[GeoNode-users] Geonode 2.6 on ubuntu 14.04
Simone Dalmasso
simone.dalmasso at gmail.com
Tue Apr 25 08:00:33 PDT 2017
Sorry, it was my fault the 16.04 is the one supported by the package. You
can although install it on 14.04 but you have to follow the manual
installation.
2017-04-25 15:27 GMT+02:00 Allan Oware <allanoware at gmail.com>:
> I successfully installed geonode 2.6 on ubuntu 16.04. Am curious if its
> possible to run the latest geonode release on ubuntu 14.04 without
> upgrading to 16.04
> On Tue, Apr 25, 2017 at 4:02 PM, Francesco Bartoli <xbartolone at gmail.com>
> wrote:
>> Can you try with a clean 16.04?
>> Il giorno 25/apr/2017, alle ore 12:58, Allan Oware <allanoware at gmail.com>
>> ha scritto:
>> On a clean ubuntu 14.04.5
>> $ sudo add-apt-repository ppa:geonode/testing
>> $ sudo apt-get update
>> $ sudo apt-get install geonode
>> Reading package lists... Done
>> Building dependency tree
>> Reading state information... Done
>> Some packages could not be installed. This may mean that you have
>> requested an impossible situation or if you are using the unstable
>> distribution that some required packages have not yet been created
>> or been moved out of Incoming.
>> The following information may help to resolve the situation:
>> The following packages have unmet dependencies:
>> geonode : Depends: python-geonode-dialogos but it is not installable
>> Depends: python-django-activity-stream but it is not
>> installable
>> Depends: python-django-forms-bootstrap but it is not
>> installable
>> Depends: python-geonode-user-accounts but it is not going to
>> be installed
>> Depends: python-geonode-user-messages but it is not installable
>> Depends: python-pinax-theme-bootstrap but it is not going to
>> be installed
>> Depends: python-pinax-theme-bootstrap-account but it is not
>> going to be installed
>> Depends: python-django-tastypie but it is not installable
>> Depends: python-django-autocomplete-light but it is not
>> installable
>> Depends: python-django-bootstrap3-datetimepicker but it is
>> not installable
>> Depends: python-awesome-slugify but it is not installable
>> Depends: python-dj-database-url but it is not installable
>> Depends: python-django-storages but it is not installable
>> Depends: python-django-oauth-toolkit but it is not installable
>> Recommends: transifex-client but it is not going to be
>> installed
>> E: Unable to correct problems, you have held broken packages.
>> On Tue, Apr 25, 2017 at 12:32 PM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> Yes the package is for 14.04 what error did you get?
>>> Il giorno lun 24 apr 2017 alle 21:44 Allan Oware <allanoware at gmail.com>
>>> ha scritto:
>>>> Hi,
>>>> Am curious whether its possible to install geonode 2.6 candidate
>>>> releases on ubuntu 14.04 ? I tried adding geonode/testing to my ubuntu
>>>> 14.04 apt-get list but couldnt install.
>>>> Allan Oware
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> Simone
>> Allan Oware
> Allan Oware
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170425/44411190/attachment.html>
More information about the geonode-users
