[GeoNode-users] rest service connection
Marcelo Villarroel
raul.marcelo.villarroel.villazon at gmail.com
Tue May 24 09:22:35 PDT 2016
Hi Simone,
Syntax in ALLOWED_HOSTS & PROXY_ALLOWED_HOSTS was Ok. Thanks for the
advice. Connection message remains the same.
The debug console shows 3 kind of errors:
- Failed to load resource: the server responded with a status of 404
(Not Found).
- Failed to load resource: the server responded with a status of 403
(Forbidden)
- GeoExplorer.js:1660 Uncaught TypeError: Cannot read property 'wkid' of
undefined
Is it possible that ArcGIS service is comming without Coordinate System
reference?
Thank you,
On Tue, May 24, 2016 at 10:53 AM, Simone Dalmasso <simone.dalmasso at gmail.com
> wrote:
> Hi,
> the ALLOWED_HOSTS is only for your server name and it's not involved in
> the remote server use. It should contain the name or IP of your geonode
> server.
> the PROXY_ALLOWED_HOSTS should look like ( '<host>', ) beware
> the parenthesis.
> In case it still don't work you can open the browser debug console and see
> what request is issued.
> hope this helps
> 2016-05-24 16:48 GMT+02:00 Marcelo Villarroel <
> raul.marcelo.villarroel.villazon at gmail.com>:
>> Hi,
>> Geonode, version 2.4b25, is installed in a linux server of my office. I´m
>> connecting as superuser through local network.
>> There are ArcGIS rest services I want to add. They are provided as:
>> https://<host>/arcgis/rest/services/SMA/WebMap_Existente/MapServer/<name>
>> I added this server in local_settings.py:
>> ALLOWED_HOSTS= [ 'https://<host>/arcgis/services' ]
>> PROXY_ALLOWED_HOSTS = [ 'https://<host>/arcgis/services' ]
>> When I want to add a layer to a map:
>> Layers/ Add layers / Add a new Server... / Type: ArcGIS REST Service
>> (REST)
>> URL: https://
>> The message remains: Contacting server... and does not connect.
>> Do you know if there is something I´m missing in the configuration file,
>> or is something related to the ArcGIS service itself?
>> Thank you.
>> Regards,
>> *R. Marcelo Villarroel V.*
>> Ing. Civil, MSc.
>> *Sistemas de Información Geográfica*
>> Cochabamba, Bolivia.
>> Cel.: (+591) 722 12346
>> Mail: raul.marcelo.villarroel.villazon at gmail.com
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
Ing. Civil, MSc.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160524/da0fc1ad/attachment.html>
More information about the geonode-users
