[GeoNode-users] FW: Cannot upload layers
Stefano.LUONI at ext.ec.europa.eu Stefano.LUONI at ext.ec.europa.eu
Wed Dec 20 00:31:47 PST 2017
Hi Ariel,
unfortunately, this is not my case, as tomcat is already the owner of GeoServer data directory.
Anyway, thanks for your contribution.
@Alessio: thank you very much for your support. At this point I'm lost and I think I'll try again with a fresh machine. Just let me know if you think that I could have missed some other steps setting up Tomcat and Apache services, starting from a development installation (regular installation with geonode 2.6 is not an option for me).
Stefano
Sent: 20 December 2017 00:02
To: Alessio Fabiani; LUONI Stefano (JRC-ISPRA-EXT)
Cc: geonode-users
Subject: Re: [GeoNode-users] FW: Cannot upload layers
Hi, just in case it helps you, i had a similar problem some time ago after migrating GeoNode 2.6 to another server, probably not exactly the same. When I did the migration, some files in the new server where with owner: "root" instead of "Tomcat". Particularly after changing the ownership of: /usr/share/geoserver/data/data/geonode, the problem desapeared and all users were able to upload layers again.
Probably is not your issue, but check the ownership of your files to make sure they´re right.
Cheers
2017-12-19 13:57 GMT-03:00 Alessio Fabiani <alessio.fabiani at geo-solutions.it<mailto:alessio.fabiani at geo-solutions.it>>:
[Inline image 1]
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility  for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
On Tue, Dec 19, 2017 at 5:56 PM, Alessio Fabiani <alessio.fabiani at geo-solutions.it<mailto:alessio.fabiani at geo-solutions.it>> wrote:
So,
I did some tests with your datasets and GeoNode is able to import them correctly
[Inline image 1]
I'm currently using the GeoNode master with GeoServer 2.12.x, but I don't think that your issue is related to the versions actually.
I am pretty sure that something is wrong with your overall configuration, but it's hard to say without looking into the server config.
Regards,
Alessio Fabiani
@alfa7691
GeoSolutions S.A.S.
Italy
phone: +39 0584 962313<tel:0584%20962313>
fax:     +39 0584 1660272<tel:0584%20166%200272>
mob:   +39 331 6233686<tel:331%20623%203686>
On Tue, Dec 19, 2017 at 4:46 PM, <Stefano.LUONI at ext.ec.europa.eu<mailto:Stefano.LUONI at ext.ec.europa.eu>> wrote:
The machine is not reachable from outside JRC network at this time, unfortunately.
If it can be of help, I can send you the GeoServer data directory, Apache virtual host, Geonode settings file and the GeoTiff layer we were testing before.
From: Alessio Fabiani [alessio.fabiani at geo-solutions.it<mailto:alessio.fabiani at geo-solutions.it>]
Sent: 19 December 2017 16:01
To: LUONI Stefano (JRC-ISPRA-EXT)
Cc: GeoSolutions - JAI; geonode-users
That is very strange. Do you have a sample that I can test locally?
Regards,
Alessio Fabiani
@alfa7691
GeoSolutions S.A.S.
Italy
On Tue, Dec 19, 2017 at 3:41 PM, <Stefano.LUONI at ext.ec.europa.eu<mailto:Stefano.LUONI at ext.ec.europa.eu>> wrote:
Yes, I already checked that this file could be processed by GeoServer. If I try to load it directly from GeoServer, SRS are detected (EPSG:21892), as well as bounds and the layer can be published.
I don't understand why GeoServer should not be able to read the file.
This file is just an example, but I get an upload error from Tomcat for shape files too.
Sent: 19 December 2017 15:18
Ah but "bogota" is a GeoTIFF or something? Is it gridded data or vectorial data?
>From the logs it looks like GeoNode tries to create a Coverage Store and GeoServer somehow is not able to read the file.
It could be worth trying to ingest the file directly on GeoServer in order to understand if the server is able to recognize it or not. Maybe it needs some GDAL pre-processing in order to be correctly managed by GeoServer.
Regards,
Alessio Fabiani
@alfa7691
GeoSolutions S.A.S.
