[GeoNode-users] ACTIVITY Feed - Option
Simone Dalmasso
simone.dalmasso at gmail.com
Fri Jul 14 00:33:23 PDT 2017
Sorry, could you please explain your issue again?
2017-07-13 6:32 GMT+02:00 Naresh N <naresh919 at gmail.com>:
> Dear Simone,
> kindly help me how to set new limit value for People and Groups list
> Best Regards,
> Naresh
> On Wed, Jul 12, 2017 at 4:49 PM, Naresh N <naresh919 at gmail.com> wrote:
>> Dear Simone,
>> After removing the line also ,the user list is not available, it is
>> showing empty.
>> I have reverted the changes i.e commenting the line in url.py and
>> profile_details.html and done changes like as follows in the
>> C:\GeoNode-2.4.x\geonode-2.4.x\geonode\templates\actstream\actor.html ,
>> now it is working fine
>> *{% if user.is_superuser or request.user == actor %} *after line number
>> 24
>> It may not be professional way to do, I did not get any other option, so
>> with the following now it is working fine.
>> Once again thanks for the support.
>> *Kindly help me in following new issue*
>> How to limit the no of results showing to max 10 only , as of now default
>> limit is 100.
>> I mean in following url limit is 100
>> http://192.168.197.108/people/?limit=100&offset=0
>> To do the change the limit value in settings.py i have
>> modified CLIENT_RESULTS_LIMIT =10 and max_limit=10 in the file
>> GeoNode-2.4.x\geonode-2.4.x\geonode\api\resourcebase_api.py
>> After doing above changes layers,maps,documents is working as per the new
>> updated limit value 10,.
>> However people,groups url showing like http://192.168.197.108/people/
>> ?limit=10&offset=0,http://192.168.197.108/groups/?limit=10&offset=0, but
>> if you change the limit value in url more than 10,
>> it is displaying the result more than 10(as per given limit value)
>> Please kindly suggest me how to enable new limit value to People, Groups
>> list also
>> Best Regards,
>> Naresh
>> On Wed, Jul 12, 2017 at 12:53 PM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> Sorry. Commenting the line in the HTML is not enough. You have to remove
>>> it.
>>> Il giorno mer 12 lug 2017 alle 08:18 Naresh N <naresh919 at gmail.com> ha
>>> scritto:
>>>> Dear Simone,
>>>> Thanks for the response. After commenting following two lines, it did
>>>> not working as per expected.
>>>> https://github.com/GeoNode/geonode/blob/master/geonode/peopl
>>>> e/templates/people/profile_detail.html#L130 and
>>>> https://github.com/GeoNode/geonode/blob/master/geonode/urls.py#L86.
>>>> In this case also Not able to see the user list,please find the below
>>>> screenshot for reference
>>>> [image: Inline image 1]
>>>> Please find below my requirement, I want on click of People, the user
>>>> list should be available as follows and there should not be no option to
>>>> see the activity feed of the user.
>>>> [image: Inline image 2]
>>>> Even if user know direct url of the activity feed, he should not
>>>> able to see the activity feed, I mean with the url
>>>> http://192.168.197.108/activity/actors/31/5/ now I am able to see the
>>>> activity feed. So even with direct url user should not see activity feed
>>>> Please help me to do the task.
>>>> Best Regards,
>>>> Naresh. N
>>>> On Tue, Jul 11, 2017 at 6:16 PM, Simone Dalmasso <
>>>>> You have to comment out the activity button in the template of profile
>>>>> detail too https://github.com/GeoNode/geonode/blob/master/geonode/p
>>>>> eople/templates/people/profile_detail.html#L130
>>>>> 2017-07-11 14:37 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>> Dear Simone,
>>>>>> Thanks for quick response
>>>>>> I have commented the line 86 i.e. (r'^activity/',
>>>>>> include('actstream.urls')), then we are not able to see peoples profile
>>>>>> list. I want only activity feed should not be visible/accessible to the
>>>>>> users. Please suggest
>>>>>> Best Regards,
>>>>>> Naresh
>>>>>> On Tue, Jul 11, 2017 at 5:57 PM, Simone Dalmasso <
>>>>>>> Hi, you could exclude the activity urls by commenting this line
>>>>>>> 2017-07-11 14:08 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>> Dear All,
>>>>>>>> Please any body can share how to disable activity stream option
>>>>>>>> for all the users.
