[GeoNode-users] rest service connection
Simone Dalmasso simone.dalmasso at gmail.com
Wed May 25 01:53:56 PDT 2016
Hi, GeoNode is requesting it in 900913. So if the server is unable to serve
it then it gets the error. :(
2016-05-24 18:35 GMT+02:00 Marcelo Villarroel <
raul.marcelo.villarroel.villazon at gmail.com>:
> Hi Simone,
> I just saw the service has this spatial reference
>    Spatial Reference: 102100  (3857)
> Maybe GeoNode is not reading it as EPSG:900913?
> Thank you,
> On Tue, May 24, 2016 at 12:22 PM, Marcelo Villarroel <
> raul.marcelo.villarroel.villazon at gmail.com> wrote:
>> Hi Simone,
>> Syntax in ALLOWED_HOSTS & PROXY_ALLOWED_HOSTS was Ok. Thanks for the
>> advice. Connection message remains the same.
>> The debug console shows 3 kind of errors:
>>    - Failed to load resource: the server responded with a status of 404
>>    (Not Found).
>>    - Failed to load resource: the server responded with a status of 403
>>    (Forbidden)
>>    - GeoExplorer.js:1660 Uncaught TypeError: Cannot read property 'wkid'
>>    of undefined
>> Is it possible that ArcGIS service is comming without Coordinate System
>> reference?
>> Thank you,
>> On Tue, May 24, 2016 at 10:53 AM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> Hi,
>>> the ALLOWED_HOSTS is only for your server name and it's not involved in
>>> the remote server use. It should contain the name or IP of your geonode
>>> server.
>>> the PROXY_ALLOWED_HOSTS should look like  ( '<host>', ) beware
>>> the parenthesis.
>>> In case it still don't work you can open the browser debug console and
>>> see what request is issued.
>>> hope this helps
>>> 2016-05-24 16:48 GMT+02:00 Marcelo Villarroel <
>>>> Hi,
>>>> Geonode, version 2.4b25, is installed in a linux server of my office.
>>>> I´m connecting as superuser through local network.
>>>> There are ArcGIS rest services I want to add. They are provided as:
>>>> https://
>>>> <host>/arcgis/rest/services/SMA/WebMap_Existente/MapServer/<name>
>>>> I added this server in local_settings.py:
>>>> ALLOWED_HOSTS= [ 'https://<host>/arcgis/services' ]
>>>> PROXY_ALLOWED_HOSTS = [ 'https://<host>/arcgis/services' ]
>>>> When I want to add a layer to a map:
>>>> Layers/ Add layers / Add a new Server... / Type: ArcGIS REST Service
>>>> (REST)
>>>> URL: https://
>>>> The message remains: Contacting server...  and does not connect.
>>>> Do you know if there is something I´m missing in the configuration
>>>> file, or is something related to the ArcGIS service itself?
>>>> Thank you.
>>>> Regards,
>>>> *R. Marcelo Villarroel V.*
>>>> Ing. Civil, MSc.
>>>> *Sistemas de Información Geográfica*
>>>> Cochabamba, Bolivia.
>>>> Cel.:     (+591) 722 12346
>>>> Mail:     raul.marcelo.villarroel.villazon at gmail.com
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>> Simone
>> Ing. Civil, MSc.
> Ing. Civil, MSc.
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160525/f4b90644/attachment.html>
More information about the geonode-users mailing list
