[GeoNode-users] Geonode - Error on uploading layer
Francesco Bartoli xbartolone at gmail.com
Fri Apr 21 03:54:33 PDT 2017
Giuseppe,
Please review all the updated configurations of the workshop. They are fully working now. In case try to restart the vagrant vm from scratch.
Thanks,
Francesco
21 apr 2017, 12:18 +0200, giuseppe musumeci <musumeci.giuseppe at gmail.com>, ha scritto:
> Hi francesco.
> I'm having problem with this configuration.
> 1.from geoserver if i want a preview I get this error:
> Impossibile trovare la pagina localhost
> Nessuna pagina web trovata per l'indirizzo web:http://localhost/geoserver/geonode/wms?service=WMS&version=1.1.0&request=GetMap&layers=geonode:comunidart&styles=&bbox=1553666.125,4677093.5,1772807.875,4926024.5&width=676&height=768&srs=EPSG:3003&format=application/openlayers
> HTTP ERROR 404
> 2. pOSTGRESQL
> i'M UNABLE TO CONNECT PGADMIN RUNNING IN WINDOWS TO GEONODE DATABASE RUNNING IN vm
> i'VE SPENT LAST TWO DAYS
> 2017-04-21 0:07 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com (mailto:xbartolone at gmail.com)>:
> > Hi Giuseppe,
> > I have to adjust my previous hints. To recap the required configurations for geoserver are:
> > /usr/share/geoserver/data/security/role/geonode\ REST\ role\ service/config.
> > <baseUrl>http://localhost:80/</baseUrl>
> > /usr/share/geoserver/data/security/filter/geonode-oauth2/config.xml
> > <accessTokenUri>http://localhost/o/token/</accessTokenUri>
> > <userAuthorizationUri>http://localhost:8001/o/authorize/</userAuthorizationUri>
> > <redirectUri>http://localhost:8001/geoserver</redirectUri>
> > <checkTokenEndpointUrl>http://localhost/api/o/v4/tokeninfo/</checkTokenEndpointUrl>
> > <logoutUri>http://localhost:8001/account/logout/</logoutUri>
> > /usr/share/geoserver/data/security/auth/geonodeAuthProvider/config.xml
> > <baseUrl>http://localhost:8001/</baseUrl>
> > /usr/share/geoserver/data/global.xml
> > <proxyBaseUrl>http://localhost:80/geoserver</proxyBaseUrl>
> > I have updated the workshop, also figuring out that this configuration is a GeoNode full proxied use case where the internal port 8080 is not forwarded to the host machine.
> > Thanks for reporting your initial issues.
> > Hope this definitively clarifies,
> > Francesco
> > Il giorno 12/apr/2017, alle ore 21:34, giuseppe musumeci <musumeci.giuseppe at gmail.com (mailto:musumeci.giuseppe at gmail.com)> ha scritto:
> > > Leaving <proxyBaseUrl> unaltered. I'm able to load layer but I'm not able to preview it in geoserver:
> > > The port changes from 8001 to 8080 and I have the error
> > > "The requested URL /geoserver/geonode/wms was not found on this server."
> > > 2017-04-11 12:28 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com (mailto:xbartolone at gmail.com)>:
> > > > Thanks Simone you are right. I will update the slide, it was my fault.
> > > > @Giuseppe you have to leave <proxyBaseUrl> unaltered.
> > > > Sent from Nylas Pro (https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-070d2acb-91ee/0?redirect=https%3A%2F%2Fnylas.com%2Fnylas-pro%3Fref%3Dn1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t), the most powerful email app for work
> > > > On apr 11 2017, at 7:23 am, Simone Dalmasso <simone.dalmasso at gmail.com (mailto:simone.dalmasso at gmail.com)> wrote:
> > > > > Dears, just a not.
> > > > > In the vagrant installation we made at the workshop, there's no need to forward geoserver to the host as the apache proxy will take care of serving under localhost:8001/geoserver.
> > > > > Best
> > > > > 2017-04-10 23:35 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com (mailto:xbartolone at gmail.com)>:
> > > > > > See inline
> > > > > > Il giorno 10/apr/2017, alle ore 21:14, giuseppe musumeci <musumeci.giuseppe at gmail.com (mailto:musumeci.giuseppe at gmail.com)> ha scritto:
> > > > > > > I followed your instructions.
