[GeoNode-users] Vector upload error on Geonode 2.6.x
jodom oumak
jodomoumak.jo at gmail.com
Tue Jul 11 23:38:36 PDT 2017
Hello, Jodom here.
I have successfully set up my geonode 2.6.x for development on Ubuntu Linux
- Mint 18.
THe issue im having is, I cant upload vector layers while uploading
rasters is okay.
This issue has been mentioned before in the mailing lists under the
topic: *[GeoNode-users]
Running Geonode development build on another ip (!= localhost) * but i dont
think a conclusive solution was reached.
To test, ive used about three different instances(separate virtual
environments) and even tried to install the same on a fresh machine but in
production mode.
I end up with the same problem so its essentially possible to replicate the
problem.
Below are my stack traces:
*Terminal error:*
j
*ava.lang.UnsatisfiedLinkError:
/tmp/spatialite-3.7.22.4-libspatialitejdbc.so
<http://spatialite-3.7.22.4-libspatialitejdbc.so>: libproj.so.0: cannot
open shared object file: No such file or directory*
*Full trace on terminal:*
java.net.ConnectException: Connection refused (Connection refused)
at java.net.PlainSocketImpl.socketConnect(Native Method)
at
java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
at
java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
at
java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
at java.net.Socket.connect(Socket.java:589)
at
com.rabbitmq.client.impl.SocketFrameHandlerFactory.create(SocketFrameHandlerFactory.java:50)
at
com.rabbitmq.client.impl.recovery.RecoveryAwareAMQConnectionFactory.newConnection(RecoveryAwareAMQConnectionFactory.java:60)
at
com.rabbitmq.client.impl.recovery.AutorecoveringConnection.init(AutorecoveringConnection.java:99)
at
com.rabbitmq.client.ConnectionFactory.newConnection(ConnectionFactory.java:900)
at
com.rabbitmq.client.ConnectionFactory.newConnection(ConnectionFactory.java:859)
at
com.rabbitmq.client.ConnectionFactory.newConnection(ConnectionFactory.java:817)
at
com.rabbitmq.client.ConnectionFactory.newConnection(ConnectionFactory.java:954)
at
org.geoserver.notification.common.sender.RabbitMQSender.initialize(RabbitMQSender.java:79)
at
org.geoserver.notification.common.sender.RabbitMQSender.send(RabbitMQSender.java:98)
at
org.geoserver.notification.common.DefaultNotificationProcessor.process(DefaultNotificationProcessor.java:39)
at
org.geoserver.notification.MessageProcessor$WorkerThread.run(MessageProcessor.java:79)
at
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:748)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
java.lang.UnsatisfiedLinkError: /tmp/
spatialite-3.7.22.4-libspatialitejdbc.so: libproj.so.0: cannot open shared
*Geoserver logs:*
org.apache.wicket.WicketRuntimeException: Method onRequest of interface
org.apache.wicket.behavior.IBehaviorListener targeted at
org.apache.wicket.ajax.markup.html.form.AjaxSubmitLink$1 at c5a5db9 on
component [AjaxSubmitLink [Component id = save]] threw an exception
at
org.apache.wicket.RequestListenerInterface.internalInvoke(RequestListenerInterface.java:268)
at
org.apache.wicket.RequestListenerInterface.invoke(RequestListenerInterface.java:241)
at
org.apache.wicket.core.request.handler.ListenerInterfaceRequestHandler.invokeListener(ListenerInterfaceRequestHandler.java:248)
at
org.apache.wicket.core.request.handler.ListenerInterfaceRequestHandler.respond(ListenerInterfaceRequestHandler.java:234)
at
org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:865)
at
org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:64)
at
org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:265)
at
org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:222)
at
org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:293)
at
org.apache.wicket.protocol.http.WicketFilter.processRequestCycle(WicketFilter.java:261)
at
org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:203)
at
org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:159)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:755)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)
at
org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:158)
at
org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:147)
at
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50)
at
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:959)
at
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893)
at
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:968)
at
org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:870)
at
org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:844)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:669)
at
org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1336)
at
org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at
org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1307)
at
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at
org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at
at
org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at
at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:316)
at
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:126)
at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:90)
at
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at
org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
at
at
org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
at
at
at
at
org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at
at
at
org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:205)
at
at
at
