[GeoNode-users] Geonode - Error on uploading layer
Francesco Bartoli
xbartolone at gmail.com
Mon Apr 10 05:43:25 PDT 2017
Yes, absolutely. It looks like you missed this one http://geonode.org/geonode-workshop/foss4git2017/#/4/6
Il giorno 10/apr/2017, alle ore 14:39, giuseppe musumeci <musumeci.giuseppe at gmail.com> ha scritto:
> I followed all the istructions in the tutorial you send me.
> Is there a way to correct these errors using a command (i.e sudo geonode-updateip localhost:8001)?
> 2017-04-10 14:33 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
> How did you perform the installation?
> You were originally receive that error because GEOSERVER_PUBLIC_LOCATION is wrong. It should be:
> 'http://localhost:8001/geoserver'
> Il giorno 10/apr/2017, alle ore 13:44, giuseppe musumeci <musumeci.giuseppe at gmail.com> ha scritto:
>> From /usr/local/lib/python2.7/dist-packages/geonode/settings.py
>> GEOSERVER_LOCATION = os.getenv(
>> 'GEOSERVER_LOCATION', 'http://localhost:8080/geoserver/'
>> GEOSERVER_PUBLIC_LOCATION = os.getenv(
>> 'GEOSERVER_PUBLIC_LOCATION', 'http://localhost:8080/geoserver/'
>> From /etc/geonode/local_settings.py
>> GEOSERVER_URL = SITEURL + 'geoserver/'
>> 2017-04-10 13:31 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>> Can you double check what you have in the settings for the geoserver configurations?
>> Sent from Nylas Pro, the most powerful email app for work
>> On apr 10 2017, at 1:28 pm, giuseppe musumeci <musumeci.giuseppe at gmail.com> wrote:
>> Dear Francesco,
>> I followed the tutorial
>> I need to set <proxyBaseUrl>http://localhost:8001/geoserver/</proxyBaseUrl>
>> and not <proxyBaseUrl>http://localhost:8001/</proxyBaseUrl>
>> In this way geoserver seems to work fine.
>> The problem is I'm not able to upload layers from geonode menu
>> [Errno 111] Connection refused
>> 2017-04-10 13:18 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>> Giuseppe,
>> if you set "<proxyBaseUrl>http://localhost:8080/geoserver/</proxyBaseUrl>" then you have to make that url reachable from your host. That means
>> the configuration "config.vm.network "forwarded_port", guest: 8080, host: 8080” is required otherwise you get the 404 error.
>> Il giorno 10/apr/2017, alle ore 11:18, giuseppe musumeci <musumeci.giuseppe at gmail.com> ha scritto:
>>> To be able to upload layers I must set
>>> into usr/share/geoserver/data/global.xml
>>> If I open geoserver from the admin panel the address is
>>> http://localhost:8001/geoserver/web/?1
>>> but If i want for example a layer preview
>>> address change to
>>> http://localhost:8080/geoserver/geonode/wms?access_token=h4oWfeewhIhMk1aNWvm4nmXSG1QSO1%3Fservice%3DWMS/kml?layers=geonode:fiora_amianto
>>> with error The requested URL /geoserver/geonode/wms was not found on this server.
>>> 2017-04-10 10:58 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>> is simply redundant. It has been added to access geoserver out of the scope of oauth2.
>>> What url are you going to call in the browser for geoserver?
>>> On apr 10 2017, at 10:49 am, giuseppe musumeci <musumeci.giuseppe at gmail.com> wrote:
>>> I ran the installation of Geonode using the instructions at the link http://geonode.org/geonode-workshop/foss4git2017/#/4/2
>>> I think there are problems in the instructions about geoserver configuration:
>>> $ Sudo vi usr / share / geoserver / data / global.xml
>>> I changed the default settings with those specified:
>>> <ProxyBaseUrl> http: // localhost: 8001 / </ proxyBaseUrl>
>>> But geoserver don't works: I then set the value to
>>> moreover i Think that to configure vagrantfile as suggested:
>>> is not correct.
>>> Could someone tell me the correct settings values for geoserver and vagrantfile?
>>> 2017-04-06 14:40 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>> Dear Giuseppe,
>>> as already replied on the italian gfoss list you should check to follow from scratch the workshop http://geonode.org/geonode-workshop/foss4git2017/#/4/2 we did during foss4g-it. If the error is still happening please let me know as probably in this case the beta release is also affected and you can help us with your feedback.
>>> Thanks,
>>> Francesco
>>> Il giorno 06/apr/2017, alle ore 14:12, giuseppe musumeci <musumeci.giuseppe at gmail.com> ha scritto:
>>>> Dear list
>>>> I'm working with Geonode that I installed on a VM set via Vagrant
>>>> When I try to load the shape file, I get this error:
>>>> failed to create /var/www/vagrant-ubuntu-trusty-64.MainThread-3777
>>>> In the Apache error log is as follows:
>>>> ERROR: geonode.layers.views: failed to create /var/www/vagrant-ubuntu-trusty-64.Dummy-2-3778
>>>> Trying to google around I found that in the settings.py file should add the line:
>>>> NOTIFICATION_LOCK_LOCATION = '/ var / www / geonode'
>>>> Finally I verified that the www-data user has all permissions on the www / folder geonode
>>>> drwxr-xr-x 5 www-data root March 21 4096 14:27 geonode
>>>> The fact remains that I can't upload.
>>>> Does anyone know help me?
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170410/a68f7b66/attachment.html>
More information about the geonode-users
