[GeoNode-users] rest service connection
Marcelo Villarroel raul.marcelo.villarroel.villazon at gmail.com
Wed May 25 05:01:46 PDT 2016
So that its the problem.
Thank you very much Simone.
Best regards,
On Wed, May 25, 2016 at 4:53 AM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Hi, GeoNode is requesting it in 900913. So if the server is unable to
> serve it then it gets the error. :(
> 2016-05-24 18:35 GMT+02:00 Marcelo Villarroel <
> raul.marcelo.villarroel.villazon at gmail.com>:
>> Hi Simone,
>> I just saw the service has this spatial reference
>>    Spatial Reference: 102100  (3857)
>> Maybe GeoNode is not reading it as EPSG:900913?
>> Thank you,
>> On Tue, May 24, 2016 at 12:22 PM, Marcelo Villarroel <
>> raul.marcelo.villarroel.villazon at gmail.com> wrote:
>>> Hi Simone,
>>> Syntax in ALLOWED_HOSTS & PROXY_ALLOWED_HOSTS was Ok. Thanks for the
>>> advice. Connection message remains the same.
>>> The debug console shows 3 kind of errors:
>>>    - Failed to load resource: the server responded with a status of 404
>>>    (Not Found).
>>>    - Failed to load resource: the server responded with a status of 403
>>>    (Forbidden)
>>>    - GeoExplorer.js:1660 Uncaught TypeError: Cannot read property
>>>    'wkid' of undefined
>>> Is it possible that ArcGIS service is comming without Coordinate System
>>> reference?
>>> Thank you,
>>> On Tue, May 24, 2016 at 10:53 AM, Simone Dalmasso <
>>> simone.dalmasso at gmail.com> wrote:
>>>> Hi,
>>>> the ALLOWED_HOSTS is only for your server name and it's not involved in
>>>> the remote server use. It should contain the name or IP of your geonode
>>>> server.
>>>> the PROXY_ALLOWED_HOSTS should look like  ( '<host>', ) beware
>>>> the parenthesis.
>>>> In case it still don't work you can open the browser debug console and
>>>> see what request is issued.
>>>> hope this helps
>>>> 2016-05-24 16:48 GMT+02:00 Marcelo Villarroel <
>>>>> Hi,
>>>>> Geonode, version 2.4b25, is installed in a linux server of my office.
>>>>> I´m connecting as superuser through local network.
>>>>> There are ArcGIS rest services I want to add. They are provided as:
>>>>> https://
>>>>> <host>/arcgis/rest/services/SMA/WebMap_Existente/MapServer/<name>
>>>>> I added this server in local_settings.py:
>>>>> ALLOWED_HOSTS= [ 'https://<host>/arcgis/services' ]
>>>>> PROXY_ALLOWED_HOSTS = [ 'https://<host>/arcgis/services' ]
>>>>> When I want to add a layer to a map:
>>>>> Layers/ Add layers / Add a new Server... / Type: ArcGIS REST Service
>>>>> (REST)
>>>>> URL: https://
>>>>> The message remains: Contacting server...  and does not connect.
>>>>> Do you know if there is something I´m missing in the configuration
>>>>> file, or is something related to the ArcGIS service itself?
>>>>> Thank you.
>>>>> Regards,
>>>>> *R. Marcelo Villarroel V.*
>>>>> Ing. Civil, MSc.
>>>>> *Sistemas de Información Geográfica*
>>>>> Cochabamba, Bolivia.
>>>>> Cel.:     (+591) 722 12346
>>>>> Mail:     raul.marcelo.villarroel.villazon at gmail.com
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>>> Simone
>>> Ing. Civil, MSc.
>> Ing. Civil, MSc.
> Simone
Ing. Civil, MSc.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160525/b71eed3b/attachment-0001.html>
More information about the geonode-users mailing list
