[GeoNode-users] Error Uploading Layers
Simone Dalmasso
simone.dalmasso at gmail.com
Mon Oct 17 22:24:56 PDT 2016
Hi Ivo,
how did you install your geonode? I can't replicate this issue locally nor
on demo.geonode.org. It sounds like a not fully completed upgrade from 2.4.
2016-10-17 16:55 GMT+02:00 Ivo Santos <ivojfs at gmail.com>:
> I'm continuing to try to solve this issue. My layers (previously on
> geonode) when I try to reupload them are always giving the same error. I
> tried a layer downloaded from the geonode demo site and it happens like I
> previously mentioned. It gives me the following error on firebug:
> Sorry if I am annoying trying to explain you the problem.
> Thank you for your attention,
> Ivo
> -----------------------------14293747531324 Content-Disposition:
> form-data; name="base_file"; filename="arn_vt.zip" Content-Type:
> application/zip PK � �¯uQI������������ ���arn_vt.cst qÓµ��PK P< ��� ���PK
> � �¯uQI������������ ���arn_vt.shp Ô{LSw ð[ê Y&:´H …I!¢R *RÌ¥ò00Á ØCž
> !Ti)Õ Ay i NQX !Š(Q‹Ñ ¢C/³bEœàt¨ Ì ]ƒ¸QM ¨€ß& £á ÝOÎïœ_ò»çü ‚û 1å²úÉÈ$
> _½—kFÄŒ(Ú¥QÉÞø˜¢§ ÿ¢éz Iw6 ¢={(zêü õ¼?§ 6 «ß%µTv>÷ ¤oµÿ>Ú Xâ… †%px »é!
> ÚÝø žíSØo†×³ZÂmáÓ ä^žöˆ¢ ×þ&cÂ÷ ŸùÕ Þu |jÉ ž8}G ufäFMDÒõO3ìFà”V # .Í
> T,è¥è¹¶Ö±Ñ°X-pçÁlzkš ΓK¯…Á2V‡¢ öÈã7gÀWV¤{×Á= ÙäNá[k ¼äpœ‡PÑ
> BJe÷à'‹ýʇ`NéaÇ3pç±üçN} ]Ä j:`Ÿ4ûÿ¼à£yœÊFøJr“S8<â?+U ×H¿q Ác&íræd$½ nœ@ ÛÄ0³_"
> œ˜ñ Vjs ÆáÒÑ]jx {YÄ XŸ å« ¿Ö;.™†ü®Ÿ‡ËŽÁ“œ ¾*ÿvÞIx )Ž>ˆý re¡¾ý ½ãüÎ
> ú`»x·àÍp²|Þ�¼°Ì÷~ |Šéêò žì>1j‰[‡ ` žý¬øš•°wk!/ vj³ û½Øxœ vI“öÀ¼»I³ ÁúzC” >ÈWW‘ðZIaï%x¨wÇ›
> xp"YØ g xÀ LI ù E߈Kð—à cÎboØš±.$ ž©ØgN…+ö m1 zñ}o†h3 zij*2û–œíg Öæb¾Ù
> ® “+\`µè~L œ|äYÕ Îg ‰lÜQ oÒz†Á%%’‘�XR¦SyÂüæ¶j1Îo—gåŸÅ}
> ˆÜ+.Âã™yi«a££(ö1ݪá&úáu×u lX_Âi²ôKœºú <ßõäËz8 è ´EþÝ€5:1, çœ
> FœªÝï)‚•:r•å hS*5®ð@ì÷?ª`óí×~ÎpŒŽ } ï= OÂu:ò| Ìý›åjÄ<$dsS,ý8ú¨üÕM8èÐ*V
> ü—ìÏT%,ÈÚ »ÉÒ?) c*¼ô’Ù^‚ù -¿Ø<ˆyTþßo¤à‰‚Ö€F˜µYà» V ß¹%ÁÛU ¡ ã fÿý[ S.«Ø §WgŸZ‰¸rK™¨
> ®ªúÒÊ æ{ý릇?} Þ PK Í íñ¨ ��Ì ��PK � �¯uQI������������ ���arn_vt.shxc`PçbÀ
> Ì^030° w÷-øžÊè @ak‡dðC‡ l úç\üãwàÂöG!š· àÐ Œ ˜ �PK y˜®$;���l���PK � �¯uQI������������
> ���wfsrequest.txt-ÍÍ Â0 à§1·& /¥ ¤ S½ ª ^Jh·?‡fãfSñí âq æ›™Ù—J °¢œ�
> ‘¦²ÈUŠ h R¯1 G¤Õr‡ž tA÷³¥�¼;T·«É Áo ή ÿH*,¹nc ‘}dó›ëö\5§ìqiDrC’ô^æ2 ߣ¥
> }7 xF ¬k` –#Á PK ÉC“6Ž���¥���PK � �¯uQI������������ ���arn_vt.prjm _ ‚0