>>>>>>>> With Best Regards,
>>>>>>>> Naresh
>>>>>>>> On Wed, Jun 28, 2017 at 9:24 AM, Naresh N <naresh919 at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> Dear Fabiani,
>>>>>>>>> Thanks for sharing the links, I will go through the links
>>>>>>>>> Best Regards,
>>>>>>>>> Naresh
>>>>>>>>> On Tue, Jun 27, 2017 at 8:41 PM, Alessio Fabiani <
>>>>>>>>> alessio.fabiani at geo-solutions.it> wrote:
>>>>>>>>>> Hi,
>>>>>>>>>> recently I have rebuilt almost from scratch the source code of
>>>>>>>>>> GeoExplorer and aligned with live code in order to make it updatable.
>>>>>>>>>> You can find the GeoNode module here
>>>>>>>>>> https://github.com/GeoNode/django-geoexplorer
>>>>>>>>>> It actually depends on this one
>>>>>>>>>> https://github.com/geosolutions-it/geoexplorer/tree/geonode-
>>>>>>>>>> geoexplorer
>>>>>>>>>> which, again, references other git submodules.
>>>>>>>>>> See instructions here
>>>>>>>>>> https://github.com/GeoNode/django-geoexplorer#geoexplorer-sources
>>>>>>>>>> also you need to download sources by uasing
>>>>>>>>>> git submodule sync
>>>>>>>>>> Regards,
>>>>>>>>>> Alessio Fabiani
>>>>>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>>>>>> http://goo.gl/it488V for more information.
>>>>>>>>>> Ing. Alessio Fabiani
>>>>>>>>>> @alfa7691
>>>>>>>>>> Founder/Technical Lead
>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>> Via di Montramito 3/A
>>>>>>>>>> 55054 Massarosa (LU)
>>>>>>>>>> Italy
>>>>>>>>>> phone: +39 0584 962313 <+39%200584%20962313>
>>>>>>>>>> fax: +39 0584 1660272 <+39%200584%20166%200272>
>>>>>>>>>> mob: +39 331 6233686 <+39%20331%20623%203686>
>>>>>>>>>> http://www.geo-solutions.it
>>>>>>>>>> http://twitter.com/geosolutions_it
>>>>>>>>>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>>>>>>>>>> Le informazioni contenute in questo messaggio di posta
>>>>>>>>>> elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente
>>>>>>>>>> riservate. Il loro utilizzo è consentito esclusivamente al destinatario del
>>>>>>>>>> messaggio, per le finalità indicate nel messaggio stesso. Qualora riceviate
>>>>>>>>>> questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente
>>>>>>>>>> di darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>>>>>>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>>>>>>>>>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>>>>>>>>>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>>>>>>>>>> principi dettati dal D.Lgs. 196/2003.
>>>>>>>>>> The information in this message and/or attachments, is intended
>>>>>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>>>>>> immediately the sender by telephone, fax or e-mail and delete the
>>>>>>>>>> information in this message that has been received in error. The sender
>>>>>>>>>> does not give any warranty or accept liability as the content, accuracy or
>>>>>>>>>> completeness of sent messages and accepts no responsibility for changes
>>>>>>>>>> made after they were sent or for other risks which arise as a result of
>>>>>>>>>> e-mail transmission, viruses, etc.
