[GeoNode-users] Geonode auth for Geoserver
Francesco Bartoli
xbartolone at gmail.com
Fri Dec 1 07:05:00 PST 2017
Did you try the commands "geonode-updateip <external ip>" to reconfigure the address while “python manage.py updatelayers” and “python manage.py updatemaplayerip” to update layers and maps? In addition the oauth2 configuration should be touched to reconfigure a couple of endpoints as explained here [1] in the paragraph "Setting up OAuth2 configuration"
http://docs.geonode.org/en/master/tutorials/install_and_admin/setup_on_centos/install_geonode.html#initialize-geonode
Hope this helps
Il giorno 01/dic/2017, alle ore 15:37, Corina Tudorache <corina_ww at yahoo.com> ha scritto:
> Hi Francesco,
> I know that the deployment hasn’t any recommendation in term of cloud providers. But with AWS might be a problem configuring GeoNode because of the internal IP that is different than the external IP. With DigitalOcean is easier because the internal IP is the external IP. When trying to conect to geoserver with GeoNode credentials, the url will point to the internal IP, and therefor it will not connect. This is why, I assume, I have problems updating layers from GeoServer in GeoNode in AWS too. I don't have this issue in DigitalOcean.
> Kind regards,
> Corina
> On Friday, December 1, 2017, 2:09:33 PM GMT, Francesco Bartoli <xbartolone at gmail.com> wrote:
> Corina,
> actually the deployment hasn’t any recommendation in term of cloud providers while the preferred OS would be Ubuntu with the ease of available packages even if there are detailed instructions along the documentation to achieve it to CentOS too.
> Furthermore in term of devops there are options to use Ansible with the repo [1] and Docker with images from the docker hub for docker-compose. What’s your bad experience with AWS?
> [1] https://github.com/GeoNode/ansible-geonode
> Il giorno 01/dic/2017, alle ore 14:21, <Stefano.LUONI at ext.ec.europa.eu> <Stefano.LUONI at ext.ec.europa.eu> ha scritto:
> Hi Corina,
> actually I'm using internal systems at JRC Ispra, so no cloud service provider was involved in my case.
> Sorry not to be of help.
> Stefano
> From: Corina Tudorache [corina_ww at yahoo.com]
> Sent: 01 December 2017 12:08
> To: LUONI Stefano (JRC-ISPRA-EXT); Alessio Fabiani
> Cc: geonode-users
> Subject: Re: [GeoNode-users] Geonode auth for Geoserver
> Hi Stefano,
> My I ask what what cloud service provider you used to install GeoServer and GeoNode? Because I have fount it easyer to configure GeoNode with GeoServer on Digital Ocean than on AWS,
> Kind Regards,
> Corina
> On Friday, December 1, 2017, 8:58:33 AM GMT, Alessio Fabiani <alessio.fabiani at geo-solutions.it> wrote:
> Very good,
> thanks.
> Regards,
> Alessio Fabiani
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054 Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i file/s allegato/i
> sono da considerarsi strettamente riservate. Il loro utilizzo è consentito esclusivamente al destinatario del messaggio, per le finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente
> di darcene notizia via e-mail e di procedere alla distruzione del messaggio stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità diverse,
> costituisce comportamento contrario ai principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for the attention
> and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure,
> reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone,
> fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after
> they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
> On Fri, Dec 1, 2017 at 9:36 AM, <Stefano.LUONI at ext.ec.europa.eu> wrote:
> Hi again,
> I managed to solve my issue after reading this article
> http://docs.geonode.org/en/ master/tutorials/admin/ geoserver_geonode_security/
> Thanks!
> From: geonode-users [geonode-users-bounces at lists. osgeo.org] on behalf of Stefano.LUONI at ext.ec.europa.eu [Stefano.LUONI at ext.ec.europa. eu]
> Sent: 30 November 2017 17:21
> To: geonode-users at lists.osgeo.org
> Subject: [GeoNode-users] Geonode auth for Geoserver
> Hi everyone,
> I need some clarifications about configuring oAuth for synchronizing Geonode and Geoserver login.
> I followed steps described here: http://training.geonode.geo- solutions.it/002_install_and_ admin/002_geonode_install/ install_geoserver_application. html#setup-geoserver
> I'm browsing the website from remote, because the machine it's an Ubuntu Server one and has to host a public website.
> Setting everything as described in the guide, the authentication fails because the browser is unable to connect to localhost.
> If I replace "localhost" with my site url, I get the error:
> Error: invalid_request - Mismatching redirect URI.
> I tried using both http://localhost and http://mywebsiteurl.com as SITEURL in local_settings.py with the same result.
> My machine is Ubuntu 16.04 on which was performed a custom installation of Geonode (http://docs.geonode.org/en/ master/tutorials/admin/ install/custom_install.html# custom-install).
> Can you help me?
> Thank you very much,
> Stefano
> ______________________________ _________________
> geonode-users mailing list
> https://lists.osgeo.org/ mailman/listinfo/geonode-users
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171201/ec08bbdf/attachment-0001.html>
More information about the geonode-users
