[GeoNode-users] Docker installation of Geonode
Francesco Bartoli
xbartolone at gmail.com
Thu Feb 2 01:36:18 PST 2017
interesting use case. you should be able to achieve this:
* create two different database services in you compose file and declare them as link for the django service, one of them has to be based on a postgis image
* add on each of their dockerfile a specific script that creates the geonode and geonode_data databases in order to have two distinct images
* declare two different DATABASE_URL env variables for previous database services
* use the env variables to instruct the piece of database settings for geonode and geonode_data
Hope this helps, let's know
Francesco
Sent from [Nylas Pro](https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc
/local-d264c7ff-eeff/0?redirect=https%3A%2F%2Fnylas.com%2Fnylas-
pro%3Fref%3Dn1&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=), the most powerful
email app for work
On feb 2 2017, at 10:10 am, Zizi Jama <mazizi.jama at gmail.com> wrote:
> Dear List,
> I would like to separate the geonode database that stores the configuration
data and spatial data. I have not been able to do this with the docker-
compose.yml file.
> According to the documentation - [http://training.geonode.geo-solutions.it/0
02_install_and_admin/002_geonode_install/create_geonode_db.html](http://traini
ng.geonode.geo-solutions.it/002_install_and_admin/002_geonode_install/create_g
eonode_db.html&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=)
> the following databases are created during installation with user geonode:
> geonode (this stores geonode configuration data)
> geonode_data (posting is enabled here)
> I used the following steps:
> # build the docker container
> docker-compose build
> # run the docker container
> docker-compose up
> # turn it off
> docker-compose down
> # create database
> make sync
> This then creates a single database - postgres (and the geonode
configuration data is then installed on this database).
> The two databases named are not created and I do not know which setting
must I change to enable this.
> Regards,
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170202/0cade438/attachment.html>
More information about the geonode-users
