[GeoNode-users] Installation Problems with version 2.6 on Ubuntu 16.04
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Tue Jun 20 02:45:40 PDT 2017
Not an issue, just a warning. It has been already solved on master.
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
On Tue, Jun 20, 2017 at 7:53 AM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> @Cliff, could you describe again how you install GeoNode? if using apt-get
> you should get errors during installation, please report them here.
> @Israel, that is just an info due to db design, we can clean it up in the
> future but is not an issue.
> 2017-06-19 22:46 GMT+02:00 Cliff Patterson <cliffpatterson at gmail.com>:
>> No previous version installed. It was installed on a fresh OS.
>> On Jun 19, 2017 4:43 PM, "Israel López" <asralf at gmail.com> wrote:
>> Hi, did you have a previous version of genode installed???
>> I'm testing Geonode 2.6 too, but on Develoment mode, I had similar issues,
>> but "log-in" problem I solved running the create superuser command again.
>> The issue that remains is this one:
>> base.ResourceBase.tkeywords: (fields.W340) null has no effect on
>> ManyToManyField.
>> I don't understand it, but Geonode is running and working, if somebody
>> could explain me
>> how to fix it I will appreciate it.
>> Greetings.
>> 2017-06-19 11:29 GMT-05:00 Cliff Patterson <cliffpatterson at gmail.com>:
>>> I finally reinstalled on a clean Ubuntu 16.04.2 (64 bit) VPS with 4GB of
>>> ram and still having the same issues:
>>> 1. Unable to log in with superuser credentials
>>> 2. unable to fully update IP. The system hangs at "Inspecting the
>>> available layers in GeoServer ..."
>>> 3. Getting the following warning during install and when running
>>> createssuperuser:
>>> WARNINGS:
>>> ?: (1_8.W001) The standalone TEMPLATE_* settings were deprecated in
>>> Django 1.8 and the TEMPLATES dictionary takes precedence. You must put the
>>> values of the following settings into your default TEMPLATES dict:
>>> TEMPLATE_DIRS.
>>> ManyToManyField.
>>> Bottom line, even on a 4GB machine, I cannot get Geonode working. Have
>>> the installation instructions changed or am I missing some critical step?
>>> I'm using these: http://geonode.org/blog/2017/0
>>> 5/17/geonode-2.6-released/
>>> Big thanks!
>>> Cliff
>>> On Fri, Jun 9, 2017 at 7:25 AM, Simone Dalmasso <
>>> simone.dalmasso at gmail.com> wrote:
>>>> Hi, well 2 GB are probably not enough. 4GB are the minimum I think. You
>>>> shopuld be able to find geoserver with locate geoserver, it is uncompressed
>>>> in /usr/share if I'm no wrong.
>>>> 2017-06-09 13:03 GMT+02:00 Cliff Patterson <cliffpatterson at gmail.com>:
>>>>> Thanks for the reply!
>>>>> I didn't see any errors (except for template warnings) during
>>>>> installation. I even saw that geonode-geoserver was installed but I can't
>>>>> find it post installation.
>>>>> I spun it up on a VM with 4 cores and 2GB of ram on Digital Ocean. Is
>>>>> this enough power for GeoNode?
>>>>> Thanks again for your help!
>>>>> Cheers,
>>>>> Cliff
>>>>> On Jun 9, 2017 3:17 AM, "Simone Dalmasso" <simone.dalmasso at gmail.com>
>>>>> wrote:
>>>>>> Hi, yes definitely geoserver needs to be there and the package should
>>>>>> install it. Make sure your machine is powerful enough, also during the
>>>>>> installation you should have gotten some errors.
>>>>>> 2017-06-08 18:22 GMT+02:00 Cliff Patterson <cliffpatterson at gmail.com>
>>>>>>> PS: and I am unable to authenticate via the geonode website.
>>>>>>> On Thu, Jun 8, 2017 at 12:20 PM, Cliff Patterson <
>>>>>>> cliffpatterson at gmail.com> wrote:
>>>>>>>> Hello,
>>>>>>>> I decided to give Geonode 2.6 a go and installed it on a fresh VM
>>>>>>>> running Ubuntu 16.04.2 x64. I installed it with the following commands:
>>>>>>>> sudo add-apt-repository ppa:geonode/stable
>>>>>>>> sudo apt-get update
>>>>>>>> sudo apt-get install geonode
>>>>>>>> geonode createsuperuser
>>>>>>>> sudo geonode-updateip 67.207.87.119
>>>>>>>> When creating the super user, I get the following warning:
>>>>>>>> System check identified some issues:
>>>>>>>> WARNINGS:
>>>>>>>> TEMPLATE_DIRS.
>>>>>>>> ManyToManyField.
>>>>>>>> Username: test
>>>>>>>> Email address:
>>>>>>>> Password:
>>>>>>>> Password (again):
>>>>>>>> Superuser created successfully.
>>>>>>>> When running sudo geonode-updateip 67.207.87.119, the following
>>>>>>>> happens:
>>>>>>>> 1) Hangs on "Inspecting the available layers in GeoServer ..."
>>>>>>>> 2) Geonode does get up and running at 67.207.87.119 but no ability
>>>>>>>> to login
>>>>>>>> Replacing SITEURL value with '67.207.87.119' in
>>>>>>>> /etc/geonode/local_settings.py ... done.
>>>>>>>> Adding entry for '67.207.87.119' in /usr/share/geoserver/data/printing/config.yaml
>>>>>>>> ... done.
>>>>>>>> Adding ALLOWED_HOSTS with in /etc/geonode/local_settings.py ...
>>>>>>>> done.
>>>>>>>> Setting up oauth
>>>>>>>> Am I missing something in the instructions? Do we need to install
>>>>>>>> Geoserver on Tomcat7 first, then Geonode? As far as I can see, Geoserver
>>>>>>>> has not been installed, which I thought was part of the geonode
>>>>>>>> installation, but I could be wrong.
>>>>>>> _______________________________________________
>>>>>>> geonode-users mailing list
>>>>>>> geonode-users at lists.osgeo.org
>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>> Simone
>>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170620/fb94fcd1/attachment-0001.html>
More information about the geonode-users
