[GeoNode-users] Geonode 2.6 on ubuntu 14.04
Allan Oware allanoware at gmail.com
Tue Apr 25 06:27:53 PDT 2017
I successfully installed geonode 2.6 on ubuntu 16.04. Am curious if its
possible to run the latest geonode release on ubuntu 14.04 without
upgrading to 16.04
On Tue, Apr 25, 2017 at 4:02 PM, Francesco Bartoli <xbartolone at gmail.com>
wrote:
> Can you try with a clean 16.04?
> Il giorno 25/apr/2017, alle ore 12:58, Allan Oware <allanoware at gmail.com>
> ha scritto:
> On a clean ubuntu 14.04.5
> $ sudo add-apt-repository ppa:geonode/testing
> $ sudo apt-get update
> $ sudo apt-get install geonode
> Reading package lists... Done
> Building dependency tree
> Reading state information... Done
> Some packages could not be installed. This may mean that you have
> requested an impossible situation or if you are using the unstable
> distribution that some required packages have not yet been created
> or been moved out of Incoming.
> The following information may help to resolve the situation:
> The following packages have unmet dependencies:
>  geonode : Depends: python-geonode-dialogos but it is not installable
>            Depends: python-django-activity-stream but it is not installable
>            Depends: python-django-forms-bootstrap but it is not installable
>            Depends: python-geonode-user-accounts but it is not going to be
> installed
>            Depends: python-geonode-user-messages but it is not installable
>            Depends: python-pinax-theme-bootstrap but it is not going to be
> installed
>            Depends: python-pinax-theme-bootstrap-account but it is not
> going to be installed
>            Depends: python-django-tastypie but it is not installable
>            Depends: python-django-autocomplete-light but it is not
> installable
>            Depends: python-django-bootstrap3-datetimepicker but it is not
> installable
>            Depends: python-awesome-slugify but it is not installable
>            Depends: python-dj-database-url but it is not installable
>            Depends: python-django-storages but it is not installable
>            Depends: python-django-oauth-toolkit but it is not installable
>            Recommends: transifex-client but it is not going to be installed
> E: Unable to correct problems, you have held broken packages.
> On Tue, Apr 25, 2017 at 12:32 PM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> Yes the package is for 14.04 what error did you get?
>> Il giorno lun 24 apr 2017 alle 21:44 Allan Oware <allanoware at gmail.com>
>> ha scritto:
>>> Hi,
>>> Am curious whether its possible to install geonode 2.6 candidate
>>> releases on ubuntu 14.04 ? I tried adding geonode/testing to my ubuntu
>>> 14.04 apt-get list but couldnt install.
>>> Allan Oware
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> Simone
> Allan Oware
Allan Oware
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170425/bbf76332/attachment.html>
More information about the geonode-users mailing list
