[GeoNode-users] default workspace for geosites
Jeffrey Johnson
ortelius at gmail.com
Fri Jan 13 06:26:17 PST 2017
Just to clarify.
CASCADE_WORKSPACE Is used by Remote services for cascading WMS.
The geosites functionality does NOT use geoserver workspaces.
On Fri, Jan 13, 2017 at 3:04 AM, Eugenio Trumpy <frippe12573 at hotmail.com> wrote:
> The suggested way to store the layers belonging different geosites in
> geoserver It seemed nice to me.
> I read it here:
> https://geonode.readthedocs.io/en/2.0/tutorials/admin/multi-tenancy.html
> I wondered how I should create the workspace in geoserver.
> I presume by hand from geoserver interface, then second question was where I
> have to
> set the workspace for the geosite since in the global setting.py I have:
> DEFAULT_WORKSPACE
> and
> CASCADE_WORKSPACE (what does it means? What is it?)
> I suppose the master site has to have DEFAULT_WORKSPACE = 'geonode'
> whereas the site DEFAULT_WORKSPACE = 'geosite', so loading a layer from the
> site it should use such workspace, is that right?
> Why it does not work?
> I understand that could be a second way (i.e. the way suggested by Simone),
> could you give me an example? I guess you act layer by layer adding new
> rules in geoserver 'Data security'.
> ciao
> Eugenio
> ________________________________
> Da: Simone Dalmasso <simone.dalmasso at gmail.com>
> Inviato: venerdì 13 gennaio 2017 11.45
> A: Alessio Fabiani
> Cc: Eugenio Trumpy; geonode-users at lists.osgeo.org
> Oggetto: Re: [GeoNode-users] default workspace for geosites
> Not sure about the default workspace it might be a geonode bug. But I leave
> the layers in the "geonode" one and it works well. Layers are managed
> respecting permissions, and it works well in the instances I have.
> 2017-01-13 10:59 GMT+01:00 Alessio Fabiani
> <alessio.fabiani at geo-solutions.it>:
>> Not sure but I'm afraid geonode has currently a lot of hardcoded stuff. It
>> is quite premature speaking about multi-tenancy on GeoNode.
>> Best Regards,
>> Alessio Fabiani.
>> GeoServer Professional Services from the experts!
>> Visit http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A
>> 55054 Massarosa (LU)
>> Italy
>> phone: +39 0584 962313
>> fax: +39 0584 1660272
>> mob: +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il loro
>> utilizzo è consentito esclusivamente al destinatario del messaggio, per le
>> finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
>> senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
>> via e-mail e di procedere alla distruzione del messaggio stesso,
>> cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
>> anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
>> finalità diverse, costituisce comportamento contrario ai principi dettati
>> dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely for
>> the attention and use of the named addressee(s) and may be confidential or
>> proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> information in this message that has been received in error. The sender does
>> not give any warranty or accept liability as the content, accuracy or
>> completeness of sent messages and accepts no responsibility for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> On Fri, Jan 13, 2017 at 10:44 AM, Eugenio Trumpy <frippe12573 at hotmail.com>
>> wrote:
>>> Dear all,
>>> I setup geosites in my geonode instance.
>>> I'm now testing the geosite I created. I tried to upload a SHP from my
>>> new geosite and the procedure went well.
>>> However in geoserver, I see the new layer under the workspace named
>>> 'geonode', which was created by the master site (for master site I mean the
>>> one we have with the default installation of geonode). Since i inserted the
>>> variable DEFAULT_WORKSPACE='mynewgeosite' in the settings.py placed in the
>>> folder of my new geosite, I was expected to have the new SHP in the new
>>> geoserver workspace.
>>> Where am I wrong?
>>> Moreover, after the layer upload I can see it in the layer list, but in
>>> the 'type' filter I see the vector layer loaded over all the others layers
>>> loaded in the master site.
>>> I was expected to have only 1 layer. Is that correct or it is due to a
>>> somehow miss-configuration?
>>> Thanks in advance
>>> Eugenio
>>> geonode-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
More information about the geonode-users
