[GeoNode-users] Problem to update the metadata_xml and CSW response
Tom Kralidis
tomkralidis at gmail.com
Wed Apr 12 18:40:30 PDT 2017
Hi Davi: sorry for the delay, comments interleaved:
On Fri, Mar 31, 2017 at 2:02 PM, Davi Custodio <davicustodio at gmail.com> wrote:
> Hello everyone, I'm having problems in the metadata form of Geonode 2.4 with
> regards to CSW xml generation.
> I noticed that, for example, if i change only the abstract field, the
> metadata_xml is not populated, and consequently, the PyCSW response remains
> out of date.
I'm unable to reproduce against 2.4.x branch. Updating the metadata
form propagates
the changes in the metadata_xml and pycsw as expected. Are you able
to try against
2.4.x branch specifically?
> In what class should I change, to force, that whenever any field in the
> metadata form is changed, the metadata_xml field is populated?
> Thanks
> Davi de O. Custódio
More information about the geonode-users
