[GeoNode-users] Label and description of layer attribute table
Paolo Corti
pcorti at gmail.com
Fri Mar 17 07:21:33 PDT 2017
Hi Daniel
The original reason of that is that the client should display the
label in place of the field name in the identify dialog. If that is
not the case could you please file a ticket?
thanks a lot
p
On Fri, Mar 17, 2017 at 8:44 AM, Daniel Victoria
<daniel.victoria at gmail.com> wrote:
> Hi list,
> At the end of the metadata form in GeoNode, I can describe what each column
> in my layer attribute table contains (Description). Bet there is also a
> Label column. What does that do? The only place I saw some difference, when
> setting a Label, was that it changed the Attribute name in the layer page.
> I tested this in the geonode demo server (v2.4)
> http://demo.geonode.org/layers/geonode%3Asan_juan
> Cheers
> Daniel
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the geonode-users
