[GeoNode-users] Regarding the RESOURCE_PUBLISHING options, how can staff users publish/unpublish
Simone Dalmasso simone.dalmasso at gmail.com
Wed Aug 26 23:56:20 PDT 2015
Hi, I think that being a "staff" is not enough to get access to the db
tables. You have to grant the staff specific permissions from the staff
admin user page, there should be a drag and drop area where you can move
add, remove, edit resourcebase on the right panel.
2015-08-27 8:43 GMT+02:00 Tukang Sampah <tkgsmph at gmail.com>:
> Dear all,
> I have the following use case:
>    1. RESOURCE_PUBLISHING is set to True
>    2. Group1 has 2 users: groupadmin as manager, and groupmember as member
>    3. User groupadmin has been assigned as a staff user by the superuser
>    4. User groupmember uploads a layer, they make sure that Group1 is set
>    in the "Who can view it" and "Who can manage it" permissions
>    5. Because RESOURCE_PUBLISHING is True nobody can see the uploaded
>    layer except groupmember
>    6. User groupadmin's job is to review and publish groupmember's layer
> It is mentioned in the doc (@
> http://geonode.readthedocs.org/en/latest/reference/developers/settings.html)
> that a staff user can access the admin page and publish/unpublish
> resources. However when user groupadmin accesses /admin/layers/layer/ they
> are not permitted, and when they access groupmember's uploaded layer page
> from the group activity a 404 error is returned.
> My question: where can the groupadmin go to publish/unpublish
> groupmember's layer? Is groupadmin missing a permission to the layers admin
> page? The only way I can get groupmember's layer to be published is by the
> superuser themself, which is not desired.
> Any suggestions are appreciated.
> Thanks,
> Tukang
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150827/b4b8de0e/attachment-0001.html>
More information about the geonode-users mailing list
