[GeoNode-users] Security Integration Optimization section - GeoNode in Production
Simone Dalmasso
simone.dalmasso at gmail.com
Tue Jun 6 04:51:58 PDT 2017
Hi, sorry, that is not needed anymore in GeoNode and we will update the doc
soon.
Best
2017-06-06 13:49 GMT+02:00 Naresh N <naresh919 at gmail.com>:
> Dear All,
> Please see the my post and Kindly help to resolve the issue
> On Mon, Jun 5, 2017 at 4:45 PM, Naresh N <naresh919 at gmail.com> wrote:
>> Dear All,
>> *ISSUE-1*
>> I have deployed GeNode in RHEL 7.2 64 bit machine. Now I am configuring
>> for production environment by following the steps mentioned in
>> http://docs.geonode.org/en/master/tutorials/advanced/geonod
>> e_production/production.html.
>> But not able to complete the *Security Integration Optimization
>> section* steps. The following is the issue
>> *WEB-INF/classes/org/geonode/security/geonode_authorize_layer.sql* not
>> able to found in my system. And also not able to fine geoserver.xml
>> Please help me to over come this issue.
>> *ISSUE-2 :*
>> To understand the Database security, I have deployed GeoNode 2.4 in
>> Windows and here i could able to find the file
>> *geonode_authorize_layer.sql. * But when I executed this file though
>> pgadmin-3(Geonode database) it showed following error
>> ERROR: "$1" is declared CONSTANT
>> CONTEXT: compilation of PL/pgSQL function "geonode_authorize_layer" near
>> line 23
>> ( if (user_name IS NULL or user_name = '') then
>> user_name = 'AnonymousUser';
>> end if;)
>> Then I have modified the code - one temp variable is declared in Declare
>> setion and the above code is modified like as follows
>> ( if (user_name IS NULL or user_name = '') then temp =
>> 'AnonymousUser'; else temp=user_nameend if;) and After that rest of the
>> section user_name is replaced with temp.
>> Now modified updated psql command was successfully executed.
>> After that not able to find geoserver.xml and created the new xml with
>> as follows and placed in following location C:\GeoNode-2.4.x\apac
>> he-tomcat-7.0.65\conf\Catalina\localhost\geoserver.xml
>> <Context path="/geoserver"
>> antiResourceLocking="false" >
>> <Parameter name="org.geonode.security.databaseSecurityClient.url"
>> value="jdbc:postgresql://localhost:5454/geonode?user=geonode
>> &password=geonode"/>
>> </Context>
>> But now my *geoserver *is not working. Please kindly suggest to over
>> come this issue.
>> Thanks&Regards,
>> Naresh
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170606/79249b25/attachment-0001.html>
More information about the geonode-users
