[GeoNode-users] Support for Python 3 or SNI (Server Name Indication) when using https
Daniel Victoria daniel.victoria at gmail.com
Thu Nov 3 03:33:09 PDT 2016
Issue opened. Thanks for you help Simone
Cheers
On Thu, Nov 3, 2016 at 7:24 AM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Hi Daniel,
> I can only answer to your last question and is no, at the moment there are
> no plan to move to 3 but since you raised this and is an issue we will
> discuss it at the next geonode summit. Could you please open a ticket in
> the issue tracker copying your email, I'll flag it properly.
> Thanks
> 2016-11-01 17:39 GMT+01:00 Daniel Victoria <daniel.victoria at gmail.com>:
>> Hi list,
>> I think I've hit a httplib2 bug that is causing trouble in my GeoNode
>> Install. I have GeoNode (v2.4.1) running on Ubuntu 14.01. The server is
>> behind a reverse proxy that has multiple SSL certificates associated with
>> only one IP address.
>> The problem is that when I try to upload some data to GeoNode, I get a
>> certificate mismatch. The returned certificate is the one associated with
>> the IP address of the reverse proxy and not the certificate my geonode site.
>> From what I was told, the ability to resolve multiple SSL certificates
>> from one address is implemented through SNI (Server Name Indication). And
>> from this Github issue [2], it appears that Python 2.7 and its httplib2
>> will not receive SNI support.
>> Another thing that makes me believe it's a python2.7+httplib2 specific
>> problem is that If I try to connect to my site using python2 and httplib2
>> it fails but, using python3, it works.
>> So, the questions are:
>> Is anyone running GeoNode behind a reverse proxy that implements multiple
>> SSL certificates for one address (SNI)?
>> Will the next release of geonode use python3?
>> Cheers
>> Daniel
>> [1] https://lists.osgeo.org/pipermail/geonode-users/2016-June/001933.html
>> [2] https://github.com/jcgregorio/httplib2/issues/233
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20161103/eb694526/attachment.html>
More information about the geonode-users mailing list
