[GeoNode-users] Geonode - Error on uploading layer
giuseppe musumeci musumeci.giuseppe at gmail.com
Mon Apr 10 06:46:50 PDT 2017
I installed again geonode according the tutorial
I run the command geonode-updateip
I have problem to load layers:[Errno 111] Connection refused
Where I'm wrong?
2017-04-10 14:43 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
> Yes, absolutely. It looks like you missed this one http://geonode.org/
> geonode-workshop/foss4git2017/#/4/6
> Il giorno 10/apr/2017, alle ore 14:39, giuseppe musumeci <
> musumeci.giuseppe at gmail.com> ha scritto:
> I followed all the istructions in the tutorial you send me.
> Is there a way to correct these errors using a command (i.e sudo
> geonode-updateip localhost:8001)?
> 2017-04-10 14:33 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>> How did you perform the installation?
>> You were originally receive that error because GEOSERVER_PUBLIC_LOCATION
>> is wrong. It should be:
>> 'http://localhost:8001/geoserver'
>> Il giorno 10/apr/2017, alle ore 13:44, giuseppe musumeci <
>> From /usr/local/lib/python2.7/dist-packages/geonode/settings.py
>> GEOSERVER_LOCATION = os.getenv(
>>     'GEOSERVER_LOCATION', 'http://localhost:8080/geoserver/'
>> GEOSERVER_PUBLIC_LOCATION = os.getenv(
>>     'GEOSERVER_PUBLIC_LOCATION', 'http://localhost:8080/geoserver/'
>> From /etc/geonode/local_settings.py
>> GEOSERVER_URL = SITEURL + 'geoserver/'
>> 2017-04-10 13:31 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>> Can you double check what you have in the settings for the
>>> geoserver configurations?
>>> Sent from Nylas Pro
>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-677d8377-2abb/0?redirect=https%3A%2F%2Fnylas.com%2Fnylas-pro%3Fref%3Dn1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>,
>>> the most powerful email app for work
>>> On apr 10 2017, at 1:28 pm, giuseppe musumeci <
>>> musumeci.giuseppe at gmail.com> wrote:
>>>> Dear Francesco,
>>>> I followed the tutorial
>>>> I need to set <proxyBaseUrl>http://localhost:8001/geoserver/
>>>> <http://localhost:8080/geoserver/&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>> </proxyBaseUrl>
>>>> and not <proxyBaseUrl>http://localhost:8001/
>>>> </proxyBaseUrl>
>>>> In this way geoserver seems to work fine.
>>>> The problem is I'm not able to upload layers from geonode menu
>>>> 2017-04-10 13:18 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>> Giuseppe,
>>>> if you set "<proxyBaseUrl>http://localhost:8080/geoserver/
>>>> </proxyBaseUrl>" then you have to make that url reachable from your
>>>> host. That means
>>>> the configuration "config.vm.network
>>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-eec0852c-64f5/0?redirect=config.vm.network&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>  "forwarded_port", guest: 8080, host: 8080” is required otherwise you
>>>> get the 404 error.
>>>> Il giorno 10/apr/2017, alle ore 11:18, giuseppe musumeci <
>>>> To be able to upload layers I must set
>>>> </proxyBaseUrl>
>>>> into usr/share/geoserver/data/global.xml
>>>> If I open geoserver from the admin panel the address is
>>>> http://localhost:8001/geoserver/web/?1
>>>> <http://localhost:8001/geoserver/web/?1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>> but If i want for example a layer preview
>>>> address change to
>>>> http://localhost:8080/geoserver/geonode/wms?access_token=h4o
>>>> WfeewhIhMk1aNWvm4nmXSG1QSO1%3Fservice%3DWMS/kml?layers=geono
>>>> de:fiora_amianto
>>>> <http://localhost:8080/geoserver/geonode/wms?access_token=h4oWfeewhIhMk1aNWvm4nmXSG1QSO1%3Fservice%3DWMS/kml?layers=geonode:fiora_amianto&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>> with error The requested URL /geoserver/geonode/wms was not found on
>>>> this server.
>>>> 2017-04-10 10:58 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>> config.vm.network
>>>> is simply redundant. It has been added to access geoserver out of the
>>>> scope of oauth2.
>>>> What url are you going to call in the browser for geoserver?
>>>> Sent from Nylas Pro
>>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-eec0852c-64f5/1?redirect=https%3A%2F%2Fnylas.com%2Fnylas-pro%3Fref%3Dn1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>,
>>>> On apr 10 2017, at 10:49 am, giuseppe musumeci <
>>>> I ran the installation of Geonode using the instructions at the link
>>>> http://geonode.org/geonode-workshop/foss4git2017/#/4/2
>>>> <http://geonode.org/geonode-workshop/foss4git2017/#/4/2&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>> I think there are problems in the instructions about geoserver
>>>> configuration:
>>>> $ Sudo vi usr / share / geoserver / data / global.xml
>>>> I changed the default settings with those specified:
>>>> <ProxyBaseUrl> http: // localhost: 8001 / </ proxyBaseUrl>
>>>> But geoserver don't works: I then set the value to
>>>> moreover i Think that to configure vagrantfile as suggested:
>>>> config.vm.network "forwarded_port", guest: 8080, host: 8080
>>>> is not correct.
>>>> Could someone tell me the correct settings values for geoserver and
>>>> vagrantfile?
>>>> 2017-04-06 14:40 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>> Dear Giuseppe,
>>>> as already replied on the italian gfoss list you should check to follow
>>>> from scratch the workshop http://geonode.org/ge
>>>> <http://geonode.org/geonode-workshop/foss4git2017/#/4/2&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t> we
>>>> did during foss4g-it. If the error is still happening please let me know as
>>>> probably in this case the beta release is also affected and you can help us
>>>> with your feedback.
>>>> Thanks,
>>>> Francesco
>>>> Il giorno 06/apr/2017, alle ore 14:12, giuseppe musumeci <
>>>> Dear list I'm working with Geonode that I installed on a VM set via
>>>> Vagrant When I try to load the shape file, I get this error: *failed
>>>> to create /var/www/vagrant-ubuntu-trusty-64.MainThread-3777* In the
>>>> Apache error log is as follows: *ERROR: geonode.layers.views: failed
>>>> to create /var/www/vagrant-ubuntu-trusty-64.Dummy-2-3778* Trying to
>>>> google around I found that in the settings.py file should add the line:
>>>> NOTIFICATION_LOCK_LOCATION = '/ var / www / geonode' Finally I verified
>>>> that the www-data user has all permissions on the www / folder geonode
>>>> drwxr-xr-x 5 www-data root March 21 4096 14:27 geonode The fact remains
>>>> that I can't upload. Does anyone know help me?
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>> <https://lists.osgeo.org/mailman/listinfo/geonode-users&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170410/67056b1c/attachment-0001.html>
More information about the geonode-users mailing list
