[GeoNode-users] Geonode - Error on uploading layer
giuseppe musumeci musumeci.giuseppe at gmail.com
Fri Apr 21 03:18:32 PDT 2017
Hi francesco.
I'm having problem with this configuration.
1.from geoserver if i want a preview I get this error:
Impossibile trovare la pagina localhost
Nessuna pagina web trovata per l'indirizzo
web:*http://localhost/geoserver/geonode/wms?service=WMS&version=1.1.0&request=GetMap&layers=geonode:comunidart&styles=&bbox=1553666.125,4677093.5,1772807.875,4926024.5&width=676&height=768&srs=EPSG:3003&format=application/openlayers
<http://localhost/geoserver/geonode/wms?service=WMS&version=1.1.0&request=GetMap&layers=geonode:comunidart&styles=&bbox=1553666.125,4677093.5,1772807.875,4926024.5&width=676&height=768&srs=EPSG:3003&format=application/openlayers>*
HTTP ERROR 404
2. pOSTGRESQL
i'M UNABLE TO CONNECT PGADMIN RUNNING IN WINDOWS TO GEONODE DATABASE
RUNNING IN vm
i'VE SPENT LAST TWO DAYS
2017-04-21 0:07 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
> Hi Giuseppe,
> I have to adjust my previous hints. To recap the required configurations
> for geoserver are:
> /usr/share/geoserver/data/security/role/geonode\ REST\ role\ service/config.
> <baseUrl>http://localhost:80/</baseUrl>
> /usr/share/geoserver/data/security/filter/geonode-oauth2/config.xml
> <accessTokenUri>http://localhost/o/token/</accessTokenUri>
> <userAuthorizationUri>http://localhost:8001/o/authorize/</userAuthorizationUri>
> <redirectUri>http://localhost:8001/geoserver</redirectUri>
> <checkTokenEndpointUrl>http://localhost/api/o/v4/tokeninfo/</checkTokenEndpointUrl>
> <logoutUri>http://localhost:8001/account/logout/</logoutUri>
> /usr/share/geoserver/data/security/auth/geonodeAuthProvider/config.xml
> <baseUrl>http://localhost:8001/</baseUrl>
> /usr/share/geoserver/data/global.xml
> <proxyBaseUrl>http://localhost:80/geoserver</proxyBaseUrl>
> I have updated the workshop, also figuring out that this configuration is
> a GeoNode full proxied use case where the internal port 8080 is not
> forwarded to the host machine.
> Thanks for reporting your initial issues.
> Hope this definitively clarifies,
> Francesco
> Il giorno 12/apr/2017, alle ore 21:34, giuseppe musumeci <
> musumeci.giuseppe at gmail.com> ha scritto:
> Leaving <proxyBaseUrl> unaltered. I'm able to load layer but I'm not able
> to preview it in geoserver:
> The port changes from 8001 to 8080 and I have the error
>  "The requested URL /geoserver/geonode/wms was not found on this server."
> 2017-04-11 12:28 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>> Thanks Simone you are right. I will update the slide, it was my fault.
>>  @Giuseppe you have to leave <proxyBaseUrl> unaltered.
>> Sent from Nylas Pro
>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-070d2acb-91ee/0?redirect=https%3A%2F%2Fnylas.com%2Fnylas-pro%3Fref%3Dn1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>,
>> the most powerful email app for work
>> On apr 11 2017, at 7:23 am, Simone Dalmasso <simone.dalmasso at gmail.com>
>> wrote:
>>> Dears, just a not.
>>> In the vagrant installation we made at the workshop, there's no need to
>>> forward geoserver to the host as the apache proxy will take care of serving
>>> under localhost:8001/geoserver.
>>> Best
>>> 2017-04-10 23:35 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>> See inline
>>> Il giorno 10/apr/2017, alle ore 21:14, giuseppe musumeci <
>>> I followed your instructions.