> Å¿ÊØ³Èþ8ç ¥ÆÜC)nR!=DŽ *¡ŒèÛ7 "È·{9çwï9Jæjfj¸R $ À<µÕÂïÝõÔ�åºÆõí
> ˜çwg€Åè1E&Ë\Ï °˜ò S ¢� ‘„„qB(‹i�ÒÊfy©í¦†²0 #Šàv;%ŔģT”z!} uuîòh÷Gÿ ×ÿ™D
> <2ÕRÛ 6îà™· óˆQ" ÃBD~`ÃÓµö}¿ÍNÝåÐö÷f djì„c× Ë¼´Ùdðè ü PK â®ËfÌ���O ��PK �
> �¯uQI������������ ���arn_vt.dbfc à dd``pdøÏ€ 8'æ ä B˜ â š<¯‚£^ žŸžÂ �PK
> ½™ ~'���@ ��PK � � �¯uQIP< ��� ��� �����������������arn_vt.cstPK � �
> �¯uQIÍ íñ¨ ��Ì �� �������������?���arn_vt.shpPK � � �¯uQIy˜®$;���l��� �������������
> ��arn_vt.shxPK � � �¯uQIÉC“6Ž���¥��� �������������’ ��wfsrequest.txtPK � �
> �¯uQIâ®ËfÌ���O �� �������������\ ��arn_vt.prjPK � � �¯uQI½™ ~'���@ �� �������������`
> ��arn_vt.dbfPK ���� � �T ��¿ ���� -----------------------------14293747531324
> Content-Disposition: form-data; name="permissions"
> {"users":{"AnonymousUser":["view_resourcebase","download_resourcebase"]},"groups":{}}
> form-data; name="charset" UTF-8 -----------------------------1
> 4293747531324--
> 2016-10-17 11:00 GMT+01:00 Ivo Santos <ivojfs at gmail.com>:
>> Hi,
>> I dont know if it helps but it happens also with rasters. Probably it is
>> my fault, but what?
>> Thank you,
>> Ivo
>> 2016-10-16 13:04 GMT+01:00 Ivo Santos <ivojfs at gmail.com>:
>>> Hi everyone,
>>> I'm having a error when uploading new layers on geonode:null value in
>>> column "metadata_uploaded_preserve" violates not-null constraint DETAIL:
>>> Failing row contains (40, 41, 32808528-9397-11e6-8c07-0cc47a6a3280, 1,
>>> academias_evora_utf8_wgs84, 2016-10-16 06:53:47.799427-05, publication,
>>> null, No abstract provided, null, null, null, null, null, eng, null, null,
>>> null, null, No information provided, null, null, null, -7.9048369022,
>>> -7.9046211568, 38.5703936836, 38.5730466272, EPSG:4326, gmd:MD_Metadata,
>>> http://www.isotc211.org/2005/gmd, local, 2016-10-16 06:53:49.017099-05,
>>> dataset, null, POLYGON((-180 -90,-180 90,180 90,180 -90,-180 -90)), f,
>>> null, , 0, 0, f, t, null, null, 0).
>>> The layer becomes available on Geoserver but not on Geonode.
>>> My log on this error is attached to the email.
>>> And my Geoserver version is: 2.7.4
>>> Any ideas?
>>> Kind regards,
>>> Ivo
>>> Ivo Santos
>> Ivo Santos
> Ivo Santos
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20161018/6aa46f87/attachment-0001.html>
More information about the geonode-users
