[GeoNode-users] documents upload by URL
Eugenio Trumpy
frippe12573 at hotmail.com
Fri Apr 7 01:26:36 PDT 2017
Thank you Simone for your feedback.
What about to remove 'not null' to the 'extension' field in table base_link?
I tried and it works. Is that a too simple solution?
Just a note, once the document with short URL has been registered it doesn't appear the regular pdf icon. I Think this should be related, isn't it?
E.
Da: Simone Dalmasso <simone.dalmasso at gmail.com>
Inviato: venerdì 7 aprile 2017 08.55
A: Eugenio Trumpy; geonode-users at lists.osgeo.org
Oggetto: Re: [GeoNode-users] documents upload by URL
Documents requires the extension thus short URLs don't work. Is not a bug but might be a good feature if someone will make a pr.
Il giorno ven 7 apr 2017 alle 04:22 Eugenio Trumpy <frippe12573 at hotmail.com<mailto:frippe12573 at hotmail.com>> ha scritto:
Hi all,
I was trying to insert a document in geonode 2.4 by using title and URL (without upload the file).
If the URL contains in the end the file extension everything works fine, otherwise if I use
a generated short link (e.g. https://goo.gl/d5q4hZ)
I got this error:
Thu Apr 06 13:46:17.129074 2017] [:error] [pid 25821] Internal Server Error: /documents/upload
[Thu Apr 06 13:46:17.129220 2017] [:error] [pid 25821] Traceback (most recent call last):
[Thu Apr 06 13:46:17.129228 2017] [:error] [pid 25821] File "/usr/local/lib/python2.7/dist-packages/django/core/handlers/base.py", line 112, in get_response
[Thu Apr 06 13:46:17.129234 2017] [:error] [pid 25821] response = wrapped_callback(request, *callback_args, **callback_kwargs)
[Thu Apr 06 13:46:17.129240 2017] [:error] [pid 25821] File "/usr/local/lib/python2.7/dist-packages/django/contrib/auth/decorators.py", line 22, in _wrapped_view
[Thu Apr 06 13:46:17.129246 2017] [:error] [pid 25821] return view_func(request, *args, **kwargs)
[Thu Apr 06 13:46:17.129251 2017] [:error] [pid 25821] File "/usr/local/lib/python2.7/dist-packages/django/views/generic/base.py", line 69, in view
[Thu Apr 06 13:46:17.129256 2017] [:error] [pid 25821] return self.dispatch(request, *args, **kwargs)
[Thu Apr 06 13:46:17.129261 2017] [:error] [pid 25821] File "/usr/local/lib/python2.7/dist-packages/django/views/generic/base.py", line 87, in dispatch
[Thu Apr 06 13:46:17.129364 2017] [:error] [pid 25821] return handler(request, *args, **kwargs)
[Thu Apr 06 13:46:17.129466 2017] [:error] [pid 25821] File "/usr/local/lib/python2.7/dist-packages/django/views/generic/edit.py", line 205, in post
[Thu Apr 06 13:46:17.129541 2017] [:error] [pid 25821] return super(BaseCreateView, self).post(request, *args, **kwargs)
[Thu Apr 06 13:46:17.129595 2017] [:error] [pid 25821] File "/usr/local/lib/python2.7/dist-packages/django/views/generic/edit.py", line 171, in post
[Thu Apr 06 13:46:17.129647 2017] [:error] [pid 25821] return self.form_valid(form)
[Thu Apr 06 13:46:17.129743 2017] [:error] [pid 25821] File "/dati/geonode/geonode/documents/views.py", line 158, in form_valid
[Thu Apr 06 13:46:17.129954 2017] [:error] [pid 25821] self.object.save()
[Thu Apr 06 13:46:17.130137 2017] [:error] [pid 25821] File "/usr/local/lib/python2.7/dist-packages/polymorphic/polymorphic_model.py", line 90, in save
[Thu Apr 06 13:46:17.130338 2017] [:error] [pid 25821] return super(PolymorphicModel, self).save(*args, **kwargs)
[Thu Apr 06 13:46:17.130526 2017] [:error] [pid 25821] File "/usr/local/lib/python2.7/dist-packages/django/db/models/base.py", line 545, in save
[Thu Apr 06 13:46:17.130645 2017] [:error] [pid 25821] force_update=force_update, update_fields=update_fields)
[Thu Apr 06 13:46:17.130718 2017] [:error] [pid 25821] File "/usr/local/lib/python2.7/dist-packages/django/db/models/base.py", line 582, in save_base
[Thu Apr 06 13:46:17.130759 2017] [:error] [pid 25821] update_fields=update_fields, raw=raw, using=using)
[Thu Apr 06 13:46:17.130900 2017] [:error] [pid 25821] File "/usr/local/lib/python2.7/dist-packages/django/dispatch/dispatcher.py", line 185, in send
[Thu Apr 06 13:46:17.130981 2017] [:error] [pid 25821] response = receiver(signal=self, sender=sender, **named)
[Thu Apr 06 13:46:17.131213 2017] [:error] [pid 25821] File "/dati/geonode/geonode/documents/models.py", line 200, in post_save_document
