[GeoNode-users] documents upload by URL
Simone Dalmasso
simone.dalmasso at gmail.com
Thu Apr 6 23:55:05 PDT 2017
Documents requires the extension thus short URLs don't work. Is not a bug
but might be a good feature if someone will make a pr.
Il giorno ven 7 apr 2017 alle 04:22 Eugenio Trumpy <frippe12573 at hotmail.com>
ha scritto:
> Hi all,
> I was trying to insert a document in geonode 2.4 by using title and URL
> (without upload the file).
> If the URL contains in the end the file extension everything works fine,
> otherwise if I use
> a generated short link (e.g. https://goo.gl/d5q4hZ)
> I got this error:
> Thu Apr 06 13:46:17.129074 2017] [:error] [pid 25821] Internal Server
> Error: /documents/upload
> [Thu Apr 06 13:46:17.129220 2017] [:error] [pid 25821] Traceback (most
> recent call last):
> [Thu Apr 06 13:46:17.129228 2017] [:error] [pid 25821] File
> "/usr/local/lib/python2.7/dist-packages/django/core/handlers/base.py", line
> 112, in get_response
> [Thu Apr 06 13:46:17.129234 2017] [:error] [pid 25821] response =
> wrapped_callback(request, *callback_args, **callback_kwargs)
> [Thu Apr 06 13:46:17.129240 2017] [:error] [pid 25821] File
> "/usr/local/lib/python2.7/dist-packages/django/contrib/auth/decorators.py",
> line 22, in _wrapped_view
> [Thu Apr 06 13:46:17.129246 2017] [:error] [pid 25821] return
> view_func(request, *args, **kwargs)
> [Thu Apr 06 13:46:17.129251 2017] [:error] [pid 25821] File
> "/usr/local/lib/python2.7/dist-packages/django/views/generic/base.py", line
> 69, in view
> [Thu Apr 06 13:46:17.129256 2017] [:error] [pid 25821] return
> self.dispatch(request, *args, **kwargs)
> [Thu Apr 06 13:46:17.129261 2017] [:error] [pid 25821] File
> 87, in dispatch
> [Thu Apr 06 13:46:17.129364 2017] [:error] [pid 25821] return
> handler(request, *args, **kwargs)
> [Thu Apr 06 13:46:17.129466 2017] [:error] [pid 25821] File
> "/usr/local/lib/python2.7/dist-packages/django/views/generic/edit.py", line
> 205, in post
> [Thu Apr 06 13:46:17.129541 2017] [:error] [pid 25821] return
> super(BaseCreateView, self).post(request, *args, **kwargs)
> [Thu Apr 06 13:46:17.129595 2017] [:error] [pid 25821] File
> 171, in post
> [Thu Apr 06 13:46:17.129647 2017] [:error] [pid 25821] return
> self.form_valid(form)
> [Thu Apr 06 13:46:17.129743 2017] [:error] [pid 25821] File
> "/dati/geonode/geonode/documents/views.py", line 158, in form_valid
> [Thu Apr 06 13:46:17.129954 2017] [:error] [pid 25821]
> self.object.save()
> [Thu Apr 06 13:46:17.130137 2017] [:error] [pid 25821] File
> "/usr/local/lib/python2.7/dist-packages/polymorphic/polymorphic_model.py",
> line 90, in save
> [Thu Apr 06 13:46:17.130338 2017] [:error] [pid 25821] return
> super(PolymorphicModel, self).save(*args, **kwargs)
> [Thu Apr 06 13:46:17.130526 2017] [:error] [pid 25821] File
> "/usr/local/lib/python2.7/dist-packages/django/db/models/base.py", line
> 545, in save
> [Thu Apr 06 13:46:17.130645 2017] [:error] [pid 25821]
> force_update=force_update, update_fields=update_fields)
> [Thu Apr 06 13:46:17.130718 2017] [:error] [pid 25821] File
> 582, in save_base
> [Thu Apr 06 13:46:17.130759 2017] [:error] [pid 25821]
> update_fields=update_fields, raw=raw, using=using)
> [Thu Apr 06 13:46:17.130900 2017] [:error] [pid 25821] File
> "/usr/local/lib/python2.7/dist-packages/django/dispatch/dispatcher.py",
> line 185, in send
> [Thu Apr 06 13:46:17.130981 2017] [:error] [pid 25821] response =
> receiver(signal=self, sender=sender, **named)
> [Thu Apr 06 13:46:17.131213 2017] [:error] [pid 25821] File
