[GeoNode-users] question about deleting some service layers.
    Simone Dalmasso
    simone.dalmasso at gmail.com
    Fri Aug 25 04:49:44 PDT 2017
Hi, when registering a new service the layers are created in layers/layer
and the reference for the in the service is in services/servicelayer.
If you delete the latest you will loose their relation to the service, if
you delete them in layers you will loose the entire layer. For the remote
server in the map is different, it is not using the services but only
issuing a getCapabilities, so you will always see al layers there (and you
will always have to add the remote address every time you create a new map)
2017-08-23 19:57 GMT+02:00 Ariel Neri <ariel.neriw at gmail.com>:
> Hi all.
>  I added a new service, which automatically added more than 300 layers to
> my layer list, I only want to keep 10 of them in the list. But keep access
> to all when creating a new map (remote server layers).
> In the Admin UI these layers are found in 2 places: /admin/layers/layer/
> and in /admin/services/servicelayer/
> What would be the diference in deleting from each location?
> Thanks
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170825/470d41c8/attachment.html>
More information about the geonode-users