org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:116)
at
at
at
org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:157)
at
at
at
at
org.geoserver.security.oauth2.GeoServerOAuthAuthenticationFilter.doFilter(GeoServerOAuthAuthenticationFilter.java:167)
at
at
at
org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:91)
at
org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at
at
at
at
org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:213)
at
org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:176)
at
org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:152)
at
org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at
org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
at
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
at
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at
at
org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at
at
org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:121)
at
org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
at
at
org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:453)
at
org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:137)
at
org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:560)
at
org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:231)
at
org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1072)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:382)
at
org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:193)
at
org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1006)
at
org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:135)
at
org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:255)
at
org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:154)
at
org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:116)
at org.eclipse.jetty.server.Server.handle(Server.java:365)
at
org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:485)
at
org.eclipse.jetty.server.AbstractHttpConnection.content(AbstractHttpConnection.java:937)
at
org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.content(AbstractHttpConnection.java:998)
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:856)
at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:240)
at
org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:82)
at
org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:628)
at
org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:52)
at
org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:608)
at
org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:543)
Caused by: java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at
org.apache.wicket.RequestListenerInterface.internalInvoke(RequestListenerInterface.java:258)
... 108 more
Caused by: java.lang.NoSuchMethodError:
org.postgresql.core.BaseConnection.getPreferQueryMode()Lorg/postgresql/jdbc/PreferQueryMode;
at org.postgresql.jdbc.PgStatement.executeCachedSql(PgStatement.java:273)
at org.postgresql.jdbc.PgStatement.executeWithFlags(PgStatement.java:269)
at org.postgresql.jdbc.PgStatement.executeQuery(PgStatement.java:236)
at
org.apache.commons.dbcp.DelegatingStatement.executeQuery(DelegatingStatement.java:208)
at
org.apache.commons.dbcp.PoolableConnectionFactory.validateConnection(PoolableConnectionFactory.java:658)
at
org.apache.commons.dbcp.BasicDataSource.validateConnectionFactory(BasicDataSource.java:1558)
at
org.apache.commons.dbcp.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:1545)
at
org.apache.commons.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:1388)
at
org.apache.commons.dbcp.BasicDataSource.getConnection(BasicDataSource.java:1044)
at
org.geotools.data.jdbc.datasource.AbstractManageableDataSource.getConnection(AbstractManageableDataSource.java:48)
at org.geotools.jdbc.JDBCDataStore.createConnection(JDBCDataStore.java:2067)
at org.geotools.jdbc.JDBCDataStore.createTypeNames(JDBCDataStore.java:978)
at
org.geotools.data.store.ContentDataStore.getTypeNames(ContentDataStore.java:308)
at
org.vfny.geoserver.util.DataStoreUtils.getDataAccess(DataStoreUtils.java:97)
at org.geoserver.catalog.ResourcePool.getDataStore(ResourcePool.java:636)
at
org.geoserver.catalog.impl.DataStoreInfoImpl.getDataStore(DataStoreInfoImpl.java:38)
at
org.geoserver.web.data.store.DataAccessNewPage.onSaveDataStore(DataAccessNewPage.java:95)
at
org.geoserver.web.data.store.AbstractDataAccessPage$1.onSubmit(AbstractDataAccessPage.java:165)
at
org.apache.wicket.ajax.markup.html.form.AjaxSubmitLink$1.onSubmit(AjaxSubmitLink.java:110)
at
org.apache.wicket.ajax.form.AjaxFormSubmitBehavior$AjaxFormSubmitter.onSubmit(AjaxFormSubmitBehavior.java:215)
at org.apache.wicket.markup.html.form.Form.delegateSubmit(Form.java:1307)
at org.apache.wicket.markup.html.form.Form.process(Form.java:974)
at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:795)
at
org.apache.wicket.ajax.form.AjaxFormSubmitBehavior.onEvent(AjaxFormSubmitBehavior.java:171)
at
org.apache.wicket.ajax.AjaxEventBehavior.respond(AjaxEventBehavior.java:155)
at
org.apache.wicket.ajax.AbstractDefaultAjaxBehavior.onRequest(AbstractDefaultAjaxBehavior.java:588)
... 113 more
-*Note: On geoserver, I have no store and when I try to re-create one, I
get the above error.*
*At first installation, I had a store called geonode which was enabled, but
still could not upload vector layer.*
Your help debugging this is greatly appreciated,
Jodom.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170712/701b84f0/attachment-0001.html>
More information about the geonode-users
