[GeoNode-devel] Update (re-upload) to existing layer in GeoNode
Alessio Fabiani
alessio.fabiani at geosolutionsgroup.com
Tue Oct 11 02:12:30 PDT 2022
I would suggest updating the layer on GeoServer first and, eventually, run
the management command "updatelayers -f <layer_name>" on GeoNode.
On Tue, Oct 11, 2022 at 10:59 AM Pattara Kiatisevi <pattara at longdo.com>
wrote:
> Hi Geonode-devel,
> Is it possible to re-upload the file into an existing dataset so that the
> whole content of the dataset is replaced by the new uploaded content?
> The idea is to have the layer with the same name updated with the new
> content.
> I've tried deleting the layer and re-upload the data and found that I have
> to also delete all the dependencies (i.e., maps that use that dataset)
> before the new layer can be uploaded and use the same name.
> Any hints are appreciated.
> Thank you very much,
> Patara
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services-us for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions Group
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
https://www.geosolutionsgroup.com/
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20221011/abbef811/attachment.htm>
More information about the geonode-devel
