[GeoNode-users] Limit amount of people results
Naresh N
naresh919 at gmail.com
Thu Jul 13 05:14:07 PDT 2017
Dear Toni,
Thanks a lot for response. Now i could able to fix by doing following
changes
1. Settings.py CLIENT_RESULTS_LIMIT = 10 and API_LIMIT_PER_PAGE = 10
2. In /geonode/api/api.py mnewly added max_limit =10 is added in meta
class of GroupResource and Profile resouce
3. In /geonode/api/resourcebase_api.py max_limit value is changed from
NONE to 10 and limit value 10
Thanks again for support
Best Regards,
Naresh
On Thu, Jul 13, 2017 at 1:46 PM, Toni Schönbuchner <
toni.schoenbuchner at csgis.de> wrote:
> Dear Naresh,
> sorry, please ignore what I´ve written below.After a second look I don´t
> think it will work as the angular module is
> initated before. Means the second way, changing the search script to your
> needs might be the way to go.
> cheers,
> toni
> Anfang der weitergeleiteten Nachricht:
> *Von: *geonode-users-request at lists.osgeo.org
> *Betreff: **geonode-users Digest, Vol 30, Issue 50*
> *Datum: *13. Juli 2017 um 08:25:39 MESZ
> *An: *geonode-users at lists.osgeo.org
> *Antwort an: *geonode-users at lists.osgeo.org
> from a quick look it´s the same angular controller for both api requests.
> Means all use the same max var. If you like to have the amount different
> on peoples page only you could give a try to override
> this variable in the peoples template. From naming I think it should be
> profile_list.html
> here I would try to add a new var after line 28
> https://github.com/GeoNode/geonode/blob/master/geonode/
> people/templates/people/profile_list.html#L28<https://
> github.com/GeoNode/geonode/blob/master/geonode/people/
> templates/people/profile_list.html#L28>
> <script type="text/javascript">
> CLIENT_RESULTS_LIMIT = 10;
> </script>
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170713/2f160a02/attachment.html>
More information about the geonode-users
