[GeoNode-users] Geonode - Error on uploading layer
    giuseppe musumeci
    musumeci.giuseppe at gmail.com
    Sat Apr 22 05:59:39 PDT 2017
I checked all steps of your tutorial. I have yet the errors I posted in the
last mail.
2017-04-21 12:54 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
> Giuseppe,
> Please review all the updated configurations of the workshop. They are
> fully working now. In case try to restart the vagrant vm from scratch.
> Thanks,
> Francesco
> 21 apr 2017, 12:18 +0200, giuseppe musumeci <musumeci.giuseppe at gmail.com>,
> ha scritto:
> Hi francesco.
> I'm having problem with this configuration.
> 1.from geoserver if i want a preview I get this error:
> Impossibile trovare la pagina localhost
> Nessuna pagina web trovata per l'indirizzo web:*http://localhost/geoserver/geonode/wms?service=WMS&version=1.1.0&request=GetMap&layers=geonode:comunidart&styles=&bbox=1553666.125,4677093.5,1772807.875,4926024.5&width=676&height=768&srs=EPSG:3003&format=application/openlayers
> <http://localhost/geoserver/geonode/wms?service=WMS&version=1.1.0&request=GetMap&layers=geonode:comunidart&styles=&bbox=1553666.125,4677093.5,1772807.875,4926024.5&width=676&height=768&srs=EPSG:3003&format=application/openlayers>*
> HTTP ERROR 404
> 2. pOSTGRESQL
> i'M UNABLE TO CONNECT PGADMIN RUNNING IN WINDOWS TO GEONODE DATABASE
> RUNNING IN vm
> i'VE SPENT LAST TWO DAYS
> 2017-04-21 0:07 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>> Hi Giuseppe,
>> I have to adjust my previous hints. To recap the required configurations
>> for geoserver are:
>> /usr/share/geoserver/data/security/role/geonode\ REST\ role\ service/config.
>> <baseUrl>http://localhost:80/</baseUrl>
>> /usr/share/geoserver/data/security/filter/geonode-oauth2/config.xml
>> <accessTokenUri>http://localhost/o/token/</accessTokenUri>
>> <userAuthorizationUri>http://localhost:8001/o/authorize/</userAuthorizationUri>
>> <redirectUri>http://localhost:8001/geoserver</redirectUri>
>> <checkTokenEndpointUrl>http://localhost/api/o/v4/tokeninfo/</checkTokenEndpointUrl>
>> <logoutUri>http://localhost:8001/account/logout/</logoutUri>
>> /usr/share/geoserver/data/security/auth/geonodeAuthProvider/config.xml
>> <baseUrl>http://localhost:8001/</baseUrl>
>> /usr/share/geoserver/data/global.xml
>> <proxyBaseUrl>http://localhost:80/geoserver</proxyBaseUrl>
>> I have updated the workshop, also figuring out that this configuration is
>> a GeoNode full proxied use case where the internal port 8080 is not
>> forwarded to the host machine.
>> Thanks for reporting your initial issues.
>> Hope this definitively clarifies,
>> Francesco
>> Il giorno 12/apr/2017, alle ore 21:34, giuseppe musumeci <
>> musumeci.giuseppe at gmail.com> ha scritto:
>> Leaving <proxyBaseUrl> unaltered. I'm able to load layer but I'm not
>> able to preview it in geoserver:
>> The port changes from 8001 to 8080 and I have the error
>>  "The requested URL /geoserver/geonode/wms was not found on this server."
>> 2017-04-11 12:28 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>> Thanks Simone you are right. I will update the slide, it was my fault.
>>>  @Giuseppe you have to leave <proxyBaseUrl> unaltered.
>>> Sent from Nylas Pro
>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-070d2acb-91ee/0?redirect=https%3A%2F%2Fnylas.com%2Fnylas-pro%3Fref%3Dn1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>,
>>> the most powerful email app for work
>>> On apr 11 2017, at 7:23 am, Simone Dalmasso <simone.dalmasso at gmail.com>
>>> wrote:
>>>> Dears, just a not.
>>>> In the vagrant installation we made at the workshop, there's no need to
>>>> forward geoserver to the host as the apache proxy will take care of serving
>>>> under localhost:8001/geoserver.
>>>> Best
>>>> 2017-04-10 23:35 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>> See inline
>>>> Il giorno 10/apr/2017, alle ore 21:14, giuseppe musumeci <
>>>> I followed your instructions.
