[GeoNode-users] Upload layer error on windows
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Aug 25 01:29:11 PDT 2017
Sorry no clues on that issue. It looks to me something related to your
local language. It could be necessary to tweak the Python and JVM options
in order to support encoding.
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Mon, Aug 7, 2017 at 4:14 AM, Andres Juarez <
albertoandres.juarez at gmail.com> wrote:
> Hi again
> Updating information about this problem.
> I've reinstalled Geonode, without uninstalling the existing one, and
> everything went back to working as it did in the beginning.
> Do some actions that I had done, such as modifying the SITE_URL,
> PUBLIC_LOCATION, ALLOWED_HOST, all in the local_settings.
> Also create new users and load new layers from the different profiles, and
> everything works fine.
> The only thing I did not do was configure the geoserver 'URL proxy base'.
> Could this have caused the error?
> regards
> 2017-08-06 17:54 GMT-03:00 Andres Juarez <albertoandres.juarez at gmail.com>:
>> Hello everyone
>> I just installed Geonode 2.4.1 Win 32bit (with the standard installer) on
>> Windows 7 64bit. The installation finished properly and everything worked
>> fine. I managed to load some layers with the admin user but I can not do it
>> again. I created users, managed to load PDF documents, but I can no longer
>> load shapefiles or geoTiff.
>> The layer is loaded into Geoserver (the corresponding style is not
>> generated), but at the end it always returns the error
>> UnicodeDecodeError at / layers / upload 'utf8' codec can not decode byte
>> 0xf3 in position 169: invalid continuation byte
>> And I can see the layer from the Geoserver preview.
>> I have tried changing the encoding of the layer in QGis (to Latin1 and
>> UTF-8), try with several encoding at the time of loading the layer but none
>> worked.
>> Any help will be welcome.
>> Thanks in advance
>> PS: sorry for my English, I used google translate...
>>    Andrés Juarez
>    Andrés Juarez
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170825/7927f481/attachment.html>
More information about the geonode-users mailing list