> "/dati/geonode/geonode/documents/models.py", line 200, in post_save_document
> [Thu Apr 06 13:46:17.131311 2017] [:error] [pid 25821]
> link_type='data',))
> [Thu Apr 06 13:46:17.131407 2017] [:error] [pid 25821] File
> "/usr/local/lib/python2.7/dist-packages/django/db/models/manager.py", line
> 154, in get_or_create
> [Thu Apr 06 13:46:17.131468 2017] [:error] [pid 25821] return
> self.get_queryset().get_or_create(**kwargs)
> [Thu Apr 06 13:46:17.131555 2017] [:error] [pid 25821] File
> "/usr/local/lib/python2.7/dist-packages/django/db/models/query.py", line
> 391, in get_or_create
> [Thu Apr 06 13:46:17.131639 2017] [:error] [pid 25821]
> six.reraise(*exc_info)
> [Thu Apr 06 13:46:17.131724 2017] [:error] [pid 25821] File
> 383, in get_or_create
> [Thu Apr 06 13:46:17.131799 2017] [:error] [pid 25821]
> obj.save(force_insert=True, using=self.db)
> [Thu Apr 06 13:46:17.131867 2017] [:error] [pid 25821] File
> 545, in save
> [Thu Apr 06 13:46:17.131969 2017] [:error] [pid 25821]
> [Thu Apr 06 13:46:17.132086 2017] [:error] [pid 25821] File
> 573, in save_base
> [Thu Apr 06 13:46:17.132144 2017] [:error] [pid 25821] updated =
> self._save_table(raw, cls, force_insert, force_update, using, update_fields)
> [Thu Apr 06 13:46:17.132241 2017] [:error] [pid 25821] File
> 654, in _save_table
> [Thu Apr 06 13:46:17.132399 2017] [:error] [pid 25821] result =
> self._do_insert(cls._base_manager, using, fields, update_pk, raw)
> [Thu Apr 06 13:46:17.132488 2017] [:error] [pid 25821] File
> 687, in _do_insert
> [Thu Apr 06 13:46:17.132585 2017] [:error] [pid 25821] using=using,
> raw=raw)
> [Thu Apr 06 13:46:17.132646 2017] [:error] [pid 25821] File
> 232, in _insert
> [Thu Apr 06 13:46:17.132747 2017] [:error] [pid 25821] return
> insert_query(self.model, objs, fields, **kwargs)
> [Thu Apr 06 13:46:17.132804 2017] [:error] [pid 25821] File
> 1514, in insert_query
> [Thu Apr 06 13:46:17.132874 2017] [:error] [pid 25821] return
> query.get_compiler(using=using).execute_sql(return_id)
> [Thu Apr 06 13:46:17.132942 2017] [:error] [pid 25821] File
> "/usr/local/lib/python2.7/dist-packages/django/db/models/sql/compiler.py",
> line 903, in execute_sql
> [Thu Apr 06 13:46:17.133008 2017] [:error] [pid 25821]
> cursor.execute(sql, params)
> [Thu Apr 06 13:46:17.133085 2017] [:error] [pid 25821] File
> "/usr/local/lib/python2.7/dist-packages/django/db/backends/util.py", line
> 69, in execute
> [Thu Apr 06 13:46:17.133131 2017] [:error] [pid 25821] return
> super(CursorDebugWrapper, self).execute(sql, params)
> [Thu Apr 06 13:46:17.133227 2017] [:error] [pid 25821] File
> 53, in execute
> [Thu Apr 06 13:46:17.133309 2017] [:error] [pid 25821] return
> self.cursor.execute(sql, params)
> [Thu Apr 06 13:46:17.133400 2017] [:error] [pid 25821] File
> "/usr/local/lib/python2.7/dist-packages/django/db/utils.py", line 99, in
> __exit__
> [Thu Apr 06 13:46:17.133486 2017] [:error] [pid 25821]
> six.reraise(dj_exc_type, dj_exc_value, traceback)
> [Thu Apr 06 13:46:17.133557 2017] [:error] [pid 25821] File
> 53, in execute
> [Thu Apr 06 13:46:17.133661 2017] [:error] [pid 25821] return
> [Thu Apr 06 13:46:17.133721 2017] [:error] [pid 25821] IntegrityError:
> null value in column "extension" violates not-null constraint
> [Thu Apr 06 13:46:17.133808 2017] [:error] [pid 25821] DETAIL: Failing
> row contains (2772, 134, null, data, External Document, text/plain,
> https://goo.gl/F7sQB8)
> Is that a bug? Do you know a workaround?
> E.
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170407/dfbf98b2/attachment-0001.html>
More information about the geonode-users