>>> There are few differences:
>>> in order the system works I must set
>>> *<proxyBaseUrl>http://localhost:8001/geoserver
>>> <http://localhost:8001/geoserver&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>> /</proxyBaseUrl>*
>>> instead of
>>> <http://localhost:8001/&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>> /</proxyBaseUrl> *
>>> This is not required if the settings are configured fine. During an
>>> installation with apt-get this is done automatically while executing the
>>> command geonode-updateip
>>> I cannot edit vagrant file with *config.vm.network "forwarded_port",
>>> guest: 8080, host: **8080*
>>> infact I get the error
>>> "Vagrant cannot forward the specified ports on this VM, since they
>>> would collide with some other application that is already listening on
>>> these ports. The forwarded port to 8080 is already in use on the host
>>> machine.”
>>> You have another process which is running on port 8080 in your host
>>> machine. Please shutdown that.
>>> If I try to upload a layer I get this error [Errno 111] Connection
>>> refused
>>> but if I access geoserver on http://localhost:8001/geoserver/web
>>> <http://localhost:8001/geoserver/web&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>> Apparently some geoserver configurations in your settings are still
>>> wrong. Are you sure you started a new installation after a vagrant destroy?
>>> I see that layers have been uploaded into geoserver.
>>> Nevethless If I watch into geonode I see that "No content created yet"
>>> 2017-04-10 16:09 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>> If you have run “sudo geonode-updateip localhost:8001” then the next
>>> thing to do is to check again the configuration of geoserver in settings
>>> file and for the security in the data directory.
>>> Il giorno 10/apr/2017, alle ore 16:05, giuseppe musumeci <
>>> I've already done it in this attempt
>>> Il 10/apr/2017 16:02, "Francesco Bartoli" <xbartolone at gmail.com> ha
>>> scritto:
>>> Can you please repeat all the commands from scratch? You can do it by
>>> running “vagrant destroy”
>>> Il giorno 10/apr/2017, alle ore 15:46, giuseppe musumeci <
>>> I installed again geonode according the tutorial
>>> I run the command geonode-updateip
>>> I have problem to load layers:[Errno 111] Connection refused
>>> Where I'm wrong?
>>> 2017-04-10 14:43 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>> Yes, absolutely. It looks like you missed this one
>>> http://geonode.org/geonode-workshop/foss4git2017/#/4/6
>>> <http://geonode.org/geonode-workshop/foss4git2017/#/4/6&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>> Il giorno 10/apr/2017, alle ore 14:39, giuseppe musumeci <
>>> I followed all the istructions in the tutorial you send me.
>>> Is there a way to correct these errors using a command (i.e sudo
>>> geonode-updateip localhost:8001)?
>>> 2017-04-10 14:33 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>> How did you perform the installation?
>>> You were originally receive that error because GEOSERVER_PUBLIC_LOCATION
>>> is wrong. It should be:
>>> 'http://localhost:8001/geoserver'
>>> <http://localhost:8001/geoserver&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t'>
>>> Il giorno 10/apr/2017, alle ore 13:44, giuseppe musumeci <
>>> From /usr/local/lib/python2.7/dist-packages/geonode/settings.py
>>> GEOSERVER_LOCATION = os.getenv(
>>>     'GEOSERVER_LOCATION', 'http://localhost:8080/geoserver/
>>> <http://localhost:8080/geoserver/&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>> GEOSERVER_PUBLIC_LOCATION = os.getenv(
>>>     'GEOSERVER_PUBLIC_LOCATION', 'http://localhost:8080/geoserver/
>>> From /etc/geonode/local_settings.py
>>> GEOSERVER_URL = SITEURL + 'geoserver/'
>>> 2017-04-10 13:31 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>> Can you double check what you have in the settings for the
>>> geoserver configurations?
>>> Sent from Nylas Pro
>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-677d8377-2abb/0?redirect=https%3A%2F%2Fnylas.com%2Fnylas-pro%3Fref%3Dn1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>,
>>> On apr 10 2017, at 1:28 pm, giuseppe musumeci <
>>> musumeci.giuseppe at gmail.com> wrote:
>>> Dear Francesco,
>>> I followed the tutorial
>>> I need to set <proxyBaseUrl>http://localhost:8001/geoserver/
>>> <http://localhost:8080/geoserver/&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>> </proxyBaseUrl>
>>> and not <proxyBaseUrl>http://localhost:8001/
>>> </proxyBaseUrl>
>>> In this way geoserver seems to work fine.