>>>> There are few differences:
>>>> in order the system works I must set
>>>> *<proxyBaseUrl>http://localhost:8001/geoserver
>>>> <http://localhost:8001/geoserver&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>> /</proxyBaseUrl>*
>>>> instead of
>>>> <http://localhost:8001/&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>> /</proxyBaseUrl>*
>>>> This is not required if the settings are configured fine. During an
>>>> installation with apt-get this is done automatically while executing the
>>>> command geonode-updateip
>>>> I cannot edit vagrant file with *config.vm.network "forwarded_port",
>>>> guest: 8080, host:* *8080*
>>>> infact I get the error
>>>> "Vagrant cannot forward the specified ports on this VM, since they
>>>> would collide with some other application that is already listening on
>>>> these ports. The forwarded port to 8080 is already in use on the host
>>>> machine.”
>>>> You have another process which is running on port 8080 in your host
>>>> machine. Please shutdown that.
>>>> If I try to upload a layer I get this error [Errno 111] Connection
>>>> refused
>>>> but if I access geoserver on http://localhost:8001/geoserver/web
>>>> <http://localhost:8001/geoserver/web&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>> Apparently some geoserver configurations in your settings are still
>>>> wrong. Are you sure you started a new installation after a vagrant destroy?
>>>> I see that layers have been uploaded into geoserver.
>>>> Nevethless If I watch into geonode I see that "No content created yet"
>>>> 2017-04-10 16:09 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>> If you have run “sudo geonode-updateip localhost:8001” then the next
>>>> thing to do is to check again the configuration of geoserver in settings
>>>> file and for the security in the data directory.
>>>> Il giorno 10/apr/2017, alle ore 16:05, giuseppe musumeci <
>>>> I've already done it in this attempt
>>>> Il 10/apr/2017 16:02, "Francesco Bartoli" <xbartolone at gmail.com> ha
>>>> scritto:
>>>> Can you please repeat all the commands from scratch? You can do it by
>>>> running “vagrant destroy”
>>>> Il giorno 10/apr/2017, alle ore 15:46, giuseppe musumeci <
>>>> I installed again geonode according the tutorial
>>>> I run the command geonode-updateip
>>>> I have problem to load layers:[Errno 111] Connection refused
>>>> Where I'm wrong?
>>>> 2017-04-10 14:43 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>> Yes, absolutely. It looks like you missed this one
>>>> http://geonode.org/geonode-workshop/foss4git2017/#/4/6
>>>> <http://geonode.org/geonode-workshop/foss4git2017/#/4/6&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>> Il giorno 10/apr/2017, alle ore 14:39, giuseppe musumeci <
>>>> I followed all the istructions in the tutorial you send me.
>>>> Is there a way to correct these errors using a command (i.e sudo
>>>> geonode-updateip localhost:8001)?
>>>> 2017-04-10 14:33 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>> How did you perform the installation?
>>>> You were originally receive that error because
>>>> GEOSERVER_PUBLIC_LOCATION is wrong. It should be:
>>>> 'http://localhost:8001/geoserver'
>>>> <http://localhost:8001/geoserver&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t'>
>>>> Il giorno 10/apr/2017, alle ore 13:44, giuseppe musumeci <
>>>> From /usr/local/lib/python2.7/dist-packages/geonode/settings.py
>>>> GEOSERVER_LOCATION = os.getenv(
>>>>     'GEOSERVER_LOCATION', 'http://localhost:8080/geoserver/
>>>> <http://localhost:8080/geoserver/&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>> GEOSERVER_PUBLIC_LOCATION = os.getenv(
>>>>     'GEOSERVER_PUBLIC_LOCATION', 'http://localhost:8080/geoserver/
>>>> From /etc/geonode/local_settings.py
>>>> GEOSERVER_URL = SITEURL + 'geoserver/'
>>>> 2017-04-10 13:31 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>> Can you double check what you have in the settings for the
>>>> geoserver configurations?
>>>> Sent from Nylas Pro
>>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-677d8377-2abb/0?redirect=https%3A%2F%2Fnylas.com%2Fnylas-pro%3Fref%3Dn1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>,
>>>> On apr 10 2017, at 1:28 pm, giuseppe musumeci <
>>>> musumeci.giuseppe at gmail.com> wrote:
>>>> Dear Francesco,
>>>> I followed the tutorial
>>>> I need to set <proxyBaseUrl>http://localhost:8001/geoserver/
>>>> <http://localhost:8080/geoserver/&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>> </proxyBaseUrl>
>>>> and not <proxyBaseUrl>http://localhost:8001/
>>>> </proxyBaseUrl>
>>>> In this way geoserver seems to work fine.
