[GeoNode-users] Vector upload error on Geonode 2.6.x
Simone Dalmasso
simone.dalmasso at gmail.com
Fri Jul 14 00:36:24 PDT 2017
Hi, looks like there is a connection issue between the database and
geoserver. Are you using postgres? If yes make sure the parameters set for
the geonode dayabase "datastore" settings are correct.
2017-07-12 8:38 GMT+02:00 jodom oumak <jodomoumak.jo at gmail.com>:
> Hello, Jodom here.
> I have successfully set up my geonode 2.6.x for development on Ubuntu
> Linux - Mint 18.
> THe issue im having is, I cant upload vector layers while uploading
> rasters is okay.
> This issue has been mentioned before in the mailing lists under the topic: *[GeoNode-users]
> Running Geonode development build on another ip (!= localhost) * but i
> dont think a conclusive solution was reached.
> To test, ive used about three different instances(separate virtual
> environments) and even tried to install the same on a fresh machine but in
> production mode.
> I end up with the same problem so its essentially possible to
> replicate the problem.
> Below are my stack traces:
> *Terminal error:*
> j
> *ava.lang.UnsatisfiedLinkError:
> /tmp/spatialite-3.7.22.4-libspatialitejdbc.so
> <http://spatialite-3.7.22.4-libspatialitejdbc.so>: libproj.so.0: cannot
> open shared object file: No such file or directory*
> *Full trace on terminal:*
> java.net.ConnectException: Connection refused (Connection refused)
> at java.net.PlainSocketImpl.socketConnect(Native Method)
> at java.net.AbstractPlainSocketImpl.doConnect(
> AbstractPlainSocketImpl.java:350)
> at java.net.AbstractPlainSocketImpl.connectToAddress(
> AbstractPlainSocketImpl.java:206)
> at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:
> 188)
> at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
> at java.net.Socket.connect(Socket.java:589)
> at com.rabbitmq.client.impl.SocketFrameHandlerFactory.create(
> SocketFrameHandlerFactory.java:50)
> at com.rabbitmq.client.impl.recovery.RecoveryAwareAMQConnectionFact
> ory.newConnection(RecoveryAwareAMQConnectionFactory.java:60)
> at com.rabbitmq.client.impl.recovery.AutorecoveringConnection.init(
> AutorecoveringConnection.java:99)
> at com.rabbitmq.client.ConnectionFactory.newConnection(
> ConnectionFactory.java:900)
> ConnectionFactory.java:859)
> ConnectionFactory.java:817)
> ConnectionFactory.java:954)
> at org.geoserver.notification.common.sender.RabbitMQSender.
> initialize(RabbitMQSender.java:79)
> send(RabbitMQSender.java:98)
> at org.geoserver.notification.common.DefaultNotificationProcessor.process(
> DefaultNotificationProcessor.java:39)
> at org.geoserver.notification.MessageProcessor$WorkerThread.
> run(MessageProcessor.java:79)
> at java.util.concurrent.ThreadPoolExecutor.runWorker(
> ThreadPoolExecutor.java:1142)
> at java.util.concurrent.ThreadPoolExecutor$Worker.run(
> ThreadPoolExecutor.java:617)
> at java.lang.Thread.run(Thread.java:748)
> 188)
> 188)
> java.lang.UnsatisfiedLinkError: /tmp/spatialite-3.7.22.4-
> libspatialitejdbc.so: libproj.so.0: cannot open shared object file: No
> *Geoserver logs:*
> org.apache.wicket.WicketRuntimeException: Method onRequest of interface
> org.apache.wicket.behavior.IBehaviorListener targeted at
> org.apache.wicket.ajax.markup.html.form.AjaxSubmitLink$1 at c5a5db9 on
> component [AjaxSubmitLink [Component id = save]] threw an exception
> at org.apache.wicket.RequestListenerInterface.internalInvoke(
> RequestListenerInterface.java:268)
> at org.apache.wicket.RequestListenerInterface.invoke(
> RequestListenerInterface.java:241)
> at org.apache.wicket.core.request.handler.ListenerInterfaceRequestHandle
> r.invokeListener(ListenerInterfaceRequestHandler.java:248)
> r.respond(ListenerInterfaceRequestHandler.java:234)
> at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(
> RequestCycle.java:865)
> at org.apache.wicket.request.RequestHandlerStack.execute(
> RequestHandlerStack.java:64)
> at org.apache.wicket.request.cycle.RequestCycle.execute(
> RequestCycle.java:265)
> processRequest(RequestCycle.java:222)
> at org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(
> RequestCycle.java:293)
> at org.apache.wicket.protocol.http.WicketFilter.processRequestCycle(
> WicketFilter.java:261)
> processRequest(WicketFilter.java:203)
> at org.apache.wicket.protocol.http.WicketServlet.doPost(
> WicketServlet.java:159)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:755)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)
> at org.springframework.web.servlet.mvc.ServletWrappingController.