>>> The problem is I'm not able to upload layers from geonode menu
>>> 2017-04-10 13:18 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>> Giuseppe,
>>> if you set "<proxyBaseUrl>http://localhost:8080/geoserver/
>>> </proxyBaseUrl>" then you have to make that url reachable from your
>>> host. That means
>>> the configuration "config.vm.network
>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-eec0852c-64f5/0?redirect=config.vm.network&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>  "forwarded_port", guest: 8080, host: 8080” is required otherwise you
>>> get the 404 error.
>>> Il giorno 10/apr/2017, alle ore 11:18, giuseppe musumeci <
>>> To be able to upload layers I must set
>>> </proxyBaseUrl>
>>> into usr/share/geoserver/data/global.xml
>>> If I open geoserver from the admin panel the address is
>>> http://localhost:8001/geoserver/web/?1
>>> <http://localhost:8001/geoserver/web/?1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>> but If i want for example a layer preview
>>> address change to
>>> http://localhost:8080/geoserver/geonode/wms?access_token=h4o
>>> WfeewhIhMk1aNWvm4nmXSG1QSO1%3Fservice%3DWMS/kml?layers=geono
>>> de:fiora_amianto
>>> <http://localhost:8080/geoserver/geonode/wms?access_token=h4oWfeewhIhMk1aNWvm4nmXSG1QSO1%3Fservice%3DWMS/kml?layers=geonode:fiora_amianto&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>> with error The requested URL /geoserver/geonode/wms was not found on
>>> this server.
>>> 2017-04-10 10:58 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>> config.vm.network
>>> is simply redundant. It has been added to access geoserver out of the
>>> scope of oauth2.
>>> What url are you going to call in the browser for geoserver?
>>> Sent from Nylas Pro
>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-eec0852c-64f5/1?redirect=https%3A%2F%2Fnylas.com%2Fnylas-pro%3Fref%3Dn1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>,
>>> On apr 10 2017, at 10:49 am, giuseppe musumeci <
>>> I ran the installation of Geonode using the instructions at the link
>>> http://geonode.org/geonode-workshop/foss4git2017/#/4/2
>>> <http://geonode.org/geonode-workshop/foss4git2017/#/4/2&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>> I think there are problems in the instructions about geoserver
>>> configuration:
>>> $ Sudo vi usr / share / geoserver / data / global.xml
>>> I changed the default settings with those specified:
>>> <ProxyBaseUrl> http: // localhost: 8001 / </ proxyBaseUrl>
>>> But geoserver don't works: I then set the value to
>>> moreover i Think that to configure vagrantfile as suggested:
>>> config.vm.network "forwarded_port", guest: 8080, host: 8080
>>> is not correct.
>>> Could someone tell me the correct settings values for geoserver and
>>> vagrantfile?
>>> 2017-04-06 14:40 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>> Dear Giuseppe,
>>> as already replied on the italian gfoss list you should check to follow
>>> from scratch the workshop http://geonode.org/ge
>>> <http://geonode.org/geonode-workshop/foss4git2017/#/4/2&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t> we
>>> did during foss4g-it. If the error is still happening please let me know as
>>> probably in this case the beta release is also affected and you can help us
>>> with your feedback.
>>> Thanks,
>>> Francesco
>>> Il giorno 06/apr/2017, alle ore 14:12, giuseppe musumeci <
>>> Dear list I'm working with Geonode that I installed on a VM set via
>>> Vagrant When I try to load the shape file, I get this error: *failed to
>>> create /var/www/vagrant-ubuntu-trusty-64.MainThread-3777* In the Apache
>>> error log is as follows: *ERROR: geonode.layers.views: failed to create
>>> /var/www/vagrant-ubuntu-trusty-64.Dummy-2-3778* Trying to google around
>>> I found that in the settings.py file should add the line:
>>> NOTIFICATION_LOCK_LOCATION = '/ var / www / geonode' Finally I verified
>>> that the www-data user has all permissions on the www / folder geonode
>>> drwxr-xr-x 5 www-data root March 21 4096 14:27 geonode The fact remains
>>> that I can't upload. Does anyone know help me?
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> <https://lists.osgeo.org/mailman/listinfo/geonode-users&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>> <https://lists.osgeo.org/mailman/listinfo/geonode-users&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170421/af35f368/attachment-0001.html>
More information about the geonode-users mailing list