> > > > > > > There are few differences:
> > > > > > > in order the system works I must set
> > > > > > > <proxyBaseUrl>http://localhost:8001/geoserver (http://localhost:8001/geoserver&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t) /</proxyBaseUrl>
> > > > > > > instead of
> > > > > > > <proxyBaseUrl>http://localhost:8001/ (http://localhost:8001/&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t) /</proxyBaseUrl>
> > > > > > This is not required if the settings are configured fine. During an installation with apt-get this is done automatically while executing the command geonode-updateip
> > > > > > > I cannot edit vagrant file with config.vm.network "forwarded_port", guest: 8080, host: 8080
> > > > > > > infact I get the error
> > > > > > > "Vagrant cannot forward the specified ports on this VM, since they would collide with some other application that is already listening on these ports. The forwarded port to 8080 is already in use on the host machine.”
> > > > > > You have another process which is running on port 8080 in your host machine. Please shutdown that.
> > > > > > > If I try to upload a layer I get this error [Errno 111] Connection refused
> > > > > > > but if I access geoserver on http://localhost:8001/geoserver/web (http://localhost:8001/geoserver/web&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t)
> > > > > > Apparently some geoserver configurations in your settings are still wrong. Are you sure you started a new installation after a vagrant destroy?
> > > > > > > I see that layers have been uploaded into geoserver.
> > > > > > > Nevethless If I watch into geonode I see that "No content created yet"
> > > > > > > 2017-04-10 16:09 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com (mailto:xbartolone at gmail.com)>:
> > > > > > > > If you have run “sudo geonode-updateip localhost:8001” then the next thing to do is to check again the configuration of geoserver in settings file and for the security in the data directory.
> > > > > > > > Il giorno 10/apr/2017, alle ore 16:05, giuseppe musumeci <musumeci.giuseppe at gmail.com (mailto:musumeci.giuseppe at gmail.com)> ha scritto:
> > > > > > > > > I've already done it in this attempt
> > > > > > > > > Il 10/apr/2017 16:02, "Francesco Bartoli" <xbartolone at gmail.com (mailto:xbartolone at gmail.com)> ha scritto:
> > > > > > > > > > Can you please repeat all the commands from scratch? You can do it by running “vagrant destroy”
> > > > > > > > > > Il giorno 10/apr/2017, alle ore 15:46, giuseppe musumeci <musumeci.giuseppe at gmail.com (mailto:musumeci.giuseppe at gmail.com)> ha scritto:
> > > > > > > > > > > I installed again geonode according the tutorial
> > > > > > > > > > > I run the command geonode-updateip
> > > > > > > > > > > I have problem to load layers:[Errno 111] Connection refused
> > > > > > > > > > > Where I'm wrong?
> > > > > > > > > > > 2017-04-10 14:43 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com (mailto:xbartolone at gmail.com)>:
> > > > > > > > > > > > Yes, absolutely. It looks like you missed this one http://geonode.org/geonode-workshop/foss4git2017/#/4/6 (http://geonode.org/geonode-workshop/foss4git2017/#/4/6&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t)
> > > > > > > > > > > > Il giorno 10/apr/2017, alle ore 14:39, giuseppe musumeci <musumeci.giuseppe at gmail.com (mailto:musumeci.giuseppe at gmail.com)> ha scritto:
> > > > > > > > > > > > > I followed all the istructions in the tutorial you send me.
> > > > > > > > > > > > > Is there a way to correct these errors using a command (i.e sudo geonode-updateip localhost:8001)?
> > > > > > > > > > > > > 2017-04-10 14:33 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com (mailto:xbartolone at gmail.com)>:
> > > > > > > > > > > > > > How did you perform the installation?