Italy
On Tue, Dec 19, 2017 at 3:02 PM, <Stefano.LUONI at ext.ec.europa.eu<mailto:Stefano.LUONI at ext.ec.europa.eu>> wrote:
Please, find the log attached to this email.
Thank you Alessio!
Sent: 19 December 2017 14:51
Yes it is really strange.
Can you try to configure the GeoServer log level to verbose and send to me the "geoserver.log" file ?
Regards,
Alessio Fabiani
@alfa7691
GeoSolutions S.A.S.
Italy
On Tue, Dec 19, 2017 at 2:48 PM, <Stefano.LUONI at ext.ec.europa.eu<mailto:Stefano.LUONI at ext.ec.europa.eu>> wrote:
Yes, all database configs are correct; I followed the guide in the link you posted and I also have a PostGIS store correctly enabled in GeoServer, using those credentials.
I have the same versions of Geonode and Geoserver (and Postgre sql as well) on a local development machine and everything works fine there. I have issues on this other machine, where I'm using Apache (on port 80) with WSGI daemon and Tomcat, instead of server on port 8000 and Jetty that come with the basic development installation.
I also moved the Geoserver data directory to a custom /data/geoserver-data, after copying all contents of the original folder into the new one.
I also set 777 permissions on both uploaded/layers of Geonode and GeoServer data directory, just to be sure that the problem was not there.
So, I guess something is wrong with Tomcat configurations, but I don't know what (I also followed all guides I found, by the way).
Sent: 19 December 2017 14:31
Cc: geonode-users
Did you correctly configured the database passwords and connection params on settings.py or local_settings.py ?
Try to give a look here also
http://training.geonode.geo-solutions.it/002_install_and_admin/002_geonode_install/create_geonode_db.html
Regards,
Alessio Fabiani
@alfa7691
GeoSolutions S.A.S.
Via di Montramito 3/A<https://maps.google.com/?q=Via+di+Montramito+3/A+%0D+55054+%C2%A0Massarosa&entry=gmail&source=g>
55054 <https://maps.google.com/?q=Via+di+Montramito+3/A+%0D+55054+%C2%A0Massarosa&entry=gmail&source=g>  Massarosa<https://maps.google.com/?q=Via+di+Montramito+3/A+%0D+55054+%C2%A0Massarosa&entry=gmail&source=g> (LU)
Italy
On Tue, Dec 19, 2017 at 2:20 PM, <Stefano.LUONI at ext.ec.europa.eu<mailto:Stefano.LUONI at ext.ec.europa.eu>> wrote:
My issue is still unresolved and I don't know how to deeply debug it.
I get errors while trying to upload both shape files and raster files; the only difference is that the process blocks at different points, since I already have a PostGIS data store in GeoServer that would be used for shape files.
Apparently, Geonode is unable to create a store into GeoServer. This is an extract of Apache error log.
[Tue Dec 19 07:04:02.118664<tel:02%20118664> 2017] [wsgi:error] [pid 4932:tid 140059365070592]   File "/home/luonist/risk_data_hub/my_venv/local/lib/python2.7/site-packages/geoserver/catalog.py", line 555, in _create_coveragestore
[Tue Dec 19 07:04:02.118685<tel:02%20118685> 2017] [wsgi:error] [pid 4932:tid 140059365070592]     raise UploadError(response)
[Tue Dec 19 07:04:02.118707<tel:02%20118707> 2017] [wsgi:error] [pid 4932:tid 140059365070592] UploadError: Could not save the layer bogota, there was an upload error: <!DOCTYPE html><html><head><title>Apache Tomcat/8.0.32 (Ubuntu) - Error report</title><style type="text/css">H1 {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:22px;} H2 {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:16px;} H3 {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:14px;} BODY {font-family:Tahoma,Arial,sans-serif;color:black;background-color:white;} B {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;} P {font-family:Tahoma,Arial,sans-serif;background:white;color:black;font-size:12px;}A {color : black;}A.name {color : black;}.line {height: 1px; background-color: #525D76; border: none;}</style> </head><body><h1>HTTP Status 403 - Access is denied</h1><div class="line"></div><p><b>type</b> Status report</p><p><b>message</b> <u>Access is denied</u></p><p><b>description</b> <u>Access to the specified resource has been forbidden.</u></p><hr class="line"><h3>Apache Tomcat/8.0.32 (Ubuntu)</h3></body></html>
