[GeoNode-users] Label and description of layer attribute table
Daniel Victoria
daniel.victoria at gmail.com
Fri Mar 17 08:04:30 PDT 2017
Done
https://github.com/GeoNode/geonode/issues/2957
On Fri, Mar 17, 2017 at 11:21 AM, Paolo Corti <pcorti at gmail.com> wrote:
> Hi Daniel
> The original reason of that is that the client should display the
> label in place of the field name in the identify dialog. If that is
> not the case could you please file a ticket?
> thanks a lot
> p
> On Fri, Mar 17, 2017 at 8:44 AM, Daniel Victoria
> <daniel.victoria at gmail.com> wrote:
> > Hi list,
> > At the end of the metadata form in GeoNode, I can describe what each
> column
> > in my layer attribute table contains (Description). Bet there is also a
> > Label column. What does that do? The only place I saw some difference,
> when
> > setting a Label, was that it changed the Attribute name in the layer
> page.
> > I tested this in the geonode demo server (v2.4)
> > http://demo.geonode.org/layers/geonode%3Asan_juan
> > Cheers
> > Daniel
> > geonode-users mailing list
> > geonode-users at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/geonode-users
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170317/6ad5302f/attachment.html>
More information about the geonode-users
