[GeoNode-users] how to harvest using the remote service?
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Wed Jun 7 05:56:03 PDT 2017
currently not, as far as I know. It could be always possible to implement a
management command to recall via cron or, even better, a celery periodic
task to do it, but this requires non trivial development effort.
Best Regards,
Alessio Fabiani.
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
github <https://github.com/afabiani?tab=overview>
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
On Wed, Jun 7, 2017 at 3:58 AM, Dementia Dimension <hello.dimentio at gmail.com
> wrote:
> Hi.
> I have installed geonode 2.4 and 2.6.
> I'd like to harvest metadata using the remote services.
> I registered a WMS service on remote services but it could import only
> once and it didn't update changed layers from registered services.
> I wondered if GeoNode could harvest meta data periodically or update the
> layers from a remote services registered on geonode.
> Does anyone know about it?
> Thanks, JY.
> 2017-06-07 10:51 GMT+09:00 Dementia Dimension <hello.dimentio at gmail.com>:
>> Hi.
>> I wondered if GeoNode could harvest meta data periodly or update the
>> Thanks, JY.
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170607/9f935240/attachment.html>
More information about the geonode-users
