[GeoNode-users] ERROR:An error occurred in the current transaction. You can't execute queries until the end of the 'atomic' block.
Simone Dalmasso simone.dalmasso at gmail.com
Thu Aug 10 00:35:46 PDT 2017
Hi, could you please file a ticket for that?
Looks like a bug.
thanks
2017-08-02 21:27 GMT+02:00 Ariel Neri <ariel.neriw at gmail.com>:
> Hi, I had this error while running "updatelayers" command (only if there
> are layers from remote-store in geoserver)
> And some users reported to have same error while uploading or deleting
> layers.
> Here´s the traceback:
> TransactionManagementError at /admin/layers/layer/
> Request Method: POST
> Request URL: http://192.168.0.56/admin/layers/layer/
> Django Version: 1.8.7
> Exception Type: TransactionManagementError
> Exception Value:
> Exception Location: /usr/local/lib/python2.7/dist-
> packages/django/db/backends/base/base.py in validate_no_broken_transaction,
> line 327
> Python Executable: /usr/bin/python
> Python Version: 2.7.12
> Python Path:
> ['/home/geonode/my_geonode',
>  '/usr/lib/python2.7',
>  '/usr/lib/python2.7/plat-x86_64-linux-gnu',
>  '/usr/lib/python2.7/lib-tk',
>  '/usr/lib/python2.7/lib-old',
>  '/usr/lib/python2.7/lib-dynload',
>  '/usr/local/lib/python2.7/dist-packages',
>  '/usr/lib/python2.7/dist-packages',
>  '/usr/lib/python2.7/dist-packages/PILcompat',
>  '/var/www']
> Server time: Mié, 2 Ago 2017 14:25:16 -0500
> Traceback Switch to copy-and-paste view
> <http://192.168.0.56/admin/layers/layer/#>
>    - /usr/local/lib/python2.7/dist-packages/django/core/handlers/base.py
>     in get_response
>    1.
>                                       response = wrapped_callback(request, *callback_args, **callback_kwargs)
>    ▶ Local vars <http://192.168.0.56/admin/layers/layer/#>
>    - /usr/local/lib/python2.7/dist-packages/django/contrib/admin/
>    options.py in wrapper
>    1.
>                                   return self.admin_site.admin_view(view)(*args, **kwargs)
>    - /usr/local/lib/python2.7/dist-packages/django/utils/decorators.py in
>    _wrapped_view
>    1.
>                                       response = view_func(request, *args, **kwargs)
>    - /usr/local/lib/python2.7/dist-packages/django/views/
>    decorators/cache.py in _wrapped_view_func
>    1.
>    - /usr/local/lib/python2.7/dist-packages/django/contrib/admin/sites.py
>     in inner
>    1.
>                               return view(request, *args, **kwargs)
>    _wrapper
>    1.
>                               return bound_func(*args, **kwargs)
>    _wrapped_view
>    1.
>    bound_func
>    1.
>                                   return func.__get__(self, type(self))(*args2, **kwargs2)
>    options.py in changelist_view
>    1.
>                                   response = self.response_action(request, queryset=cl.get_queryset(request))
>    options.py in response_action
>    1.
>                               response = func(self, request, queryset)
>    actions.py in delete_selected
>    1.
>                               queryset.delete()
>    - /usr/local/lib/python2.7/dist-packages/django/db/models/query.py in
>    delete
>    1.
>                           collector.delete()
>    - /usr/local/lib/python2.7/dist-packages/django/db/models/deletion.py
>     in delete
>    1.
>                                   query.delete_batch(pk_list, self.using)
>    - /usr/local/lib/python2.7/dist-packages/django/db/models/sql/
>    subqueries.py in delete_batch
>    1.
>                               self.do_query(self.get_meta().db_table, self.where, using=using)
>    subqueries.py in do_query
>    1.
>                           self.get_compiler(using).execute_sql(NO_RESULTS)
>    compiler.py in execute_sql
>    1.
>                               cursor.execute(sql, params)
>    - /usr/local/lib/python2.7/dist-packages/django/db/backends/utils.py
>     in execute
>    1.
>                               return super(CursorDebugWrapper, self).execute(sql, params)
>     in execute
>    1.
>                           self.db.validate_no_broken_transaction()
>    1.
>               if self.in_atomic_block:
>       2.
>                   raise TransactionManagementError(
>       3.
>                       "This is forbidden when an 'atomic' block is active.")
>       4.
>       5.
>           def validate_no_broken_transaction(self):
>       6.
>               if self.needs_rollback:
>       7.
>       1.
>                                   "An error occurred in the current transaction. You can't "
>    1.
>                       "execute queries until the end of the 'atomic' block.")
>       2.
>       3.
>           # ##### Foreign key constraints checks handling #####
>       4.
>       5.
>           @contextmanager
>       6.
>           def constraint_checks_disabled(self):
>       ▼ Local vars <http://192.168.0.56/admin/layers/layer/#>
>    VariableValue
>    self
>    <django.db.backends.postgresql_psycopg2.base.DatabaseWrapper object at 0x7f5b086ae0d0>
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170810/351a6a05/attachment-0001.html>
More information about the geonode-users mailing list
