[GeoNode-users] Security Integration Optimization section - GeoNode in Production
Naresh N naresh919 at gmail.com
Tue Jun 6 21:56:43 PDT 2017
Dear Simone,
 Thanks for responding. That means in production environment there is no
requirement of database level security of Geoserver? . If we are not
configuring authorization of Geoserver with database level, will this
create any possible attacks to Geoserver by user?
Thanks&Regards,
Naresh
On Tue, Jun 6, 2017 at 5:21 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Hi, sorry, that is not needed anymore in GeoNode and we will update the
> doc soon.
> Best
> 2017-06-06 13:49 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>> Dear All,
>> Please see the my post and Kindly help to resolve the issue
>> On Mon, Jun 5, 2017 at 4:45 PM, Naresh N <naresh919 at gmail.com> wrote:
>>> Dear All,
>>> *ISSUE-1*
>>>  I have deployed GeNode in RHEL 7.2 64 bit machine. Now I am configuring
>>> for production environment by following the steps mentioned in
>>> http://docs.geonode.org/en/master/tutorials/advanced/geonod
>>> e_production/production.html.
>>>  But not able to complete the  *Security Integration Optimization
>>> section* steps. The following is the issue
>>>  *WEB-INF/classes/org/geonode/security/geonode_authorize_layer.sql* not
>>> able to found in my system.  And also not able to fine geoserver.xml
>>> Please help me to over come this issue.
>>> *ISSUE-2 :*
>>> To understand the Database security, I have deployed GeoNode 2.4 in
>>> Windows and  here i could able to find the  file
>>> *geonode_authorize_layer.sql. * But when I executed this file though
>>> pgadmin-3(Geonode database) it showed following error
>>> ERROR:  "$1" is declared CONSTANT
>>> CONTEXT:  compilation of PL/pgSQL function "geonode_authorize_layer"
>>> near line 23
>>> ( if (user_name IS NULL or user_name = '') then
>>>         user_name = 'AnonymousUser';
>>> end if;)
>>> Then I have modified the code - one temp variable is declared in Declare
>>> setion and the above code is modified like as follows
>>>   ( if (user_name IS NULL or user_name = '') then        temp =
>>> 'AnonymousUser';   else temp=user_nameend if;) and  After that rest of the
>>> section user_name is replaced with temp.
>>> Now modified  updated psql command  was successfully executed.
>>> After that not able to find  geoserver.xml and  created the new xml with
>>> as follows and   placed in following location C:\GeoNode-2.4.x\apac
>>> he-tomcat-7.0.65\conf\Catalina\localhost\geoserver.xml
>>> <Context path="/geoserver"
>>>     antiResourceLocking="false" >
>>>   <Parameter name="org.geonode.security.databaseSecurityClient.url"
>>>     value="jdbc:postgresql://localhost:5454/geonode?user=geonode
>>> &password=geonode"/>
>>> </Context>
>>> But now my *geoserver *is not working.  Please kindly suggest to over
>>> come this issue.
>>> Thanks&Regards,
>>> Naresh
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170607/4ea09870/attachment.html>
More information about the geonode-users mailing list
