[GeoNode-users] ERROR:An error occurred in the current transaction. You can't execute queries until the end of the 'atomic' block.
Ariel Neri
ariel.neriw at gmail.com
Wed Aug 2 12:27:58 PDT 2017
Hi, I had this error while running "updatelayers" command (only if there
are layers from remote-store in geoserver)
And some users reported to have same error while uploading or deleting
layers.
Here´s the traceback:
TransactionManagementError at /admin/layers/layer/
Request Method: POST
Request URL: http://192.168.0.56/admin/layers/layer/
Django Version: 1.8.7
Exception Type: TransactionManagementError
Exception Value:
Exception Location:
/usr/local/lib/python2.7/dist-packages/django/db/backends/base/base.py
in validate_no_broken_transaction, line 327
Python Executable: /usr/bin/python
Python Version: 2.7.12
Python Path:
['/home/geonode/my_geonode',
'/usr/lib/python2.7',
'/usr/lib/python2.7/plat-x86_64-linux-gnu',
'/usr/lib/python2.7/lib-tk',
'/usr/lib/python2.7/lib-old',
'/usr/lib/python2.7/lib-dynload',
'/usr/local/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages/PILcompat',
'/var/www']
Server time: Mié, 2 Ago 2017 14:25:16 -0500
Traceback Switch to copy-and-paste view
<http://192.168.0.56/admin/layers/layer/#>
- /usr/local/lib/python2.7/dist-packages/django/core/handlers/base.py in
get_response
1.
response =
wrapped_callback(request, *callback_args, **callback_kwargs)
▶ Local vars <http://192.168.0.56/admin/layers/layer/#>
- /usr/local/lib/python2.7/dist-packages/django/contrib/admin/options.py
in wrapper
1.
return
self.admin_site.admin_view(view)(*args, **kwargs)
- /usr/local/lib/python2.7/dist-packages/django/utils/decorators.py in
_wrapped_view
1.
response = view_func(request,
*args, **kwargs)
- /usr/local/lib/python2.7/dist-packages/django/views/decorators/cache.py
in _wrapped_view_func
1.
response = view_func(request, *args, **kwargs)
- /usr/local/lib/python2.7/dist-packages/django/contrib/admin/sites.py
in inner
1.
return view(request, *args, **kwargs)
_wrapper
1.
return bound_func(*args, **kwargs)
_wrapped_view
1.
*args, **kwargs)
bound_func
1.
return func.__get__(self,
type(self))(*args2, **kwargs2)
in changelist_view
1.
response =
self.response_action(request, queryset=cl.get_queryset(request))
in response_action
1.
response = func(self, request, queryset)
- /usr/local/lib/python2.7/dist-packages/django/contrib/admin/actions.py
in delete_selected
1.
queryset.delete()
- /usr/local/lib/python2.7/dist-packages/django/db/models/query.py in
delete
1.
collector.delete()
- /usr/local/lib/python2.7/dist-packages/django/db/models/deletion.py in
delete
1.
query.delete_batch(pk_list, self.using)
/usr/local/lib/python2.7/dist-packages/django/db/models/sql/subqueries.py
in delete_batch
1.
self.do_query(self.get_meta().db_table,
self.where, using=using)
in do_query
1.
self.get_compiler(using).execute_sql(NO_RESULTS)
- /usr/local/lib/python2.7/dist-packages/django/db/models/sql/compiler.py
in execute_sql
1.
cursor.execute(sql, params)
- /usr/local/lib/python2.7/dist-packages/django/db/backends/utils.py in
execute
1.
return super(CursorDebugWrapper,
self).execute(sql, params)
execute
1.
self.db.validate_no_broken_transaction()
- /usr/local/lib/python2.7/dist-packages/django/db/backends/base/base.py
1.
if self.in_atomic_block:
2.
raise TransactionManagementError(
3.
"This is forbidden when an 'atomic' block is active.")
4.
5.
def validate_no_broken_transaction(self):
6.
if self.needs_rollback:
7.
1.
"An error occurred in the current
transaction. You can't "
1.
"execute queries until the end of the 'atomic' block.")
2.
3.
# ##### Foreign key constraints checks handling #####
4.
5.
@contextmanager
6.
def constraint_checks_disabled(self):
▼ Local vars <http://192.168.0.56/admin/layers/layer/#>
VariableValue
self
<django.db.backends.postgresql_psycopg2.base.DatabaseWrapper object
at 0x7f5b086ae0d0>
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170802/b8e44c7a/attachment-0001.html>
More information about the geonode-users
