[GeoNode-devel] Question for Postgis Docker Repository
Giovanni Allegri
giovanni.allegri at geosolutionsgroup.com
Tue Jul 22 06:22:37 PDT 2025
If you mean the Docker image used by GeoNode, you can find it here
<https://github.com/GeoNode/geonode-docker/tree/master/docker/postgis>.
Giovanni
On Thu, Jul 10, 2025 at 2:11 AM Ariel Anthieni via geonode-devel <
geonode-devel at lists.osgeo.org> wrote:
> Dear Team,
> I have a quick question: What is the official repository for the PostGIS
> Docker image <https://hub.docker.com/r/geonode/postgis>?Because I can't
> find it in the repository.
> Thank you in advance for your help\!
> Best regards,
> *Ariel Anthieni*
> CEO
> Presidente de Geolibres Argentina
> <https://twitter.com/KanTerritoryIT>
> <https://www.linkedin.com/company/kan-territory-it/>
> <https://www.youtube.com/channel/UCWZ-Kv0B3pVqCExtKPJaEkA>
> <https://github.com/Kan-T-IT>
> kan.com.ar <https://www.kan.com.ar/>
> geonode-devel mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services-us for more information.
Dott. Giovanni Allegri
Technical Lead / Project Manager
GeoSolutions Group
phone: +39 0584 962313
cell: +39 345 2815774
fax: +39 0584 1660272
https://www.geosolutionsgroup.com/
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20250722/d289fc4a/attachment.htm>
More information about the geonode-devel