>From GeoServer logs, I only find an error that comes later, when it looks for a store that should have been created before (if I understand correctly):
2017-12-19 13:04:02,014 ERROR [geoserver.rest] - No such datastore: geonode,bogota
2017-12-19 13:04:02,016 ERROR [geoserver.rest] -
org.geoserver.rest.RestletException
2017-12-19 13:04:02,050 ERROR [geoserver.rest] - No such coverage store: geonode,bogota
2017-12-19 13:04:02,051 ERROR [geoserver.rest] -
2017-12-19 13:04:02,080 ERROR [geoserver.rest] - No such wms store: geonode,bogota
I'm using Geonode 2.7.4, GeoServer 2.10 (taken from http://build.geonode.org/geoserver/latest/), Apache 2.4, Tomcat 8, OpenJDK 1.8.0_151
Thank you very much,
Stefano
From: geonode-users [geonode-users-bounces at lists.osgeo.org<mailto:geonode-users-bounces at lists.osgeo.org>] on behalf of Stefano.LUONI at ext.ec.europa.eu<mailto:Stefano.LUONI at ext.ec.europa.eu> [Stefano.LUONI at ext.ec.europa.eu<mailto:Stefano.LUONI at ext.ec.europa.eu>]
Sent: 18 December 2017 09:50
To: alessio.fabiani at geo-solutions.it<mailto:alessio.fabiani at geo-solutions.it>
Cc: geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
Subject: Re: [GeoNode-users] Cannot upload layers
Hi Alessio,
yes, the GeoServer WAR file came with the development installation (paver setup); I then moved the WAR file into Tomcat directory, in order to replace Jetty with Tomcat as container for GeoServer. I'm already using the Geonode authentication on GeoServer, though.
Sent: 13 December 2017 18:16
Cc: geonode-users
Are you using one of the GeoServer WARs and DataDir prepared for GeoNode?
Regards,
Alessio Fabiani
@alfa7691
GeoSolutions S.A.S.
Italy
On Wed, Dec 13, 2017 at 6:04 PM, <Stefano.LUONI at ext.ec.europa.eu<mailto:Stefano.LUONI at ext.ec.europa.eu>> wrote:
I'm facing this issue: whenever I try to upload a layer (both shape file or raster), I receive a 403 error (Access is denied) from Tomcat.
Error code (403) from GeoServer:
type Status report
message Access is denied
description Access to the specified resource has been forbidden.
I'm working on a custom installation of Geonode v.2.7.4 on Ubuntu 16.04. I replaced Jetty with Tomcat8 as container for Geoserver, which is 2.10-SNAPSHOT.
In Geoserver logs, I can find these errors:
ERROR [org.geoserver.rest] - No such coverage store: geonode,geonode_data
ERROR [org.geoserver.rest] - No such wms store: geonode,geonode_data
>From Apache logs, I see that there is an exception thrown by
my_venv/local/lib/python2.7/site-packages/geoserver/catalog.py", line 249, in save
(headers['status'], body))
FailedRequestError: Error code (403) from GeoServer
Postgre sql is working correctly and I already configured and enabled a "datastore" PostGIS store in Geoserver.
I followed all instructions about custom installation of Geonode (http://docs.geonode.org/en/master/tutorials/admin/install/custom_install.html) and advanced security (http://docs.geonode.org/en/master/tutorials/admin/geoserver_geonode_security/).
I checked that files exist in the "uploaded" directory under Geonode folder.
I don't know what to do further to debug this issue.
Can you help me?
Stefano
geonode-users mailing list
https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171220/9ac2f329/attachment-0001.html>
Name: 2017-12-19 17_56_37-GeoNode.png
Type: image/png
Desc: 2017-12-19 17_56_37-GeoNode.png
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171220/9ac2f329/attachment-0002.png>
Type: image/png
Desc: image.png
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171220/9ac2f329/attachment-0003.png>
More information about the geonode-users mailing list