>>>>>>>>>> On Tue, Jun 27, 2017 at 2:40 PM, Simone Dalmasso <
>>>>>>>>>>> Geoexplorer is quite difficult to modify, and I don't know where
>>>>>>>>>>> you could do such change.
>>>>>>>>>>> Here's a very minimal documentation on how to make geoexplorer
>>>>>>>>>>> work in dev mode but then not sure how you can compile it back and deploy
>>>>>>>>>>> http://docs.geonode.org/en/master/tutorials/devel/dev
>>>>>>>>>>> el_debug/geoexplorer.html?highlight=geoexplorer
>>>>>>>>>>> 2017-06-27 14:36 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>> Yes as told functionality is working properly based on
>>>>>>>>>>>> permissions as geoserver handling the styling option. But if user is not
>>>>>>>>>>>> having permission if he does the style change,after that showing error
>>>>>>>>>>>> message like as follows, user time will waste it is better if we disable
>>>>>>>>>>>> based on previliges. How Edit option is implemented, kindly tell us where i
>>>>>>>>>>>> need to modify the functionality
>>>>>>>>>>>> Thanks&Regards,
>>>>>>>>>>>> Naresh
>>>>>>>>>>>> On Tue, Jun 27, 2017 at 5:51 PM, Simone Dalmasso <
>>>>>>>>>>>>> Not sure it's easily achievable as would require geoexplorer
>>>>>>>>>>>>> development. Although the permission should be respected by geoserver
>>>>>>>>>>>>> anyway,
>>>>>>>>>>>>> 2017-06-27 14:13 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>> Dear Simone and all,
>>>>>>>>>>>>>> One more query, please help me to do
>>>>>>>>>>>>>> If user has option for visualizing the layer and not having
>>>>>>>>>>>>>> style option, then also Style icon is enabled mode in Map and Layer Window
>>>>>>>>>>>>>> of GeoNode interface. Can we grey out Style icon in case if user has not
>>>>>>>>>>>>>> having permission for add/edit style
>>>>>>>>>>>>>> *NOTE: This kind of enabling/disabling icon is happening for
>>>>>>>>>>>>>> Editing data icon. In following Edit is disable mode if user has not having
>>>>>>>>>>>>>> edit option. How ever for Style it is not happening*
>>>>>>>>>>>>>> * [image: Inline image 1]*
>>>>>>>>>>>>>> How to enable/disable style icon based on user privileges for
>>>>>>>>>>>>>> styling the data
>>>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>> On Tue, Jun 27, 2017 at 4:38 PM, Naresh N <
>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>> Thanks for the response, I will go through the shared link
>>>>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>> On Tue, Jun 27, 2017 at 3:12 PM, Simone Dalmasso <
>>>>>>>>>>>>>>>> Hi, GeoNode does not ship this but you can develop it. This
>>>>>>>>>>>>>>>> is the app geonode is using to implement the activity stream.
>>>>>>>>>>>>>>>> https://github.com/justquick/django-activity-stream
>>>>>>>>>>>>>>>> 2017-06-27 11:35 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>>>>> Dear All,
>>>>>>>>>>>>>>>>> Is it possible Activity Feed of the People should be
>>>>>>>>>>>>>>>>> visible to other users based on user settings?
>>>>>>>>>>>>>>>>> I mean in following screenshot , I could able to see the
>>>>>>>>>>>>>>>>> activity of jamesboy. But is it possible we can provide some option to
>>>>>>>>>>>>>>>>> user to share his Activity Feed with other based on his choice. How to
>>>>>>>>>>>>>>>>> do it? Kindly help me to do.
>>>>>>>>>>>>>>>>> Thanks&Regards,
>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>> Simone
>>>>>>>>>>> Simone
>>>>>>> Simone
>>>>> Simone
>>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170714/9f1d8464/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170714/9f1d8464/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170714/9f1d8464/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170714/9f1d8464/attachment-0007.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170714/9f1d8464/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170714/9f1d8464/attachment-0009.png>
More information about the geonode-users