[Thu Apr 06 13:46:17.131311 2017] [:error] [pid 25821] link_type='data',))
[Thu Apr 06 13:46:17.131407 2017] [:error] [pid 25821] File "/usr/local/lib/python2.7/dist-packages/django/db/models/manager.py", line 154, in get_or_create
[Thu Apr 06 13:46:17.131468 2017] [:error] [pid 25821] return self.get_queryset().get_or_create(**kwargs)
[Thu Apr 06 13:46:17.131555 2017] [:error] [pid 25821] File "/usr/local/lib/python2.7/dist-packages/django/db/models/query.py", line 391, in get_or_create
[Thu Apr 06 13:46:17.131639 2017] [:error] [pid 25821] six.reraise(*exc_info)
[Thu Apr 06 13:46:17.131724 2017] [:error] [pid 25821] File "/usr/local/lib/python2.7/dist-packages/django/db/models/query.py", line 383, in get_or_create
[Thu Apr 06 13:46:17.131799 2017] [:error] [pid 25821] obj.save(force_insert=True, using=self.db)
[Thu Apr 06 13:46:17.131867 2017] [:error] [pid 25821] File "/usr/local/lib/python2.7/dist-packages/django/db/models/base.py", line 545, in save
[Thu Apr 06 13:46:17.131969 2017] [:error] [pid 25821] force_update=force_update, update_fields=update_fields)
[Thu Apr 06 13:46:17.132086 2017] [:error] [pid 25821] File "/usr/local/lib/python2.7/dist-packages/django/db/models/base.py", line 573, in save_base
[Thu Apr 06 13:46:17.132144 2017] [:error] [pid 25821] updated = self._save_table(raw, cls, force_insert, force_update, using, update_fields)
[Thu Apr 06 13:46:17.132241 2017] [:error] [pid 25821] File "/usr/local/lib/python2.7/dist-packages/django/db/models/base.py", line 654, in _save_table
[Thu Apr 06 13:46:17.132399 2017] [:error] [pid 25821] result = self._do_insert(cls._base_manager, using, fields, update_pk, raw)
[Thu Apr 06 13:46:17.132488 2017] [:error] [pid 25821] File "/usr/local/lib/python2.7/dist-packages/django/db/models/base.py", line 687, in _do_insert
[Thu Apr 06 13:46:17.132585 2017] [:error] [pid 25821] using=using, raw=raw)
[Thu Apr 06 13:46:17.132646 2017] [:error] [pid 25821] File "/usr/local/lib/python2.7/dist-packages/django/db/models/manager.py", line 232, in _insert
[Thu Apr 06 13:46:17.132747 2017] [:error] [pid 25821] return insert_query(self.model, objs, fields, **kwargs)
[Thu Apr 06 13:46:17.132804 2017] [:error] [pid 25821] File "/usr/local/lib/python2.7/dist-packages/django/db/models/query.py", line 1514, in insert_query
[Thu Apr 06 13:46:17.132874 2017] [:error] [pid 25821] return query.get_compiler(using=using).execute_sql(return_id)
[Thu Apr 06 13:46:17.132942 2017] [:error] [pid 25821] File "/usr/local/lib/python2.7/dist-packages/django/db/models/sql/compiler.py", line 903, in execute_sql
[Thu Apr 06 13:46:17.133008 2017] [:error] [pid 25821] cursor.execute(sql, params)
[Thu Apr 06 13:46:17.133085 2017] [:error] [pid 25821] File "/usr/local/lib/python2.7/dist-packages/django/db/backends/util.py", line 69, in execute
[Thu Apr 06 13:46:17.133131 2017] [:error] [pid 25821] return super(CursorDebugWrapper, self).execute(sql, params)
[Thu Apr 06 13:46:17.133227 2017] [:error] [pid 25821] File "/usr/local/lib/python2.7/dist-packages/django/db/backends/util.py", line 53, in execute
[Thu Apr 06 13:46:17.133309 2017] [:error] [pid 25821] return self.cursor.execute(sql, params)
[Thu Apr 06 13:46:17.133400 2017] [:error] [pid 25821] File "/usr/local/lib/python2.7/dist-packages/django/db/utils.py", line 99, in __exit__
[Thu Apr 06 13:46:17.133486 2017] [:error] [pid 25821] six.reraise(dj_exc_type, dj_exc_value, traceback)
[Thu Apr 06 13:46:17.133557 2017] [:error] [pid 25821] File "/usr/local/lib/python2.7/dist-packages/django/db/backends/util.py", line 53, in execute
[Thu Apr 06 13:46:17.133661 2017] [:error] [pid 25821] return self.cursor.execute(sql, params)
[Thu Apr 06 13:46:17.133721 2017] [:error] [pid 25821] IntegrityError: null value in column "extension" violates not-null constraint
[Thu Apr 06 13:46:17.133808 2017] [:error] [pid 25821] DETAIL: Failing row contains (2772, 134, null, data, External Document, text/plain, https://goo.gl/F7sQB8)
Is that a bug? Do you know a workaround?
E.
geonode-users mailing list
geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170407/d31833ca/attachment.html>
More information about the geonode-users
