[GeoNode-users] Base layer is not visible on thumbnail of the uploaded content
Naresh N
naresh919 at gmail.com
Mon Aug 28 01:49:57 PDT 2017
Dear Jonathan,
Thanks a lot for detailed explanation.
It may be good , this kind of functionality may be implemented in newer
version of GeoNode, since with out base layer the thumbnail does not
looking good, user has to manually set
When we delete the layer/map the corresponding thumbnail is not deleting
from the server. How to delete thumbnails in case of deletion of layers/maps
Thanks&Regards,
Naresh
On Mon, Aug 28, 2017 at 11:04 AM, Jonathan Doig <j.doig at unsw.edu.au> wrote:
> Hi Naresh
> This has been an open issue since 2015. Here is a bit more explanation:
> https://github.com/GeoNode/geonode/issues/2025
> Also some notes from our own user guide:
> - Your browser caches images, so the thumbnail may not appear to
> change. Refresh the page with a ‘hard reload’ (Ctrl + Shift + R on Chrome,
> see instructions
> <https://www.getfilecloud.com/blog/2015/03/tech-tip-how-to-do-hard-refresh-in-browsers> for
> other browsers).
> - Please be patient, as larger datasets may take several minutes to
> display the first time. The system builds a tiled image cache for new
> layers, so subsequent rendering is virtually instantaneous.
> Finally, if all else fails and you have access to the server you can
> create a thumbnail ‘manually’ and FTP it to the uploaded/thumbs folder,
> overwriting the automatically created thumbnail. To find the filename to
> use, right-click the thumbnail and select ‘Copy image address’.
> Regards
> Jonathan
> *From:* geonode-users [mailto:geonode-users-bounces at lists.osgeo.org] *On
> Behalf Of *Naresh N
> *Sent:* Monday, 28 August 2017 2:03 PM
> *To:* Simone Dalmasso <simone.dalmasso at gmail.com>
> *Cc:* geonode-users lists.osgeo.org <geonode-users at lists.osgeo.org>
> *Subject:* Re: [GeoNode-users] Base layer is not visible on thumbnail of
> Dear Simone,
> Thanks a lot for answering my query.
> 1. However in case of Map - Thumbail -- when we publish/save the
> thumbnail is getting generated with the base layer. Please suggest can we
> do modification in code,
> so that when we upload the layer , the thumbnail should be
> generated with the default selected base layer along with the uploaded
> content.
> 2. Even some times when we click on SetThumbnail, the thumbnail is not
> refreshing and if we reload the page or click on the some other links the
> thumbnail get refreshers.
> I thinks there is some time delay or refresh problem. How do we over
> come this issue?
> Thanks&Regards,
> Naresh. N
> On Fri, Aug 25, 2017 at 5:29 PM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
> Hi Naresh, that is not possible. The baselayer can only be visible if the
> client is currently showing a map with it and can send it to the server
> along with the thumbnail request. This is not available on layer upload.
> 2017-08-24 14:03 GMT+02:00 Naresh N <naresh919 at gmail.com>:
> Dear All,
> After uploading the layer, if we click on layers list, the corresponding
> layer thumbnail base layers are not visible. If we click on the
> corresponding Layers --> Edit Layer if we click on Set Thumbnail then
> base layers along with uploaded content is visible in thumbnail
> Please suggest how to include the base layers also in thumbnail on upload
> of spatial data with out manually clicking Set Thumbnail option.
> Thanks&Regards,
> Naresh
> geonode-users mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170828/7b182205/attachment.html>
More information about the geonode-users
