[GeoNode-devel] Question for Postgis Docker Repository
    Ariel Anthieni
    aanthieni at kan.com.ar
    Tue Jul 22 07:52:56 PDT 2025
Dear Giovanni,
Yes, Thank you for the clarification.
Best regards.
*Ariel Anthieni*
CEO
Presidente de Geolibres Argentina
<https://twitter.com/KanTerritoryIT>
<https://www.linkedin.com/company/kan-territory-it/>
<https://www.youtube.com/channel/UCWZ-Kv0B3pVqCExtKPJaEkA>
<https://github.com/Kan-T-IT>
kan.com.ar <https://www.kan.com.ar/>
El mar, 22 jul 2025 a la(s) 10:22 a.m., Giovanni Allegri (
giovanni.allegri at geosolutionsgroup.com) escribió:
> If you mean the Docker image used by GeoNode, you can find it here
> <https://github.com/GeoNode/geonode-docker/tree/master/docker/postgis>.
> Giovanni
> On Thu, Jul 10, 2025 at 2:11 AM Ariel Anthieni via geonode-devel <
> geonode-devel at lists.osgeo.org> wrote:
>> Dear Team,
>> I have a quick question: What is the official repository for the PostGIS
>> Docker image <https://hub.docker.com/r/geonode/postgis>?Because I can't
>> find it in the repository.
>> Thank you in advance for your help\!
>> Best regards,
>> *Ariel Anthieni*
>> CEO
>> geonode-devel mailing list
>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> GeoServer Professional Services from the experts!
> Visit http://bit.ly/gs-services-us for more information.
> Dott. Giovanni Allegri
> Technical Lead / Project Manager
> GeoSolutions Group
> phone: +39 0584 962313
> cell:     +39 345 2815774
> fax:      +39 0584 1660272
> https://www.geosolutionsgroup.com/
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20250722/47c27392/attachment-0001.htm>
More information about the geonode-devel
