[GeoNode-users] Geonode Error
Patrick Dufour
pjdufour.dev at gmail.com
Tue Nov 1 12:29:48 PDT 2016
This looks like an issue with the DNS configuration, based on the fact that
Django should never need to know the actual EC2 url (as it's reporting in
the error). Try update ip with the actual DNS. If that doesn't work, you
may need to manually fix the siteurl, etc. in settings.py and other places.
Regards,
Patrick Dufour
On Oct 29, 2016 6:42 AM, xbartolone at gmail.com <xbartolone at gmail.com> wrote:
Hi Isabel,
Don't worry, you should try to login to geonode and then access geoserver
from there. If you find the user directly authenticated into this latter
then the configuration is correct.
Francesco
Inviato da TypeApp <http://www.typeapp.com/r> per iPhone
On 28 ott 2016 at 23:33, WAI TING CHAN <waichan at berkeley.edu> wrote:
Hi Francesco,
I am not too familiar with django and how does it work. Could you explain
what do you mean by "django has released a session token"? Thank you so
much.
Sincerely,
Isabel
On Fri, Oct 28, 2016 at 12:45 AM, Francesco Bartoli <xbartolone at gmail.com>
wrote:
> Ok that's fine. Then make sure that geoserver is properly configured for
> authentication/authorization. From the image I see the internal hostname of
> you aws instance is not being accepted. If you access geoserver on the
> public address from the browser do you get the user automatically logged in
> after django has released a session token?
> Sent from Nylas N1
> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-87e06c7d-7160/0?redirect=https%3A%2F%2Fnylas.com%2Fn1%3Fref%3Dn1&r=d2FpY2hhbkBiZXJrZWxleS5lZHU=>,
> the extensible, open source mail client.
> On ott 28 2016, at 8:30 am, WAI TING CHAN <waichan at berkeley.edu> wrote:
>> Hi Francesco,
>> Ambika has the "superuser status", so she should have access to all the
>> layers. I also had the same error using the admin account too.
>> Sincerely,
>> Isabel
>> On Thu, Oct 27, 2016 at 9:55 PM, "xbartolone at gmail.com" <
>> Hi Tina,
>> Are you sure that the user is authorized to edit that specific layer?
>> Francesco
>> Inviato da TypeApp
>> <http://www.typeapp.com/r&r=d2FpY2hhbkBiZXJrZWxleS5lZHU=> per iPhone
>> On 28 ott 2016 at 01:44, Tina Huang <tina at ecocitybuilders.org> wrote:
>> Hi,
>> One of our interns, Ambika (cc'ing here) ran into an error when she
>> tried to edit layers on Geonode. Please see a screenshot for exact error.
>> Do you have an idea for a solution? Much appreciated your insights! Thanks!
>> Best,
>> Tina
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>> <http://lists.osgeo.org/mailman/listinfo/geonode-users&r=d2FpY2hhbkBiZXJrZWxleS5lZHU=>
>> Wai Ting Isabel Chan
>> B.S in Environmental Science, B.A in Sustainable Environmental Design
>> U.C Berkeley, Class of 2016
>> (650) 636-6782
(650) 636-6782 <(650)%20636-6782>
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20161101/3800fb1f/attachment.html>
More information about the geonode-users