> handleRequestInternal(ServletWrappingController.java:158)
> at org.springframework.web.servlet.mvc.AbstractController.handleRequest(
> AbstractController.java:147)
> at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter
> .handle(SimpleControllerHandlerAdapter.java:50)
> at org.springframework.web.servlet.DispatcherServlet.
> doDispatch(DispatcherServlet.java:959)
> doService(DispatcherServlet.java:893)
> at org.springframework.web.servlet.FrameworkServlet.processRequest(
> FrameworkServlet.java:968)
> doPost(FrameworkServlet.java:870)
> service(FrameworkServlet.java:844)
> at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:669)
> at org.eclipse.jetty.servlet.ServletHandler$CachedChain.
> doFilter(ServletHandler.java:1336)
> at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(
> ThreadLocalsCleanupFilter.java:28)
> doFilter(ServletHandler.java:1307)
> at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(
> SpringDelegatingFilter.java:75)
> at org.geoserver.wms.animate.AnimatorFilter.doFilter(
> AnimatorFilter.java:71)
> SpringDelegatingFilter.java:71)
> at org.geoserver.filters.SpringDelegatingFilter.doFilter(
> SpringDelegatingFilter.java:46)
> at org.geoserver.platform.AdvancedDispatchFilter.doFilter(
> AdvancedDispatchFilter.java:50)
> at org.springframework.security.web.FilterChainProxy$
> VirtualFilterChain.doFilter(FilterChainProxy.java:316)
> at org.geoserver.security.filter.GeoServerCompositeFilter$
> NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
> at org.springframework.security.web.access.intercept.
> FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:126)
> FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:90)
> NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
> at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(
> GeoServerCompositeFilter.java:92)
> VirtualFilterChain.doFilter(FilterChainProxy.java:330)
> at org.springframework.security.web.access.ExceptionTranslationFilter.
> doFilter(ExceptionTranslationFilter.java:114)
> at org.geoserver.security.filter.GeoServerAnonymousAuthenticati
> onFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
> at org.springframework.security.web.authentication.
> AbstractAuthenticationProcessingFilter.doFilter(
> AbstractAuthenticationProcessingFilter.java:205)
> at org.geoserver.security.filter.GeoServerUserNamePasswordAuthe
> nticationFilter.doFilter(GeoServerUserNamePasswordAuthe
> nticationFilter.java:116)
> at org.springframework.security.web.authentication.rememberme.
> RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter
> .java:157)
> at org.geoserver.security.oauth2.GeoServerOAuthAuthenticationFi
> lter.doFilter(GeoServerOAuthAuthenticationFilter.java:167)
> at org.springframework.security.web.context.SecurityContextPersistenceFilt
> er.doFilter(SecurityContextPersistenceFilter.java:91)
> at org.geoserver.security.filter.GeoServerSecurityContextPersis
> tenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
> at org.springframework.security.web.FilterChainProxy.doFilterInternal(
> FilterChainProxy.java:213)
> at org.springframework.security.web.FilterChainProxy.doFilter(
> FilterChainProxy.java:176)
> at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(
> GeoServerSecurityFilterChainProxy.java:152)
> at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(
> DelegatingFilterProxy.java:346)
> at org.springframework.web.filter.DelegatingFilterProxy.doFilter(
> DelegatingFilterProxy.java:262)
> at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
> at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
> at org.geoserver.filters.SessionDebugFilter.doFilter(
> SessionDebugFilter.java:48)
> at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
> at org.springframework.web.filter.CharacterEncodingFilter.
> doFilterInternal(CharacterEncodingFilter.java:121)
> at org.springframework.web.filter.OncePerRequestFilter.
> doFilter(OncePerRequestFilter.java:107)
> at org.eclipse.jetty.servlet.ServletHandler.doHandle(
> ServletHandler.java:453)
> at org.eclipse.jetty.server.handler.ScopedHandler.handle(
> ScopedHandler.java:137)
> at org.eclipse.jetty.security.SecurityHandler.handle(
> SecurityHandler.java:560)
> at org.eclipse.jetty.server.session.SessionHandler.
> doHandle(SessionHandler.java:231)
> at org.eclipse.jetty.server.handler.ContextHandler.
> doHandle(ContextHandler.java:1072)
> at org.eclipse.jetty.servlet.ServletHandler.doScope(
> ServletHandler.java:382)
> doScope(SessionHandler.java:193)
> doScope(ContextHandler.java:1006)
> ScopedHandler.java:135)
> at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(
> ContextHandlerCollection.java:255)
> at org.eclipse.jetty.server.handler.HandlerCollection.
