[GeoNode-devel] Update (re-upload) to existing layer in GeoNode
Pattara Kiatisevi pattara at longdo.com
Tue Oct 11 06:44:27 PDT 2022
Thank you to both of you. We'll explore the Geoserver as you suggested
first..
Cheers,
Pattara
On Tue, Oct 11, 2022 at 4:31 PM Giovanni Allegri <
giovanni.allegri at geosolutionsgroup.com> wrote:
> Hi Pattara,
> At the moment this feature is only partially developed, and it's only
> available through the upload API for some file formats.
> During the recent development for the new importer (that you know quite
> well) we introduced a mechanism to support data replacement, which also
> required an improvement to Geoserver. This feature still needs some work
> though, including exposing it through the client.
> Giovanni
> On Tue, Oct 11, 2022 at 11:12 AM Alessio Fabiani <
> alessio.fabiani at geosolutionsgroup.com> wrote:
>> I would suggest updating the layer on GeoServer first and, eventually,
>> run the management command "updatelayers -f <layer_name>" on GeoNode.
>> On Tue, Oct 11, 2022 at 10:59 AM Pattara Kiatisevi <pattara at longdo.com>
>> wrote:
>>> Hi Geonode-devel,
>>> Is it possible to re-upload the file into an existing dataset so that
>>> the whole content of the dataset is replaced by the new uploaded content?
>>> The idea is to have the layer with the same name updated with the new
>>> content.
>>> I've tried deleting the layer and re-upload the data and found that I
>>> have to also delete all the dependencies (i.e., maps that use that dataset)
>>> before the new layer can be uploaded and use the same name.
>>> Any hints are appreciated.
>>> Thank you very much,
>>> Patara
>>> geonode-devel mailing list
>>> geonode-devel at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>> Regards,
>> Alessio Fabiani
>> GeoServer Professional Services from the experts!
>> Visit http://bit.ly/gs-services-us for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions Group
>> phone: +39 0584 962313
>> fax:     +39 0584 1660272
>> mob:   +39  331 6233686
>> https://www.geosolutionsgroup.com/
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
> Dott. Giovanni Allegri
> Technical Lead / Project Manager
> GeoSolutions Group
> cell:     +39 345 2815774
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20221011/04b949c4/attachment.htm>
More information about the geonode-devel mailing list
