[GeoNode-users] ACTIVITY Feed - Option
    Naresh N
    naresh919 at gmail.com
    Fri Jul 14 01:23:46 PDT 2017
Dear Simone,
 In present GeoNode setup default the no. of results display is 100, I mean
 http://192.168.197.108/layers/?limit=100&offset=0
 http://192.168.197.108/maps/?limit=100&offset=0
 http://192.168.197.108/groups/?limit=100&offset=0
http://192.168.197.108/people/?limit=100&offset=0
I want to change default limit of 100 to 10, Now I have done the following
changes and it is working fine
1. Settings.py CLIENT_RESULTS_LIMIT = *10* and API_LIMIT_PER_PAGE = *10*
2. In  /geonode/api/api.py  newly added *max_limit =10* is added in meta
class of  GroupResource and Profile resouce
3. In  /geonode/api/resourcebase_api.py  *max_limit* value is changed from
NONE to *10* and *limit value to 10  *
Thanks for showing interest and know the issue. Please suggest ,is any
other better method is available to fix the issue.
With Best Regards,
Naresh
On Fri, Jul 14, 2017 at 1:03 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Sorry, could you please explain your issue again?
> 2017-07-13 6:32 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>> Dear Simone,
>>  kindly help me  how to set new limit value for People and Groups list
>> Best Regards,
>> Naresh
>> On Wed, Jul 12, 2017 at 4:49 PM, Naresh N <naresh919 at gmail.com> wrote:
>>> Dear Simone,
>>>      After removing the line  also ,the user list is not available, it
>>> is showing empty.
>>>      I have reverted the changes i.e commenting the line in url.py and
>>> profile_details.html  and done changes like as follows in the
>>>  C:\GeoNode-2.4.x\geonode-2.4.x\geonode\templates\actstream\actor.html
>>> , now it is working fine
>>> *{% if user.is_superuser or request.user == actor %} *after line number
>>> 24
>>>  It may not be professional way to do, I did not get any other option,
>>> so with the following now it is working fine.
>>>  Once again thanks for the support.
>>> *Kindly help me in following new issue*
>>> How to limit the no of results showing to max 10 only , as of now
>>> default limit is 100.
>>> I mean in following url limit is 100
>>> To do the change the limit value in settings.py  i have
>>> modified CLIENT_RESULTS_LIMIT =10   and    max_limit=10 in the file
>>> GeoNode-2.4.x\geonode-2.4.x\geonode\api\resourcebase_api.py
>>> After doing above changes layers,maps,documents is working as per the
>>> new updated limit value 10,.
>>> However people,groups url showing like http://192.168.197.108/people/
>>> ?limit=10&offset=0,http://192.168.197.108/groups/?limit=10&offset=0,
>>> but if you change the limit value in url more than 10,
>>>  it is displaying the result more than 10(as per given limit value)
>>> Please kindly suggest me how to enable  new limit value to People,
>>> Groups list also
>>> Best Regards,
>>> Naresh
>>> On Wed, Jul 12, 2017 at 12:53 PM, Simone Dalmasso <
>>> simone.dalmasso at gmail.com> wrote:
>>>> Sorry. Commenting the line in the HTML is not enough. You have to
>>>> remove it.
>>>> Il giorno mer 12 lug 2017 alle 08:18 Naresh N <naresh919 at gmail.com> ha
>>>> scritto:
>>>>> Dear Simone,
>>>>>   Thanks for the response. After commenting following two lines, it
>>>>> did not working as per expected.
>>>>> https://github.com/GeoNode/geonode/blob/master/geonode/peopl
>>>>> e/templates/people/profile_detail.html#L130 and
>>>>> https://github.com/GeoNode/geonode/blob/master/geonode/urls.py#L86.
>>>>> In this case also Not able to see the user list,please find the below
>>>>> screenshot for reference
>>>>> [image: Inline image 1]
>>>>> Please find below my requirement, I want on click of People, the user
>>>>> list should be available as follows and there should not be no option to
>>>>> see the activity feed of the user.
>>>>> [image: Inline image 2]
>>>>>   Even if user know direct url of the activity feed, he should not
>>>>> able to see the activity feed, I mean with the url
>>>>> http://192.168.197.108/activity/actors/31/5/  now I am able to see
>>>>> the activity feed. So even with direct url user should not see activity feed
>>>>> Please help me to do the task.
