[GeoNode-users] Custom Installation
Giovani Fronza giovanifronza at gmail.com
Fri Feb 17 07:35:53 PST 2017
Wen run ($ sudo pip isntall -e .) returns a warning...
Installing collected packages: GeoNode
  Running setup.py develop for GeoNode
    warning: manifest_maker: MANIFEST.in, line 2: 'recursive-exclude'
expects <dir> <pattern1> <pattern2> ...
    Creating /usr/local/lib/python2.7/dist-packages/GeoNode.egg-link (link
to .)
    GeoNode 2.5.16 is already the active version in easy-install.pth
    Installed /home/geonode
Successfully installed GeoNode
Cleaning up...
2017-02-17 13:19 GMT-02:00 Paolo Corti <pcorti at gmail.com>:
> Yes, after checking out the git tag, you should reinstall resources
> (with sudo pip install -e .) as there could be differences.
> p
> On Fri, Feb 17, 2017 at 10:09 AM, Simone Dalmasso
> <simone.dalmasso at gmail.com> wrote:
> > Hi, seems that you may have a wrong version of gsconfig. pls check that.
> > 2017-02-17 16:05 GMT+01:00 Giovani Fronza <giovanifronza at gmail.com>:
> >> I think so. Don“t tried to start paver before, but now, it retuns this
> >> messanges:
> >> ---> pavement.start_django
> >> python manage.py runserver  &
> >> GeoNode is now available.
> >> root at vmgeo:/home/geonode# Performing system checks...
> >> System check identified some issues:
> >> WARNINGS:
> >> base.ResourceBase.tkeywords: (fields.W340) null has no effect on
> >> ManyToManyField.
> >> System check identified 1 issue (0 silenced).
> >> February 17, 2017 - 08:54:03
> >> Django version 1.8.17, using settings 'geonode.settings'
> >> Starting development server at http://127.0.0.1:8000/
> >> Quit the server with CONTROL-C.
> >> 2017-02-17 12:17 GMT-02:00 Paolo Corti <pcorti at gmail.com>:
> >>> Before starting using httpd and mod_wsgi: does your GeoNode instance
> >>> work correctly with the development server? You can start it with
> >>> paver start, as suggested in the documentation page you have linked
> >>> p
> >>> On Fri, Feb 17, 2017 at 8:31 AM, Giovani Fronza <
> >>> wrote:
> >>> > Thankyou very much Paolo!
> >>> > After installation I faced problem with wsgi. Something related to
> >>> > geoserver.catalog.
> >>> > I found this on apache error.log
> >>> >  mod_wsgi (pid=22240): Target WSGI script
> >>> > '/home/geonode/geonode/wsgi.py'
> >>> > cannot be loaded as Python module.
> >>> >  mod_wsgi (pid=22240): Exception occurred processing WSGI script
> >>> > '/home/geonode/geonode/wsgi.py'.
> >>> >  Traceback (most recent call last):
> >>> >    File "/home/geonode/geonode/wsgi.py", line 30, in <module>
> >>> >      application = get_wsgi_application()
> >>> >    File "/usr/local/lib/python2.7/dist-packages/django/core/
> wsgi.py",
> >>> > line
> >>> > 14, in get_wsgi_application
> >>> >      django.setup()
> >>> >    File "/usr/local/lib/python2.7/dist-packages/django/__init__.py",
> >>> > line
> >>> > 18, in setup
> >>> >      apps.populate(settings.INSTALLED_APPS)
> >>> >    File
> >>> > "/usr/local/lib/python2.7/dist-packages/django/apps/registry.py",
> >>> > line 108, in populate
> >>> >      app_config.import_models(all_models)
> >>> >    File "/usr/local/lib/python2.7/dist-packages/django/apps/
> config.py",
> >>> > line
> >>> > 198, in import_models
> >>> >      self.models_module = import_module(models_module_name)
> >>> >    File "/usr/lib/python2.7/importlib/__init__.py", line 37, in
> >>> > import_module
> >>> >      __import__(name)
> >>> >    File "/home/geonode/geonode/services/models.py", line 24, in
> >>> > <module>
> >>> >      from geoserver.catalog import FailedRequestError, Catalog
> >>> >  ImportError: No module named catalog
> >>> > How to resolv that?
> >>> > 2017-02-16 18:24 GMT-02:00 Paolo Corti <pcorti at gmail.com>:
> >>> >> Hi Giovani
> >>> >> you should be able to get the 2.6 (note that it is still not
> released)
> >>> >> by
> >>> >> checking out the 2.6 tag from git:
> >>> >> https://github.com/GeoNode/geonode/tree/debian/2.6.0+alpha1
> >>> >> hope it helps
> >>> >> p
> >>> >> On Thu, Feb 16, 2017 at 3:09 PM, Giovani Fronza
> >>> >> wrote:
> >>> >> > I've just installed the current geonode.git, according to the
> >>> >> > instructions
> >>> >> > presented on
> >>> >> > http://docs.geonode.org/en/master/tutorials/admin/
> install/custom_install.html,
> >>> >> > and for my surprise that was installed the 2.7.dev version.
> >>> >> > I'm curious about 2.6 stable release. We have just started a big
> >>> >> > project
> >>> >> > to
> >>> >> > manage geospatial data and we would like to lead with a solution
> >>> >> > newest
> >>> >> > as
> >>> >> > possible.
> >>> >> > Is there a realistic date for 2.6 version launch?
> >>> >> > What are your recomendations for custom installation (for debian),
> >>> >> > considering this situation?
> >>> >> > Giovani
> >>> >> > _______________________________________________
> >>> >> > geonode-users mailing list
> >>> >> > geonode-users at lists.osgeo.org
> >>> >> > https://lists.osgeo.org/mailman/listinfo/geonode-users
> >>> >> Paolo Corti
> >>> >> Geospatial software developer
> >>> >> web: http://www.paolocorti.net
> >>> >> twitter: @capooti
> >>> >> skype: capooti
> >>> Paolo Corti
> >>> twitter: @capooti
> >>> skype: capooti
> > Simone
> Paolo Corti
> twitter: @capooti
> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170217/05ec206a/attachment.html>
More information about the geonode-users mailing list
