[GeoNode-users] Change DEFAULT_MAP_CRS to other CRS than 900913 or 4326
Simone Dalmasso
simone.dalmasso at gmail.com
Fri Mar 10 07:23:47 PST 2017
Hi, I don't think is possible to use other projections than the two (4326
and 900913/3857), unfortunately
2017-03-10 15:37 GMT+01:00 John, Steffen <s.john at atenekom.eu>:
> Hi all,
> I would like to change the DEFAULT_MAP_CRS of my Geonode instance to
> another value than 4326 or 900913.
> The reason for it is, that I need to add a WMS-Backgroundlayer which does
> not support 900913. Ok, 4326 is supported, but I want a projected system.
> I tried changing the Parameter DEFAULT_MAP_CRS to EPSG:25832, which is the
> official reference system in most states of Germany (UTM, Zone 32).
> Appearently, changing the parameter is not enough since the map is not
> loaded properly when creating a new map. In the debug tool of the browser,
> I can see that Geonode tries to find the following file:
> http://localhost:8002/maps/defs/EPSG25832.js
> and request spatialreference.org afterwards.
> The File can not be found, because its not there...
> Can you tell me, where exactly the file should be located and what should
> be in there? (I guess, the definition of the crs, but in which format?)
> Do need to change something else, in order to get it running?
> Thanks for your help.
> Best,
> Steffen
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170310/3a6e2ded/attachment.html>
More information about the geonode-users