>>>>> Best Regards,
>>>>> Naresh. N
>>>>> On Tue, Jul 11, 2017 at 6:16 PM, Simone Dalmasso <
>>>>>> You have to comment out the activity button in the template of
>>>>>> profile detail too https://github.com/GeoNode
>>>>>> /geonode/blob/master/geonode/people/templates/people/profile
>>>>>> _detail.html#L130
>>>>>> 2017-07-11 14:37 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>> Dear Simone,
>>>>>>> Thanks for quick response
>>>>>>>  I have commented the line 86 i.e. (r'^activity/',
>>>>>>> include('actstream.urls')), then we are not able to see peoples profile
>>>>>>> list. I want only activity feed should not be visible/accessible to the
>>>>>>> users. Please suggest
>>>>>>> Best Regards,
>>>>>>> Naresh
>>>>>>> On Tue, Jul 11, 2017 at 5:57 PM, Simone Dalmasso <
>>>>>>>> Hi, you could exclude the activity urls by commenting this line
>>>>>>>> 2017-07-11 14:08 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>> Dear All,
>>>>>>>>>  Please any body can share how to disable activity stream option
>>>>>>>>> for all the users.
>>>>>>>>> With Best Regards,
>>>>>>>>> Naresh
>>>>>>>>> On Wed, Jun 28, 2017 at 9:24 AM, Naresh N <naresh919 at gmail.com>
>>>>>>>>> wrote:
>>>>>>>>>> Dear Fabiani,
>>>>>>>>>>  Thanks for sharing the links, I will go through the links
>>>>>>>>>> Best Regards,
>>>>>>>>>> Naresh
>>>>>>>>>> On Tue, Jun 27, 2017 at 8:41 PM, Alessio Fabiani <
>>>>>>>>>> alessio.fabiani at geo-solutions.it> wrote:
>>>>>>>>>>> Hi,
>>>>>>>>>>> recently I have rebuilt almost from scratch the source code of
>>>>>>>>>>> GeoExplorer and aligned with live code in order to make it updatable.
>>>>>>>>>>> You can find the GeoNode module here
>>>>>>>>>>> https://github.com/GeoNode/django-geoexplorer
>>>>>>>>>>> It actually depends on this one
>>>>>>>>>>> https://github.com/geosolutions-it/geoexplorer/tree/geonode-
>>>>>>>>>>> geoexplorer
>>>>>>>>>>> which, again, references other git submodules.
>>>>>>>>>>> See instructions here
>>>>>>>>>>> https://github.com/GeoNode/django-geoexplorer#geoexplorer-so
>>>>>>>>>>> urces
>>>>>>>>>>> also you need to download sources by uasing
>>>>>>>>>>> git submodule sync
>>>>>>>>>>> Regards,
>>>>>>>>>>> Alessio Fabiani
>>>>>>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>>>>>>> http://goo.gl/it488V for more information.
>>>>>>>>>>> Ing. Alessio Fabiani
>>>>>>>>>>> @alfa7691
>>>>>>>>>>> Founder/Technical Lead
>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>> Via di Montramito 3/A
>>>>>>>>>>> 55054  Massarosa (LU)
>>>>>>>>>>> Italy
>>>>>>>>>>> phone: +39 0584 962313 <+39%200584%20962313>
>>>>>>>>>>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>>>>>>>>>>> mob:   +39 331 6233686 <+39%20331%20623%203686>
>>>>>>>>>>> http://www.geo-solutions.it
>>>>>>>>>>> http://twitter.com/geosolutions_it
>>>>>>>>>>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>>>>>>>>>>> Le informazioni contenute in questo messaggio di posta
>>>>>>>>>>> elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente
>>>>>>>>>>> riservate. Il loro utilizzo è consentito esclusivamente al destinatario del
>>>>>>>>>>> messaggio, per le finalità indicate nel messaggio stesso. Qualora riceviate
>>>>>>>>>>> questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente
>>>>>>>>>>> di darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>>>>>>>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>>>>>>>>>>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>>>>>>>>>>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>>>>>>>>>>> principi dettati dal D.Lgs. 196/2003.
