[GeoNode-users] Group permisions for layer / map not working
Daniel Victoria daniel.victoria at gmail.com
Thu Jan 19 11:20:07 PST 2017
Great Simone, it works! I was sure I was doing something that was not
correct...
thanks
On Thu, Jan 19, 2017 at 5:07 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Hi Daniel. Group permissions are implemented but you have to create and
> manage the groups only through the geonode ui and not use the admin.
> His because geonode takes care of lot of logic behind the scenes.
> Hope this helps.
> Il giorno gio 19 gen 2017 alle 19:44 Daniel Victoria <
> daniel.victoria at gmail.com> ha scritto:
>> Hi list,
>> I'm not sure I'm doing things right. I created a group in Geonode Admin
>> Panel (Group profiles) and set some of the layers and maps in my GeoNode
>> site to have view and download permission for the users on that group.
>> However, when I logon to GeoNode with a user that belong to the group, the
>> user does not have access to the layers (view or download).
>> Am I missing something? Do I also need to change the Group auth
>> permissions.
>> I saw this GeoNode doc that says "the “Groups” permissions system is not
>> implemented yet in GeoNode"
>> http://docs.geonode.org/en/master/tutorials/admin/admin_
>> panel/users-groups.html
>> Does this means that I cannot set layer permissions based on groups and
>> will have to give permissions individually, for each user?
>> Thanks
>> Daniel
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170119/e4fe4d51/attachment.html>
More information about the geonode-users mailing list
