[GeoNode-users] GeoNode depolyment with dominname
Naresh N naresh919 at gmail.com
Thu Aug 10 02:57:00 PDT 2017
Dear Simone,
 Thanks for the response.
Best Regards,
Naresh
On Thu, Aug 10, 2017 at 1:03 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Hi,
> geonode doesn't work well if is not in the root of the domain. The
> recommendation is to keep it under the root and user a virtualhost instead
> (like geonode.example.com/)
> 2017-08-10 9:28 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>> Dear All,
>>  Please suggest for the following query. Sorry to post to this group,
>> since the query is not related to GeoNode software. I felt some users might
>> faced issue and I may get some solution.
>>  I have deployed the GeoNode 2.4 version in RHEL 7.2 64 bit machine. It
>> is working fine. Now we want to make live to public. For this  our network
>> team has given domain name with reverse proxy.
>> For example:   My System IP:  192.168.XXX.XXX
>> Given Domain Name: http://example.com/geonode
>> And they have told that with reverseproxy  when users type
>> http://example.com/geonode will internal redirect to 192.168.XXX.XX
>>  (Geonode depolyed system IP).
>> With the above the GeoNode home page is loading not properly, since  all
>> the static links/jsfiles are not loaded, and I have found that the url is
>> going to http://example.com/*static/lib/css/assets.min.css?v=2.4*
>> when I modified the urr as follows, it is working fine
>> http://example.com/*geonode*/*static/lib/css/assets.min.css?v=2.4*
>> Then I added  in settings.py file static_url=/static/ to
>> url=/geonode/static. The home page loaded properly. However if we click on
>> Layers/Map/documents - those links are going to again
>> http://example.com/layers - where page is not loading.
>> Please suggest
>> Please find below link -  it may be helpful - to give solution to my
>> problme
>> *https://serverfault.com/questions/561892/how-to-handle-relative-urls-correctly-with-a-reverse-proxy
>> <https://serverfault.com/questions/561892/how-to-handle-relative-urls-correctly-with-a-reverse-proxy>*
>> Thanks&Regards,
>> Naersh
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170810/e25edc0a/attachment.html>
More information about the geonode-users mailing list