>>>>>>>>>>> The information in this message and/or attachments, is intended
>>>>>>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>>>>>>> immediately the sender by telephone, fax or e-mail and delete the
>>>>>>>>>>> information in this message that has been received in error. The sender
>>>>>>>>>>> does not give any warranty or accept liability as the content, accuracy or
>>>>>>>>>>> completeness of sent messages and accepts no responsibility  for changes
>>>>>>>>>>> made after they were sent or for other risks which arise as a result of
>>>>>>>>>>> e-mail transmission, viruses, etc.
>>>>>>>>>>> On Tue, Jun 27, 2017 at 2:40 PM, Simone Dalmasso <
>>>>>>>>>>>> Geoexplorer is quite difficult to modify, and I don't know
>>>>>>>>>>>> where you could do such change.
>>>>>>>>>>>> Here's a very minimal documentation on how to make geoexplorer
>>>>>>>>>>>> work in dev mode but then not sure how you can compile it back and deploy
>>>>>>>>>>>> http://docs.geonode.org/en/master/tutorials/devel/dev
>>>>>>>>>>>> el_debug/geoexplorer.html?highlight=geoexplorer
>>>>>>>>>>>> 2017-06-27 14:36 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>  Yes as told functionality is working properly based on
>>>>>>>>>>>>> permissions as geoserver handling the styling option. But if user is not
>>>>>>>>>>>>> having permission if he does the style change,after that showing error
>>>>>>>>>>>>> message like as follows, user time will waste it is better if we disable
>>>>>>>>>>>>> based on previliges. How Edit option is implemented, kindly tell us where i
>>>>>>>>>>>>> need to modify the functionality
>>>>>>>>>>>>> Thanks&Regards,
>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>> On Tue, Jun 27, 2017 at 5:51 PM, Simone Dalmasso <
>>>>>>>>>>>>>> Not sure it's easily achievable as would require geoexplorer
>>>>>>>>>>>>>> development. Although the permission should be respected by geoserver
>>>>>>>>>>>>>> anyway,
>>>>>>>>>>>>>> 2017-06-27 14:13 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>>> Dear Simone and all,
>>>>>>>>>>>>>>>   One more query, please help me to do
>>>>>>>>>>>>>>>  If user has option for visualizing the layer and not having
>>>>>>>>>>>>>>> style option, then also Style icon is enabled mode in Map and Layer Window
>>>>>>>>>>>>>>> of GeoNode interface. Can we grey out Style icon in case if user has not
>>>>>>>>>>>>>>> having permission for add/edit style
>>>>>>>>>>>>>>> *NOTE: This kind of enabling/disabling icon is happening for
>>>>>>>>>>>>>>> Editing data icon. In following Edit is disable mode if user has not having
>>>>>>>>>>>>>>> edit option. How ever for Style it is not happening*
>>>>>>>>>>>>>>> *   [image: Inline image 1]*
>>>>>>>>>>>>>>> How to enable/disable style icon based on user privileges
>>>>>>>>>>>>>>> for styling the data
>>>>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>> On Tue, Jun 27, 2017 at 4:38 PM, Naresh N <
>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>   Thanks for the response, I will go through the shared link
>>>>>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>> On Tue, Jun 27, 2017 at 3:12 PM, Simone Dalmasso <
>>>>>>>>>>>>>>>>> Hi, GeoNode does not ship this but you can develop it.
>>>>>>>>>>>>>>>>> This is the app geonode is using to implement the activity stream.
>>>>>>>>>>>>>>>>> https://github.com/justquick/django-activity-stream
>>>>>>>>>>>>>>>>> 2017-06-27 11:35 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>>>>>> Dear All,
>>>>>>>>>>>>>>>>>>    Is it possible Activity Feed of the People  should be
>>>>>>>>>>>>>>>>>> visible to other users based on user settings?
>>>>>>>>>>>>>>>>>>  I mean in following screenshot , I could able to see the
>>>>>>>>>>>>>>>>>> activity of jamesboy.  But is it possible we can provide some option to
>>>>>>>>>>>>>>>>>>  user to share his  Activity  Feed with other based on his choice. How to
>>>>>>>>>>>>>>>>>> do it? Kindly help me to do.
>>>>>>>>>>>>>>>>>> Thanks&Regards,
>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>> Simone
>>>>>>>>>>>> Simone
>>>>>>>> Simone
>>>>>> Simone
>>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170714/312a6de3/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170714/312a6de3/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170714/312a6de3/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170714/312a6de3/attachment-0007.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170714/312a6de3/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170714/312a6de3/attachment-0009.png>
More information about the geonode-users
