[GeoNode-users] Custom Installation
Paolo Corti
pcorti at gmail.com
Fri Feb 17 07:44:57 PST 2017
That seems fine, though I don't see gsconfig being downgraded as it
should according to Simone's suggestion.
Could you check what is the output of: pip freeze | grep gsconfig
Also please let me know what is the output of this: git rev-parse HEAD
p
On Fri, Feb 17, 2017 at 10:35 AM, Giovani Fronza
<giovanifronza at gmail.com> wrote:
> Wen run ($ sudo pip isntall -e .) returns a warning...
> Installing collected packages: GeoNode
> Running setup.py develop for GeoNode
> warning: manifest_maker: MANIFEST.in, line 2: 'recursive-exclude'
> expects <dir> <pattern1> <pattern2> ...
> Creating /usr/local/lib/python2.7/dist-packages/GeoNode.egg-link (link
> to .)
> GeoNode 2.5.16 is already the active version in easy-install.pth
> Installed /home/geonode
> Successfully installed GeoNode
> Cleaning up...
> 2017-02-17 13:19 GMT-02:00 Paolo Corti <pcorti at gmail.com>:
>> Yes, after checking out the git tag, you should reinstall resources
>> (with sudo pip install -e .) as there could be differences.
>> p
>> On Fri, Feb 17, 2017 at 10:09 AM, Simone Dalmasso
>> <simone.dalmasso at gmail.com> wrote:
>> > Hi, seems that you may have a wrong version of gsconfig. pls check that.
>> > 2017-02-17 16:05 GMT+01:00 Giovani Fronza <giovanifronza at gmail.com>:
>> >> I think so. Don“t tried to start paver before, but now, it retuns this
>> >> messanges:
>> >> ---> pavement.start_django
>> >> python manage.py runserver &
>> >> GeoNode is now available.
>> >> root at vmgeo:/home/geonode# Performing system checks...
>> >> System check identified some issues:
>> >> WARNINGS:
>> >> base.ResourceBase.tkeywords: (fields.W340) null has no effect on
>> >> ManyToManyField.
>> >> System check identified 1 issue (0 silenced).
>> >> February 17, 2017 - 08:54:03
>> >> Django version 1.8.17, using settings 'geonode.settings'
>> >> Starting development server at http://127.0.0.1:8000/
>> >> Quit the server with CONTROL-C.
>> >> 2017-02-17 12:17 GMT-02:00 Paolo Corti <pcorti at gmail.com>:
>> >>> Before starting using httpd and mod_wsgi: does your GeoNode instance
>> >>> work correctly with the development server? You can start it with
>> >>> paver start, as suggested in the documentation page you have linked
>> >>> p
>> >>> On Fri, Feb 17, 2017 at 8:31 AM, Giovani Fronza
>> >>> wrote:
>> >>> > Thankyou very much Paolo!
>> >>> > After installation I faced problem with wsgi. Something related to
>> >>> > geoserver.catalog.
>> >>> > I found this on apache error.log
>> >>> > mod_wsgi (pid=22240): Target WSGI script
>> >>> > '/home/geonode/geonode/wsgi.py'
>> >>> > cannot be loaded as Python module.
>> >>> > mod_wsgi (pid=22240): Exception occurred processing WSGI script
>> >>> > '/home/geonode/geonode/wsgi.py'.
>> >>> > Traceback (most recent call last):
>> >>> > File "/home/geonode/geonode/wsgi.py", line 30, in <module>
>> >>> > application = get_wsgi_application()
>> >>> > File
>> >>> > "/usr/local/lib/python2.7/dist-packages/django/core/wsgi.py",
>> >>> > line
>> >>> > 14, in get_wsgi_application
>> >>> > django.setup()
>> >>> > File "/usr/local/lib/python2.7/dist-packages/django/__init__.py",
>> >>> > line
>> >>> > 18, in setup
>> >>> > apps.populate(settings.INSTALLED_APPS)
>> >>> > File
>> >>> > "/usr/local/lib/python2.7/dist-packages/django/apps/registry.py",
>> >>> > line 108, in populate
>> >>> > app_config.import_models(all_models)
>> >>> > File
>> >>> > "/usr/local/lib/python2.7/dist-packages/django/apps/config.py",
>> >>> > line
>> >>> > 198, in import_models
>> >>> > self.models_module = import_module(models_module_name)
>> >>> > File "/usr/lib/python2.7/importlib/__init__.py", line 37, in
>> >>> > import_module
>> >>> > __import__(name)
>> >>> > File "/home/geonode/geonode/services/models.py", line 24, in
>> >>> > <module>
>> >>> > from geoserver.catalog import FailedRequestError, Catalog
>> >>> > ImportError: No module named catalog
>> >>> > How to resolv that?
>> >>> > 2017-02-16 18:24 GMT-02:00 Paolo Corti <pcorti at gmail.com>:
>> >>> >> Hi Giovani
>> >>> >> you should be able to get the 2.6 (note that it is still not
>> >>> >> released)
>> >>> >> by
>> >>> >> checking out the 2.6 tag from git:
>> >>> >> https://github.com/GeoNode/geonode/tree/debian/2.6.0+alpha1
>> >>> >> hope it helps
>> >>> >> p
>> >>> >> On Thu, Feb 16, 2017 at 3:09 PM, Giovani Fronza
>> >>> >> wrote:
>> >>> >> > I've just installed the current geonode.git, according to the
>> >>> >> > instructions
>> >>> >> > presented on
>> >>> >> > http://docs.geonode.org/en/master/tutorials/admin/install/custom_install.html,
>> >>> >> > and for my surprise that was installed the 2.7.dev version.
>> >>> >> > I'm curious about 2.6 stable release. We have just started a big
>> >>> >> > project
>> >>> >> > to
>> >>> >> > manage geospatial data and we would like to lead with a solution
>> >>> >> > newest
>> >>> >> > as
>> >>> >> > possible.
>> >>> >> > Is there a realistic date for 2.6 version launch?
>> >>> >> > What are your recomendations for custom installation (for
>> >>> >> > debian),
>> >>> >> > considering this situation?
>> >>> >> > Giovani
>> >>> >> > _______________________________________________
>> >>> >> > geonode-users mailing list
>> >>> >> > geonode-users at lists.osgeo.org
>> >>> >> > https://lists.osgeo.org/mailman/listinfo/geonode-users
>> >>> >> Paolo Corti
>> >>> >> Geospatial software developer
>> >>> >> web: http://www.paolocorti.net
>> >>> >> twitter: @capooti
>> >>> >> skype: capooti
>> >>> Paolo Corti
>> >>> twitter: @capooti
>> >>> skype: capooti
>> > Simone
>> Paolo Corti
>> twitter: @capooti
>> skype: capooti
Paolo Corti
twitter: @capooti
skype: capooti
More information about the geonode-users
