[GeoNode-users] Connection error
Francesco Bartoli
xbartolone at gmail.com
Wed Mar 22 09:54:13 PDT 2017
Then you should use the command ‘updatelayers’ as Simone already suggested. GeoNode needs that layer within its configuration data.
Hope this helps
Il giorno 22/mar/2017, alle ore 17:47, Carmine Massarelli <carmine.massarelli at ba.irsa.cnr.it> ha scritto:
> Dear,
> I created a new db in postgres on geonode server with postgis extension.
> We manipulate a layer stored in that db from our local qgis istance using the plugin DB manager for a remote connection.
> If I add new store, postgis (sorry for spatialite), directly from geoserver and then I create a map in geonode adding that layer I receive that error.
> thanks in advance
> carmine
> Il 03/22/2017 05:35 PM, Francesco Bartoli ha scritto:
>> Hi Carmine,
>> what do you mean with upload a spatialite layer in geoserver? Maybe using its extension for spatialite? Can you explain a little better your workflow?
>> Il giorno 22/mar/2017, alle ore 17:17, Carmine Massarelli <carmine.massarelli at ba.irsa.cnr.it> ha scritto:
>>> thanks,
>>> but sometimes we need to edit a spatialite layer from different qgis desktop in remote connection to geonode postgresdb. Is it possible without receive that error?
>>> many thanks
>>> carmine
>>> Il 03/22/2017 02:50 PM, Simone Dalmasso ha scritto:
>>>> Hi you should use Geonode to load data. Or run the updatelayers commands after you loaded in geoserver.
>>>> Il giorno mer 22 mar 2017 alle 14:00 Carmine Massarelli <carmine.massarelli at ba.irsa.cnr.it> ha scritto:
>>>> Dear,
>>>> if I upload a layer (shapefile or spatialite) directly in geoserver and then I create a map using local geoserver option to add a layer, I receive this error:
>>>> Connection Error
>>>> The server returned an error: 404 NOT FOUND.
>>>> If I click on Detail I can only see Page not Found.
>>>> I use geonode version 2.4 on Ubuntu 14.04.
>>>> How could I solve this issue?
>>>> thank in advance
>>>> carmine
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170322/8f87b733/attachment-0001.html>
More information about the geonode-users