>>>> The problem is I'm not able to upload layers from geonode menu
>>>> 2017-04-10 13:18 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>> Giuseppe,
>>>> if you set "<proxyBaseUrl>http://localhost:8080/geoserver/
>>>> </proxyBaseUrl>" then you have to make that url reachable from your
>>>> host. That means
>>>> the configuration "config.vm.network
>>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-eec0852c-64f5/0?redirect=config.vm.network&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>>  "forwarded_port", guest: 8080, host: 8080” is required otherwise you
>>>> get the 404 error.
>>>> Il giorno 10/apr/2017, alle ore 11:18, giuseppe musumeci <
>>>> To be able to upload layers I must set
>>>> </proxyBaseUrl>
>>>> into usr/share/geoserver/data/global.xml
>>>> If I open geoserver from the admin panel the address is
>>>> http://localhost:8001/geoserver/web/?1
>>>> <http://localhost:8001/geoserver/web/?1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>> but If i want for example a layer preview
>>>> address change to
>>>> http://localhost:8080/geoserver/geonode/wms?access_token=h4o
>>>> WfeewhIhMk1aNWvm4nmXSG1QSO1%3Fservice%3DWMS/kml?layers=geono
>>>> de:fiora_amianto
>>>> <http://localhost:8080/geoserver/geonode/wms?access_token=h4oWfeewhIhMk1aNWvm4nmXSG1QSO1%3Fservice%3DWMS/kml?layers=geonode:fiora_amianto&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>> with error The requested URL /geoserver/geonode/wms was not found on
>>>> this server.
>>>> 2017-04-10 10:58 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>> config.vm.network
>>>> is simply redundant. It has been added to access geoserver out of the
>>>> scope of oauth2.
>>>> What url are you going to call in the browser for geoserver?
>>>> Sent from Nylas Pro
>>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-eec0852c-64f5/1?redirect=https%3A%2F%2Fnylas.com%2Fnylas-pro%3Fref%3Dn1&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>,
>>>> On apr 10 2017, at 10:49 am, giuseppe musumeci <
>>>> I ran the installation of Geonode using the instructions at the link
>>>> http://geonode.org/geonode-workshop/foss4git2017/#/4/2
>>>> <http://geonode.org/geonode-workshop/foss4git2017/#/4/2&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>> I think there are problems in the instructions about geoserver
>>>> configuration:
>>>> $ Sudo vi usr / share / geoserver / data / global.xml
>>>> I changed the default settings with those specified:
>>>> <ProxyBaseUrl> http: // localhost: 8001 / </ proxyBaseUrl>
>>>> But geoserver don't works: I then set the value to
>>>> moreover i Think that to configure vagrantfile as suggested:
>>>> config.vm.network "forwarded_port", guest: 8080, host: 8080
>>>> is not correct.
>>>> Could someone tell me the correct settings values for geoserver and
>>>> vagrantfile?
>>>> 2017-04-06 14:40 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>> Dear Giuseppe,
>>>> as already replied on the italian gfoss list you should check to follow
>>>> from scratch the workshop http://geonode.org/ge
>>>> <http://geonode.org/geonode-workshop/foss4git2017/#/4/2&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t> we
>>>> did during foss4g-it. If the error is still happening please let me know as
>>>> probably in this case the beta release is also affected and you can help us
>>>> with your feedback.
>>>> Thanks,
>>>> Francesco
>>>> Il giorno 06/apr/2017, alle ore 14:12, giuseppe musumeci <
>>>> Dear list I'm working with Geonode that I installed on a VM set via
>>>> Vagrant When I try to load the shape file, I get this error: *failed
>>>> to create /var/www/vagrant-ubuntu-trusty-64.MainThread-3777* In the
>>>> Apache error log is as follows: *ERROR: geonode.layers.views: failed
>>>> to create /var/www/vagrant-ubuntu-trusty-64.Dummy-2-3778* Trying to
>>>> google around I found that in the settings.py file should add the line:
>>>> NOTIFICATION_LOCK_LOCATION = '/ var / www / geonode' Finally I verified
>>>> that the www-data user has all permissions on the www / folder geonode
>>>> drwxr-xr-x 5 www-data root March 21 4096 14:27 geonode The fact remains
>>>> that I can't upload. Does anyone know help me?
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>> <https://lists.osgeo.org/mailman/listinfo/geonode-users&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>> <https://lists.osgeo.org/mailman/listinfo/geonode-users&r=bXVzdW1lY2kuZ2l1c2VwcGVAZ21haWwuY29t>
>>>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170422/7940e455/attachment-0001.html>
More information about the geonode-users
