[GeoNode-users] GeoNode 2.4 Proxy 500 Error "Connection Refused" (OSGEOLIVE DVD Image)
Simone Dalmasso simone.dalmasso at gmail.com
Wed Jul 26 06:43:25 PDT 2017
Hi, the OsGEO live is not meant to (and cannot) be used in production but
for testing as some of the functionalities (like permissions) are disabled
there.
The best way to install geonode is using apt-get on ubuntu 16.04
Regards
2017-07-26 15:12 GMT+02:00 Sampson, David (EC) <david.sampson at canada.ca>:
> Hey Folks,
> I am currently having issues with a test install of GeoNode 2.4 related to
> a 500 proxy Error in the Maps app. I have made a number of change to
> various config files to get the majority of functionality working on an
> external IP address despite the missing tool for “geonode-updateip”. I hope
> the proxy is the final issue. Any help is appreciated.
> Attached documents:
> ·        GeoNodeProxyError.txt
> ·        Local_settings.py
> ·        ApacheErrorWSGI.txt
> The Problem:
> ·        From an external IP address access geonode install
> ·        As a logged in, Admin or non-logged in user
> ·        Click on layers: Appropriate layer appears
> ·        Select Layer: Appropriate layer appears on the interactive map
> ·        Click “Create Map”
> ·        Map application loads with “500 error” dialogue box
> ·        Debug = True
> ·        Error output attached (Note the references to the IP address was
> replaced with ‘MYGEONODESERVERIP’)
> This issue also occurs under the following scenario:
> ·        From home page
> ·        Click on Maps
> ·        Click on Create Map
> GeoServer Link status:
> ·        http://SERVER/geoserver (fails)
> ·        http://SERVER:8082/geoserver (passes)
> Proxy Link status:
> ·        http://SERVER/proxy (The proxy service requires a URL-encoded
> URL as a parameter)
> ·        http://SERVER/proxy/?url=http%3A%2F%2FMYGEONODESERVERIP%
> 3A8082%2Fgeoserver%2Fwms%3FSERVICE%3DWMS%26REQUEST%
> 3DGetCapabilities%26TILED%3Dtrue%26VERSION%3D1.1.1
> o   Error At Proxy, Errno 111 Connection Refused
> o   Exception Location: /usr/lib/python2.7/socket.py in
> create_connection, line 575
> o   Proxy Allowed Hosts: (Not sure why so many duplicate GEOSERVERIP
> entries. Note these point to public IP)
> ['127.0.0.1',
> 'localhost',
> '::1',
> 'MYGEONODESERVERIP',
> 'MYGEONODESERVERIP',…]
> o   PROXY_URL '/proxy/?url='
> Apache Error Log:
> ·        Looks like a WGSI error.
> ·        Full Log attached to message
> ·        First and last lines of error:
> [Wed Jul 26 07:55:19.835894 2017] [wsgi:error] [pid 1181] Internal Server
> Error: /proxy/
> [Wed Jul 26 07:55:19.851453 2017] [wsgi:error] [pid 1181] error: [Errno
> 111] Connection refused
> The Setup:
> Due to various issues with installing GeoNode from scratch on a stand
> alone Ubuntu VM I have decided to use the following setup. Once I get this
> working to demo to my team then I can tackle the bigger issues around
> GeoServer Ubuntu installation.
> ·        Host system: Ubuntu 16.04
> ·        Virtual environment: Virtualbox 5.0.40
> ·        Virtual Machine: OSGEO Live DVD ISO image installed to HD
> ·        Django version: 1.6.11
> ·        Python Version: 2.7.12
> ·        VM is placed in network DMZ for public access while we wait for
> real servers
> Attempted fixes:
> ·        Regularly clearing browser cache upon apache restarts
> ·        Settings.py:
> o   Proxy Allowed included public IP (then removed to keep settings.py
> un-poluted
> ·        Local_settings.py (Attached and IP modified)
> o   Tried editing OGC_SERVER section
> §  I had to comment out LOG_FILE since the settings were not letting
> GeoNode start up on Apache restart
> ·        geonode-updateip (fails, no such tool installed on OsgeoLive
> that I could find)
> Other Reading:
> ·        https://lists.osgeo.org/pipermail/geonode-users/2015-
> June/000434.html
> ·        http://osgeo-org.1560.x6.nabble.com/proxy-error-in-
> geoexplorer-when-adding-wms-server-tt5278365.html#none
> ·        https://github.com/GeoNode/geonode/issues/2090
> Any other ideas or missing information?
> David Sampson
> Free Agent – IN·spire, NRCan’s Innovation Hub
> Posted to,
> National Environmental Emergency Centre (NEEC)
> Environment and Climate Change Canada / Government of Canada
> David.sampson at canada.ca
> Agent libre – IN·spire, Carrefour d’Innovation de RNCan
> Affecté à,
> Centre national des urgences environnementales (CNUE)
> Environnement et Changement climatique Canada / Gouvernement du Canada
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170726/bfabb37c/attachment-0001.html>
More information about the geonode-users mailing list