> > > > > > > > > > > > > > You were originally receive that error because GEOSERVER_PUBLIC_LOCATION is wrong. It should be:
> > > > > > > > > > > > > > 'http://localhost:8001/geoserver' (http://localhost:8001/geoserver&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t')
> > > > > > > > > > > > > > Il giorno 10/apr/2017, alle ore 13:44, giuseppe musumeci <musumeci.giuseppe at gmail.com (mailto:musumeci.giuseppe at gmail.com)> ha scritto:
> > > > > > > > > > > > > > > From /usr/local/lib/python2.7/dist-packages/geonode/settings.py
> > > > > > > > > > > > > > > GEOSERVER_LOCATION = os.getenv(
> > > > > > > > > > > > > > > 'GEOSERVER_LOCATION', 'http://localhost:8080/geoserver/ (http://localhost:8080/geoserver/&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t)'
> > > > > > > > > > > > > > > GEOSERVER_PUBLIC_LOCATION = os.getenv(
> > > > > > > > > > > > > > > 'GEOSERVER_PUBLIC_LOCATION', 'http://localhost:8080/geoserver/ (http://localhost:8080/geoserver/&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t)'
> > > > > > > > > > > > > > > From /etc/geonode/local_settings.py
> > > > > > > > > > > > > > > GEOSERVER_URL = SITEURL + 'geoserver/'
> > > > > > > > > > > > > > > 2017-04-10 13:31 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com (mailto:xbartolone at gmail.com)>:
> > > > > > > > > > > > > > > > Can you double check what you have in the settings for the geoserver configurations?
> > > > > > > > > > > > > > > > Sent from Nylas Pro (https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-677d8377-2abb/0?redirect=https%3A%2F%2Fnylas.com%2Fnylas-pro%3Fref%3Dn1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t), the most powerful email app for work
> > > > > > > > > > > > > > > > On apr 10 2017, at 1:28 pm, giuseppe musumeci <musumeci.giuseppe at gmail.com (mailto:musumeci.giuseppe at gmail.com)> wrote:
> > > > > > > > > > > > > > > > > Dear Francesco,
> > > > > > > > > > > > > > > > > I followed the tutorial
> > > > > > > > > > > > > > > > > I need to set <proxyBaseUrl>http://localhost:8001/geoserver/ (http://localhost:8080/geoserver/&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t)</proxyBaseUrl>
> > > > > > > > > > > > > > > > > and not <proxyBaseUrl>http://localhost:8001/ (http://localhost:8080/geoserver/&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t)</proxyBaseUrl>
> > > > > > > > > > > > > > > > > In this way geoserver seems to work fine.
> > > > > > > > > > > > > > > > > The problem is I'm not able to upload layers from geonode menu
> > > > > > > > > > > > > > > > > 2017-04-10 13:18 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com (mailto:xbartolone at gmail.com)>:
> > > > > > > > > > > > > > > > > > Giuseppe,
> > > > > > > > > > > > > > > > > > if you set "<proxyBaseUrl>http://localhost:8080/geoserver/ (http://localhost:8080/geoserver/&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t)</proxyBaseUrl>" then you have to make that url reachable from your host. That means
> > > > > > > > > > > > > > > > > > the configuration "config.vm.network (https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-eec0852c-64f5/0?redirect=config.vm.network&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t) "forwarded_port", guest: 8080, host: 8080” is required otherwise you get the 404 error.
> > > > > > > > > > > > > > > > > > Il giorno 10/apr/2017, alle ore 11:18, giuseppe musumeci <musumeci.giuseppe at gmail.com (mailto:musumeci.giuseppe at gmail.com)> ha scritto:
> > > > > > > > > > > > > > > > > > > To be able to upload layers I must set
> > > > > > > > > > > > > > > > > > > into usr/share/geoserver/data/global.xml
> > > > > > > > > > > > > > > > > > > If I open geoserver from the admin panel the address is
> > > > > > > > > > > > > > > > > > > http://localhost:8001/geoserver/web/?1 (http://localhost:8001/geoserver/web/?1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t)
> > > > > > > > > > > > > > > > > > > but If i want for example a layer preview
> > > > > > > > > > > > > > > > > > > address change to
> > > > > > > > > > > > > > > > > > > http://localhost:8080/geoserver/geonode/wms?access_token=h4oWfeewhIhMk1aNWvm4nmXSG1QSO1%3Fservice%3DWMS/kml?layers=geonode:fiora_amianto (http://localhost:8080/geoserver/geonode/wms?access_token=h4oWfeewhIhMk1aNWvm4nmXSG1QSO1%3Fservice%3DWMS/kml?layers=geonode:fiora_amianto&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t)
> > > > > > > > > > > > > > > > > > > with error The requested URL /geoserver/geonode/wms was not found on this server.
> > > > > > > > > > > > > > > > > > > 2017-04-10 10:58 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com (mailto:xbartolone at gmail.com)>:
> > > > > > > > > > > > > > > > > > > > is simply redundant. It has been added to access geoserver out of the scope of oauth2.