> handle(HandlerCollection.java:154)
> at org.eclipse.jetty.server.handler.HandlerWrapper.handle(
> HandlerWrapper.java:116)
> at org.eclipse.jetty.server.Server.handle(Server.java:365)
> at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(
> AbstractHttpConnection.java:485)
> at org.eclipse.jetty.server.AbstractHttpConnection.content(
> AbstractHttpConnection.java:937)
> at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.content(
> AbstractHttpConnection.java:998)
> at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:856)
> at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:240)
> at org.eclipse.jetty.server.AsyncHttpConnection.handle(
> AsyncHttpConnection.java:82)
> at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(
> SelectChannelEndPoint.java:628)
> at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(
> SelectChannelEndPoint.java:52)
> at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(
> QueuedThreadPool.java:608)
> at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(
> QueuedThreadPool.java:543)
> Caused by: java.lang.reflect.InvocationTargetException
> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
> at sun.reflect.NativeMethodAccessorImpl.invoke(
> NativeMethodAccessorImpl.java:62)
> at sun.reflect.DelegatingMethodAccessorImpl.invoke(
> DelegatingMethodAccessorImpl.java:43)
> at java.lang.reflect.Method.invoke(Method.java:498)
> RequestListenerInterface.java:258)
> ... 108 more
> Caused by: java.lang.NoSuchMethodError: org.postgresql.core.
> BaseConnection.getPreferQueryMode()Lorg/postgresql/jdbc/PreferQueryMode;
> at org.postgresql.jdbc.PgStatement.executeCachedSql(PgStatement.java:273)
> at org.postgresql.jdbc.PgStatement.executeWithFlags(PgStatement.java:269)
> at org.postgresql.jdbc.PgStatement.executeQuery(PgStatement.java:236)
> at org.apache.commons.dbcp.DelegatingStatement.executeQuery(
> DelegatingStatement.java:208)
> at org.apache.commons.dbcp.PoolableConnectionFactory.validateConnection(
> PoolableConnectionFactory.java:658)
> at org.apache.commons.dbcp.BasicDataSource.validateConnectionFactory(
> BasicDataSource.java:1558)
> at org.apache.commons.dbcp.BasicDataSource.createPoolableConnectionFactor
> y(BasicDataSource.java:1545)
> at org.apache.commons.dbcp.BasicDataSource.createDataSource(
> BasicDataSource.java:1388)
> at org.apache.commons.dbcp.BasicDataSource.getConnection(
> BasicDataSource.java:1044)
> at org.geotools.data.jdbc.datasource.AbstractManageableDataSource.
> getConnection(AbstractManageableDataSource.java:48)
> at org.geotools.jdbc.JDBCDataStore.createConnection(
> JDBCDataStore.java:2067)
> at org.geotools.jdbc.JDBCDataStore.createTypeNames(JDBCDataStore.java:978)
> at org.geotools.data.store.ContentDataStore.getTypeNames(
> ContentDataStore.java:308)
> at org.vfny.geoserver.util.DataStoreUtils.getDataAccess(
> DataStoreUtils.java:97)
> at org.geoserver.catalog.ResourcePool.getDataStore(ResourcePool.java:636)
> at org.geoserver.catalog.impl.DataStoreInfoImpl.getDataStore(
> DataStoreInfoImpl.java:38)
> at org.geoserver.web.data.store.DataAccessNewPage.onSaveDataStore(
> DataAccessNewPage.java:95)
> at org.geoserver.web.data.store.AbstractDataAccessPage$1.onSubmit(
> AbstractDataAccessPage.java:165)
> at org.apache.wicket.ajax.markup.html.form.AjaxSubmitLink$1.
> onSubmit(AjaxSubmitLink.java:110)
> at org.apache.wicket.ajax.form.AjaxFormSubmitBehavior$
> AjaxFormSubmitter.onSubmit(AjaxFormSubmitBehavior.java:215)
> at org.apache.wicket.markup.html.form.Form.delegateSubmit(Form.java:1307)
> at org.apache.wicket.markup.html.form.Form.process(Form.java:974)
> at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:795)
> at org.apache.wicket.ajax.form.AjaxFormSubmitBehavior.onEvent(
> AjaxFormSubmitBehavior.java:171)
> at org.apache.wicket.ajax.AjaxEventBehavior.respond(
> AjaxEventBehavior.java:155)
> at org.apache.wicket.ajax.AbstractDefaultAjaxBehavior.onRequest(
> AbstractDefaultAjaxBehavior.java:588)
> ... 113 more
> -*Note: On geoserver, I have no store and when I try to re-create one, I
> get the above error.*
> *At first installation, I had a store called geonode which was enabled,
> but still could not upload vector layer.*
> Your help debugging this is greatly appreciated,
> Jodom.
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170714/38abe5b6/attachment-0001.html>
More information about the geonode-users
