[GeoNode-users] GeoNode 2.4 Proxy 500 Error "Connection Refused" (OSGEOLIVE DVD Image)
Sampson, David (EC)
david.sampson at canada.ca
Wed Jul 26 06:12:07 PDT 2017
Hey Folks,
I am currently having issues with a test install of GeoNode 2.4 related to a 500 proxy Error in the Maps app. I have made a number of change to various config files to get the majority of functionality working on an external IP address despite the missing tool for "geonode-updateip". I hope the proxy is the final issue. Any help is appreciated.
Attached documents:
· GeoNodeProxyError.txt
· Local_settings.py
· ApacheErrorWSGI.txt
The Problem:
· From an external IP address access geonode install
· As a logged in, Admin or non-logged in user
· Click on layers: Appropriate layer appears
· Select Layer: Appropriate layer appears on the interactive map
· Click "Create Map"
· Map application loads with "500 error" dialogue box
· Debug = True
· Error output attached (Note the references to the IP address was replaced with 'MYGEONODESERVERIP')
This issue also occurs under the following scenario:
· From home page
· Click on Maps
· Click on Create Map
GeoServer Link status:
· http://SERVER/geoserver (fails)
· http://SERVER:8082/geoserver (passes)
Proxy Link status:
· http://SERVER/proxy (The proxy service requires a URL-encoded URL as a parameter)
· http://SERVER/proxy/?url=http%3A%2F%2FMYGEONODESERVERIP%3A8082%2Fgeoserver%2Fwms%3FSERVICE%3DWMS%26REQUEST%3DGetCapabilities%26TILED%3Dtrue%26VERSION%3D1.1.1
o Error At Proxy, Errno 111 Connection Refused
o Exception Location: /usr/lib/python2.7/socket.py in create_connection, line 575
o Proxy Allowed Hosts: (Not sure why so many duplicate GEOSERVERIP entries. Note these point to public IP)
['127.0.0.1',
'localhost',
'::1',
'MYGEONODESERVERIP',
'MYGEONODESERVERIP',...]
o PROXY_URL '/proxy/?url='
Apache Error Log:
· Looks like a WGSI error.
· Full Log attached to message
· First and last lines of error:
[Wed Jul 26 07:55:19.835894 2017] [wsgi:error] [pid 1181] Internal Server Error: /proxy/
[Wed Jul 26 07:55:19.851453 2017] [wsgi:error] [pid 1181] error: [Errno 111] Connection refused
The Setup:
Due to various issues with installing GeoNode from scratch on a stand alone Ubuntu VM I have decided to use the following setup. Once I get this working to demo to my team then I can tackle the bigger issues around GeoServer Ubuntu installation.
· Host system: Ubuntu 16.04
· Virtual environment: Virtualbox 5.0.40
· Virtual Machine: OSGEO Live DVD ISO image installed to HD
· Django version: 1.6.11
· Python Version: 2.7.12
· VM is placed in network DMZ for public access while we wait for real servers
Attempted fixes:
· Regularly clearing browser cache upon apache restarts
· Settings.py:
o Proxy Allowed included public IP (then removed to keep settings.py un-poluted
· Local_settings.py (Attached and IP modified)
o Tried editing OGC_SERVER section
§ I had to comment out LOG_FILE since the settings were not letting GeoNode start up on Apache restart
· geonode-updateip (fails, no such tool installed on OsgeoLive that I could find)
Other Reading:
· https://lists.osgeo.org/pipermail/geonode-users/2015-June/000434.html
· http://osgeo-org.1560.x6.nabble.com/proxy-error-in-geoexplorer-when-adding-wms-server-tt5278365.html#none
· https://github.com/GeoNode/geonode/issues/2090
Any other ideas or missing information?
David Sampson
Free Agent - IN·spire, NRCan's Innovation Hub
Posted to,
National Environmental Emergency Centre (NEEC)
Environment and Climate Change Canada / Government of Canada
David.sampson at canada.ca<mailto:David.sampson at canada.ca>
Agent libre - IN·spire, Carrefour d'Innovation de RNCan
Affecté à,
Centre national des urgences environnementales (CNUE)
Environnement et Changement climatique Canada / Gouvernement du Canada
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170726/e3115d92/attachment.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170726/e3115d92/attachment.txt>
Type: application/octet-stream
Desc: local_settings.py
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170726/e3115d92/attachment.obj>
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170726/e3115d92/attachment-0001.txt>
More information about the geonode-users