> > > > > > > > > > > > > > > > > > > > What url are you going to call in the browser for geoserver?
> > > > > > > > > > > > > > > > > > > > Sent from Nylas Pro (https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-eec0852c-64f5/1?redirect=https%3A%2F%2Fnylas.com%2Fnylas-pro%3Fref%3Dn1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t), the most powerful email app for work
> > > > > > > > > > > > > > > > > > > > On apr 10 2017, at 10:49 am, giuseppe musumeci <musumeci.giuseppe at gmail.com (mailto:musumeci.giuseppe at gmail.com)> wrote:
> > > > > > > > > > > > > > > > > > > > > I ran the installation of Geonode using the instructions at the link http://geonode.org/geonode-workshop/foss4git2017/#/4/2 (http://geonode.org/geonode-workshop/foss4git2017/#/4/2&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t)
> > > > > > > > > > > > > > > > > > > > > I think there are problems in the instructions about geoserver configuration:
> > > > > > > > > > > > > > > > > > > > > $ Sudo vi usr / share / geoserver / data / global.xml
> > > > > > > > > > > > > > > > > > > > > I changed the default settings with those specified:
> > > > > > > > > > > > > > > > > > > > > <ProxyBaseUrl> http: // localhost: 8001 / </ proxyBaseUrl>
> > > > > > > > > > > > > > > > > > > > > But geoserver don't works: I then set the value to
> > > > > > > > > > > > > > > > > > > > > moreover i Think that to configure vagrantfile as suggested:
> > > > > > > > > > > > > > > > > > > > > is not correct.
> > > > > > > > > > > > > > > > > > > > > Could someone tell me the correct settings values for geoserver and vagrantfile?
> > > > > > > > > > > > > > > > > > > > > 2017-04-06 14:40 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com (mailto:xbartolone at gmail.com)>:
> > > > > > > > > > > > > > > > > > > > > > Dear Giuseppe,
> > > > > > > > > > > > > > > > > > > > > > as already replied on the italian gfoss list you should check to follow from scratch the workshop http://geonode.org/geonode-workshop/foss4git2017/#/4/2 (http://geonode.org/geonode-workshop/foss4git2017/#/4/2&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t) we did during foss4g-it. If the error is still happening please let me know as probably in this case the beta release is also affected and you can help us with your feedback.
> > > > > > > > > > > > > > > > > > > > > > Thanks,
> > > > > > > > > > > > > > > > > > > > > > Francesco
> > > > > > > > > > > > > > > > > > > > > > Il giorno 06/apr/2017, alle ore 14:12, giuseppe musumeci <musumeci.giuseppe at gmail.com (mailto:musumeci.giuseppe at gmail.com)> ha scritto:
> > > > > > > > > > > > > > > > > > > > > > > Dear list I'm working with Geonode that I installed on a VM set via Vagrant When I try to load the shape file, I get this error: failed to create /var/www/vagrant-ubuntu-trusty-64.MainThread-3777 In the Apache error log is as follows: ERROR: geonode.layers.views: failed to create /var/www/vagrant-ubuntu-trusty-64.Dummy-2-3778 Trying to google around I found that in the settings.py file should add the line: NOTIFICATION_LOCK_LOCATION = '/ var / www / geonode' Finally I verified that the www-data user has all permissions on the www / folder geonode drwxr-xr-x 5 www-data root March 21 4096 14:27 geonode The fact remains that I can't upload. Does anyone know help me?
> > > > > > > > > > > > > > > > > > > > > > > _______________________________________________
> > > > > > > > > > > > > > > > > > > > > > > geonode-users mailing list
> > > > > > > > > > > > > > > > > > > > > > > geonode-users at lists.osgeo.org (mailto:geonode-users at lists.osgeo.org)
> > > > > > > > > > > > > > > > > > > > > > > https://lists.osgeo.org/mailman/listinfo/geonode-users (https://lists.osgeo.org/mailman/listinfo/geonode-users&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t)
> > > > > > https://lists.osgeo.org/mailman/listinfo/geonode-users (https://lists.osgeo.org/mailman/listinfo/geonode-users&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t)
> > > > > Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170421/5b42b604/attachment-0001.html>
More information about the geonode-users mailing list
