[GeoNode-users] Migrating large number of layers to Geonode
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Wed Dec 20 00:46:51 PST 2017
You can try to use the following module
http://docs.geonode.org/en/master/tutorials/admin/loading_data_into_geonode/importlayers.html?highlight=importlayers
This management command should walk through a spatialdata set of files
(either raster and vector) and import them on GeoNode and GeoServer with a
default initial configuration.
You still have to edit the metadata manually on a later step.
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
On Tue, Dec 19, 2017 at 11:32 PM, Sacha Black <sacha.black at gmail.com> wrote:
> hi list,
> I am new to GeoNode and interested in migrating a large number of layers
> (> 3000) from an old Mapserver 6.x WMS server. They are mostly shapefiles
> and some rasters.
> I know I can connect to the existing WMS service to use the layers in
> GeoNode, but since eventually the old server will be turned off, I would
> like to know the best option to import the layers into GeoNode permanently.
> I set up a basic GeoNode in a clean Ubuntu 16.04 install using the Quick
> Guide (http://geonode.org/#install). But I didn't find any specific
> instructions for setting up a bulk import.
> Is there any examples of using a script to do this kind of task? Is this a
> reasonable expectation? What warnings/best practices should I be aware of?
> - Sacha
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171220/551928d7/attachment.html>
More information about the geonode-users
